screen print cleaning
Goto page 1, 2  Next
ertansuluagac
PostPosted: Fri May 08, 2020 5:05 am     Reply with quote
ccs c compiler 5.093
PIC18F45K22
CRY 16MHZ
I don't want the posts to disappear when cleaning the screen. I want to do it very quickly. I made trials, it was not successful. Is there a good way to do this?
Es
PostPosted: Fri May 08, 2020 6:43 am     Reply with quote
you should post what 'screen' you're using as a LOT depends upon the mfr/make/rev .
Also post your test code.
ertansuluagac
PostPosted: Fri May 08, 2020 7:17 am     Reply with quote
test cpde
#INT_TIMER2
void  TIMER2_isr(void)
   static unsigned int32 counter;
   if(++counter>40000)//20 second  then cleaning
     printf(lcd_putc,"\f");
     counter=0;
 setup_timer_2(T2_DIV_BY_16,124,1);//500 us overflow, 500 us interrupt
Es
PostPosted: Fri May 08, 2020 7:30 am     Reply with quote
Which LCD module ?
The time the 'clear screen' command take depends upon the module. I checked one 2004 display and it takes about 2ms to 'clear the display'.
ertansuluagac
PostPosted: Fri May 08, 2020 7:35 am     Reply with quote
4x20 character Lcd
WH2004A-YYH-JT#
Es
PostPosted: Fri May 08, 2020 7:52 am     Reply with quote
According to one datasheet I downloaded, 'clear display' take +- 1.53ms, so a max of 2ms is what I'd expect if in 4 bit mode...
Jay
PostPosted: Fri May 08, 2020 8:06 am     Reply with quote
On ones using the genuine Hitachi controller that is actually the specified
time (1.64mSec).
Why clear?. Remember you can just goto the required location and write new
data that replaces what is already there. You can just use the 'home' command and write a new screen without having to clear.
Remember the LCD update will be faster if you are using the R/W pin and
waiting for the display to complete, rather than using fixed delays.
ertansuluagac
PostPosted: Fri May 08, 2020 9:13 am     Reply with quote
R/W pin I using. How can I use 'Home' command
Es
PostPosted: Fri May 08, 2020 9:36 am     Reply with quote
If you are using flex_lcd, then:
      lcd_send_byte(0,2);
      lcd_line = 1;
      delay_us(1640);
PostPosted: Fri May 08, 2020 10:49 am     Reply with quote
To clear the character lcd screen with lcd.c or with flex_lcd.c, you do this:
lcd_putc('\f');
PostPosted: Sat May 09, 2020 12:01 am     Reply with quote
He was complaining that this was too slow.
However have to agree. You can clear the display and write completely new
data, in less time than the screen takes to refresh. Can't even see that it
has been cleared normally....
ertansuluagac
PostPosted: Sat May 09, 2020 10:29 am     Reply with quote
The code you wrote by the time I compile give error.
         lcd_send_byte (0,2);
         lcd_line = 1;
         delay_us (1,640);
error
*** Error 12 "Machine To Machine\CCS C Kod\Machine to Machine.c" Line 231(10,18): Undefined identifier lcd_line
*** Error 58 "Machine To Machine\CCS C Kod\Machine to Machine.c" Line 232(22,25): Expecting a close paren
Es
PostPosted: Sat May 09, 2020 10:46 am     Reply with quote
'lcd_line' is probably defined within the driver so...
...that error could be because you didn't load the LCD driver before the code.
the other error might be the delay_us().
might be a compiler version bug I'd try
delay_us(1640); instead og
delay_us(1,640);
ertansuluagac
PostPosted: Sat May 09, 2020 11:10 am     Reply with quote
compiler 5.93
delay_us(1640); this code it is not giving error. at this moment lcd_line giving error. But , Is it correct this code delay_us(1640)?
Es
PostPosted: Thu May 14, 2020 1:18 am     Reply with quote
delay_us(1640); should work fine.
It's give an issue with a really old compiler (back in the V4 or possibly
even earlier days, the maximum allowed was 255), but this has been
acceptable syntax for perhaps 10 years!...
It's also give an issue if the clock setup was missing, but then delay_ms
would fail as well.
Goto page 1, 2  Next
Page 1 of 2
