S1gnature
Communication between PIC 16f877a and MATLAB |
Posted: Tue Apr 28, 2020 12:38 am |
I am self-studying PIC with CCS 5.0. I am working on sending/receiving data to/from PIC over MATLAB. Currently I am stuck in the first step.
My goal is to send a string from PIC 16f877a over a RS-232 port to PC. On PC, use MATLAB to read this strings. For now it just simple as that. I read the Help from CCS and my workaround is as follows (using puts method after declaring use RS232):
Code: | #include <16f877a.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use RS232 (baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8,parity=N)
puts("123");
On MATLAB, my code:
Declare used serial port :
Code: | >> s = serial('COM5') |
Check information for matching with PIC
Code: | >> get(s)
ByteOrder = littleEndian
BytesAvailable = 0
BytesAvailableFcn =
BytesAvailableFcnCount = 48
BytesAvailableFcnMode = terminator
BytesToOutput = 0
ErrorFcn =
InputBufferSize = 512
Name = Serial-COM5
ObjectVisibility = on
OutputBufferSize = 512
OutputEmptyFcn =
RecordDetail = compact
RecordMode = overwrite
RecordName = record.txt
RecordStatus = off
Status = closed
Tag =
Timeout = 10
TimerFcn =
TimerPeriod = 1
TransferStatus = idle
Type = serial
UserData = []
ValuesReceived = 0
ValuesSent = 0
SERIAL specific properties:
BaudRate = 9600
BreakInterruptFcn =
DataBits = 8
DataTerminalReady = on
FlowControl = none
Parity = none
PinStatus = [1x1 struct]
PinStatusFcn =
Port = COM5
ReadAsyncMode = continuous
RequestToSend = on
StopBits = 1
Terminator = LF
Open port:
Read data:
Code: | >> fread(s)
Warning: The specified amount of data was not returned within the Timeout period.
'serial' unable to read any data. For more information on possible reasons, see Serial Read Warnings.
ans =
1×0 empty double row vector |
I searched on some Internet sources and also tried:
Code: | >> fgets(s)
Warning: A timeout occurred before the Terminator was reached.
'serial' unable to read all requested data. For more information on possible reasons, see Serial Read Warnings.
ans =
'õõõõõõõõõõõõ' |
In both cases it shows nothing or some weird characters.
Could you give me some suggestions on this problem? Thank you very much for your time. |
Posted: Tue Apr 28, 2020 12:44 am |
Try it as follows, with the while(TRUE) at the end of main():
#fuses NOWDT, XT, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use delay(clock=4M)
#use RS232 (baud=9600, UART1, Errors)
puts("123");
while(TRUE);
Posted: Tue Apr 28, 2020 12:58 am |
The other thing is this:
#fuses NOWDT,HS,NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
These two lines, may slightly 'disagree' with one another.
Weird characters could be saying that the PIC is not actually running at the
speed you are telling the code it is running at.
Now HS is the oscillator selection for a crystal running at >=4MHz, but
on most chips is only used if you are running above 4Mhz. Yet you are
saying you are running at 4Mhz. So what crystal is actually on the board
you are using?.
Also with a crystal, you should always use PUT.
Note that PCM has selected XT in his version...
However he has left PUT off. The first character at least, risks
corruption starting off a crystal without PUT. |
S1gnature
Posted: Tue Apr 28, 2020 1:23 am |
Ttelmah wrote: | The other thing is this:
you are using?.
Thank you PCM programmer and Ttelmah for your prompt replies. The actual crystal on the board is 4MHz, I have omitted the HS in the definition and also added PUT. I'm not sure what's wrong now because in MATLAB it shows empty strings when I use the new code:
>> fgets(s)
ans =
0×0 empty char array
Posted: Tue Apr 28, 2020 2:12 am |
Quote: | in MATLAB it shows empty strings when I use the new code. |
Post the new PIC code. |
Posted: Tue Apr 28, 2020 2:48 am |
#fuses NOWDT,XT, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
Note the two changes. |
S1gnature
Posted: Tue Apr 28, 2020 2:51 am |
PCM programmer wrote: | Quote: | in MATLAB it shows empty strings when I use the new code. |
It is actually your code, I only change NOPUT to PUT following Ttelmah.
#fuses NOWDT, XT, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
puts("123");
while(TRUE);
Posted: Tue Apr 28, 2020 2:55 am |
OK.
Understand.
PCM_Programmers code prints the string _once_. Once only.
You say , implies you are reading multiple
times after this single transmission, and these _will_ be 'empty'.... |
Joined: 01 Jul 2010 Posts: 9506 Location: Greensville,Ontario
Posted: Tue Apr 28, 2020 5:20 am |
I'd have main()..
forever loop..
send 123
delay 1 second
forever loop..
By having your proram send the data forever at a 1 hz rate you have some time to see what's happening, using a scope...
Also, I'd use a terminal program , like RealTerm, FIRST, before using MATLAB. Terminal programs will be easier to setup and can confirm the PIC is working properly. So, I'd run the terminal program, connect the PC serial TX pin to the PC serial RX pin(aka loopback ). Typing on PC KBD should be seen in the PC screen. That will confirm the terminal program is working. NOW connect PC to PIC. The PC screen should show whatever the PIC is sending '123', in your case....
After this, then configure /run your MATLAB program. if it doesn't work properly, you now KNOW it's 'something' in the MATLAB code.. |
Posted: Tue Apr 28, 2020 5:34 am |
There is one glaring thing:
In the MPLAB setup:
Terminator = LF
Nowhere in the code, do you send a LF....
while (TRUE)
puts("123\n"); //note the '\n' LF
delay_ms(250);
S1gnature
Posted: Tue Apr 28, 2020 6:34 am |
Thank you everyone for your kind help. The information you guys gave me would help a lot! I will try to get back to the topic if I have progress. I am reading some more documents regarding this issues (some parts in the UART are still foggy to me :D). |
Posted: Tue Apr 28, 2020 7:01 am |
Have you tried sending the terminator?.
You are sending 123123123123123
No spaces or terminators between the numbers. No wonder MATLAB
can't work out what it is meant to decode..... |
S1gnature
Posted: Tue Apr 28, 2020 8:37 am |
Ttelmah wrote: | Have you tried sending the terminator?.
I would like to describe the problem carefully there:
I have checked on the datasheet of my development board, it shows that the crystal clock is 4MHz.
If I use your suggested code (FUSES XT). Nothing happens.
If I change XT to HS. I used the Realterm as suggested by temtronic (thank you very much) and I believe it begins to send data through the serial port.
But the sent data again, are some weird characters.
Posted: Tue Apr 28, 2020 8:41 am |
Quote: | I have checked on the datasheet of my development board |
Post the name or model number of your development board, and post a
link to the website for the board. |
S1gnature
Posted: Tue Apr 28, 2020 8:49 am |
PCM programmer wrote: | Quote: | I have checked on the datasheet of my development board |
It looks like a hand made board, I don't see any information on the board and the datasheet about the manufacturer. (I borrow it from someone else) |
