I need CRC16-CCITT(KERMIT) not CRC16-CCITT(XMODEM)
Josep Robert
PostPosted: Wed Mar 04, 2020 3:23 am     Reply with quote
Hello.
I need to calculate the CRC16-CCITT(Kermit) but this routine gives me the CRC16-CCITT(XMODEM).
I don't know what to change to obtain the CRC16-CCITT(KERMIT).
I don't know to implement the following definitions:
CRC-16/XMODEM
width=16 poly=0x1021 init=0x0000 refin=false refout=false xorout=0x0000 check=0x31c3 residue=0x0000 name="CRC-16/XMODEM"
CRC-16/KERMIT
width=16 poly=0x1021 init=0x0000 refin=true refout=true xorout=0x0000 check=0x2189 residue=0x0000 name="CRC-16/KERMIT"
Could you help me?
thanks in advance.
#include <18LF47K40.h>
#use delay(clock = 16MHZ, internal)
#FUSES WDT_SW
#FUSES WDT65536
#case
   unsigned int8 data[6] = {0x05 , 0x01 , 0x00 , 0x04 , 0xFC , 0xFF};   // XMODEM=7DCC. (KERMIT = 72A6)
   unsigned int16 crc;
   setup_crc(16, 12, 5, 0);                    // Setup the CRC polynomial x^16 + x^12 + X^5 + X^0
   crc_init(0x0000);                           // Starts the CRC accumulator out at 0
   crc = crc_calc16(data, sizeof(data), 8);    // Returns the calculated CRC value
   delay_cycles(1);                            // Breakpoint
PostPosted: Wed Mar 04, 2020 3:39 am     Reply with quote
Kermit, has the bit order in the bytes reversed before processing (and
afterwards). Also the byte order is swapped in the final result.
It's otherwise the same as XMODEM. Same seed, and same polynomial.
Bit reversal can be done efficiently with:
<https://www.ccsinfo.com/forum/viewtopic.php?t=23364>
So apply this to your data, feed this through the XMODEM calculator,
then apply this again to the result. Finally swap the pair of bytes for
the result.
Josep Robert
PostPosted: Wed Mar 04, 2020 3:55 am     Reply with quote
Thank you very much for your immediate help. Regards.
Josep Robert
PostPosted: Wed Mar 04, 2020 4:41 am     Reply with quote
With this code I get the CRC-16 / KERMIT. It works fine. Thanks again Ttelmah for your help.
#FUSES WDT_SW
#FUSES WDT65536
#case
int8 swap_bits(int8 data);
   unsigned int8 i, crcH, crcL;
   unsigned int16 crc;
   // unsigned int8 dataA[1] = {0x00};        // CRC-16/KERMIT = 0000   ok
   // unsigned int8 dataA[4] = {0x03 , 0x01 , 0x00 , 0x05};                                             // CRC-16/KERMIT = BC28   ok
      unsigned int8 dataA[6] = {0x05 , 0x01 , 0x00 , 0x04 , 0xFC , 0xFF};                               // CRC-16/KERMIT = 72A6   ok
   // unsigned int8 dataA[10] = {0x09, 0xFF , 0x00 , 0x00 , 0x07 , 0x01 , 0x7F , 0x00 , 0xFF , 0xFF};   // CRC-16/KERMIT = AEF6   ok
   unsigned int8 dataAreversed[10];
   for (i = 0; i < sizeof(dataA); i++)
      dataAreversed[i] = swap_bits(dataA[i]);
   crc = crc_calc16(dataAreversed, sizeof(dataA), 8);   // Returns the calculated CRC value
   crcH = swap_bits(make8(crc, 1));
   crcL = swap_bits(make8(crc, 0));
   crc = swap_bits(make8(crc, 1)) * 256 + swap_bits(make8(crc, 0));
   int8 result = 0;
   if(bit_test(data, 0)) bit_set(result, 7);
   if(bit_test(data, 1)) bit_set(result, 6);
   if(bit_test(data, 2)) bit_set(result, 5);
   if(bit_test(data, 3)) bit_set(result, 4);
   if(bit_test(data, 4)) bit_set(result, 3);
   if(bit_test(data, 5)) bit_set(result, 2);
   if(bit_test(data, 6)) bit_set(result, 1);
   if(bit_test(data, 7)) bit_set(result, 0);
   return result;
PostPosted: Wed Mar 04, 2020 5:33 am     Reply with quote
Well done. Smile
PostPosted: Wed Mar 04, 2020 6:04 am     Reply with quote
WOW, this is a perfect example of how this fourum can work !!
In about an hour , a challenging quetion is asked, a detailed response, and then working code posted by the original poster.
NICE !!!
sad thing is I remember when xmodem came out......
allenhuffman
PostPosted: Thu Mar 12, 2020 9:13 am     Reply with quote
Then we both probably remember when XMODEM didn't have CRC (and just used a checksum) ;-)
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Thu Mar 12, 2020 10:29 am     Reply with quote
Problem is I remember using this with acoustic coupled modems where
the inductors used for the tone filters were the size of oranges,...
allenhuffman
PostPosted: Thu Mar 12, 2020 11:25 am     Reply with quote
Well, my first modem was a borrowed acoustic coupler, but it was a RadiShack model so probably much newer. I think you have me beat!
PostPosted: Thu Mar 12, 2020 12:35 pm     Reply with quote
I remember the Radio Shack one. A lot later unit (mid 1980's).
Xmodem was late 1970's. Before this is was mainly all 'own coding'
on error testing. Usually custom for the company involved.
Showing our age rapidly.... Sad
