Stepper motor step/dir lib for drivers like A4988.. [SOLVED]
Goto page Previous  1, 2
PostPosted: Wed May 13, 2020 5:57 am     Reply with quote
Both those stepper chips have 3 pins for 'microstepping' and you're not setting them so the chip is always in full step mode.
while I don't have either device it seems that ....
code like ...
select step size ( set M1,M2,M3 pins) [say using 'SWITCH']
issue 'step command to step'
should work...
Others who use these devices will have real World knowledge, I'm just reading the datasheets...
PostPosted: Wed May 13, 2020 6:13 am     Reply with quote
The key thing is your existing code uses delay_ms between steps. Even
if the value is '1' for this, it limits your maximum step rate to just 1000*sec.
The code posted is instead using a timer interrupt at 25KHz for the minimum
step interval....
If you have a 400step motor, and you are using say 16* microstepping
(generally there is little reason to ever go beyond this - only special motors
have enough accuracy on the magnets to give worthwhile working beyond
this), then to do (say) 200RPM, you need a step pulse rate of:
(200*400*16)/60 = 21333Hz.
at 1000Hz, you can only get to about 20RPM.
In fact looking at it you use two delay_ms calls, so 10RPM.
The stepper controller should only require a pulse of perhaps 1uSec (not
mSec), and the repeat frequency of this will need to go up to tens
of kHz if you want to move the motor quickly.....
mednas
PostPosted: Wed May 13, 2020 11:41 am     Reply with quote
The 3 pins in the driver to select the mode M1, M2 and M3 are connected to 3 interruptors i can select full step mode the 3 pins connected to GND and 1/16 microstep the 3 pins to VCC. My code work only for full step. I have to change delay to us for microsteps.
BTW i have tested the code of the link shared by Ttelmah it work fine with timer 25khz, this what i want. I will add some lines to use uart and receive data from uart and show it in lcd.
Thank you guys
''I never lose, I either win or learn!" Nelson Mandela
PostPosted: Wed May 13, 2020 12:44 pm     Reply with quote
Good. Very Happy
Change the title of the thread, to include [Solved] please.
Page 2 of 2
