use Master & Slave on the same MCU !?
walat
PostPosted: Fri Mar 06, 2020 3:42 am     Reply with quote
I'm using 18f87k22 with CCS-C V5.051
I used UART1 as Modbus Slave and successfully communicate with Modbus_Poll.exe PC Software.
Then I comment UART1 and slave codes and used UART2 as Modbus Master and successfully communicate with ModBus_Slave.exe PC Software.
But,
When I try to use the same MCU as a Master and Slave, I got these errors.
So is it impossible to use both Master & Slave on the same MCU?
Best Regards.
C:\Program Files (x86)\PICC\drivers\modbus_phy_layer_rtu.c:25:1: Info#300 More info: Timer 1 tick time is 128,00 us
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:133:24: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:134:31: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:135:41: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:136:31: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:137:33: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:138:33: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:139:37: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:140:37: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP.h:142:26: Warning#225 Duplicate #define
C:\UserData\Valsmatik_B-Plus\VM_BP.X\mcp41010.c:24:1: Warning#208 Function not void and does not return a value set_pot
C:\UserData\Valsmatik_B-Plus\VM_BP.X\mcp41010.c:45:1: Warning#208 Function not void and does not return a value shutdown_pot
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP_SubFunctions.c:20:54: Error#12 Undefined identifier -- modbus_read_holding_registers_rsp
C:\UserData\Valsmatik_B-Plus\VM_BP.X\VMBP_SubFunctions.c:25:56: Error#12 Undefined identifier -- modbus_write_multiple_registers_rsp
2 Errors, 11 Warnings.
PostPosted: Fri Mar 06, 2020 6:24 am     Reply with quote
No, not at all impossible, but as standard the drivers are only written to
support one or the other. You would have to tweak them to do this.
Using two busses I presume, since 'Modbus' is not a multi-master bus.
Only Modbus TCP supports multi master. Modbus ASCII and RTU don't.
