how reduce execution time in "analog read "
hamid9543
PostPosted: Tue Feb 25, 2020 2:13 pm     Reply with quote
i use pic18f46k22 and internal clock 64 mhz
how reduce execution time in "analog read "?
Is there any other way to run code in less time?
#include <18F46K22.h>
#FUSES NOWDT,NOBROWNOUT,NOPUT,PLLEN
#device ADC=8
#use delay(internal=64mhz)
#define cal_key !input(pin_e2)
rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=pin_a4,bits=8,stream=blt)//b
unsigned int8 njl_value;
unsigned int16 AN[20]={13,11,9,8,10,12,26,25,24,19,17,23,22,21,20,4,3,2,1,0},min_njl[20],max_njl[20],cal_done=0;
int1 njl[20];
   set_analog_pins(PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A5,PIN_B0,PIN_B1,PIN_B2,PIN_B3,PIN_B4,PIN_B5,PIN_C5,PIN_C7,PIN_D0,PIN_D1,PIN_D2,PIN_D3,PIN_D4,PIN_D5,PIN_D6);
   setup_adc(ADC_CLOCK_DIV_8|ADC_TAD_MUL_0);
      for(int i=0;i<20;i++)
         threshold[i]=read_eeprom(i);
         min_njl[i] = 255;
         max_njl[i] = 0;
   while(True)
      if(cal_key && cal_done==0)
         while (cal_key);
         while (!cal_key)
               set_adc_channel(AN[i]);
               delay_us(10);
               njl_value=read_adc();
               if( njl_value>max_njl[i])      max_njl[i]= njl_value;
               if( njl_value<min_njl[i])      min_njl[i]= njl_value;
           //threshold[i]= (min_njl[i]+max_njl[i])/2;
           threshold[i]= max_njl[i]+10;Ůž
           write_eeprom(i,threshold[i]);
           delay_us(10);
         cal_done=1;
         delay_us(10);
       if(njl_value>(threshold[i]))           {njl[i]=1;}
       else if(njl_value<(threshold[i]))       njl[i]=0;
       for(int a=0;a<20;a++) printf("%u",njl[a]);
      printf("\n\r");
PostPosted: Tue Feb 25, 2020 3:13 pm     Reply with quote
couple of 'issue'...
1) the recommended adc clock is Fosc/64 NOT Fosc/8 as you have......
Check the ADC section, Table 17-1 , .....
2) do all the calculations first, THEN store as a 'block' with one write eeprom command.
3) looks like ADC is in 8 bit mode , so the ADC result buffer only needs to be 8 bit ,not 16 bits
Re: how reduce execution time in "analog read "
PostPosted: Tue Feb 25, 2020 7:49 pm     Reply with quote
hamid9543 wrote:
How reduce execution time in "analog read "?
delay_us(10);
njl_value = read_adc();
if( njl_value > max_njl[i] ) max_njl[i] = njl_value;
if( njl_value < min_njl[i] ) min_njl[i] = njl_value;
You are doing a large number of indirect array accesses, as shown in
bold above.
Look at the amount of ASM code in your loop that's shown below.
It's enormous. The PIC is very inefficient at indirect array accesses.
.....    set_adc_channel(AN[i]);
002C8:  BCF    STATUS.C
002CA:  RLCF   i,W
002CC:  CLRF   @03
002CE:  ADDLW  AN
002D0:  MOVWF  FSR0L
002D2:  MOVLW  AN+-5
002D4:  ADDWFC @03,W
002D6:  MOVWF  FSR0H
002D8:  MOVFF  PREINC0,@@9C
002DC:  MOVF   POSTDEC0,F
002DE:  MOVFF  INDF0,@@9B
002E2:  RLCF   @@x9B,W
002E4:  MOVWF  @00
002E6:  RLCF   @@x9C,W
002E8:  MOVWF  @01
002EA:  RLCF   @00,F
002EC:  RLCF   @01,F
002EE:  MOVLW  FC
002F0:  ANDWF  @00,F
002F2:  MOVF   ADCON0,W
002F4:  ANDLW  83
002F6:  IORWF  @00,W
002F8:  MOVWF  ADCON0
......   if( njl_value>max_njl[i])      max_njl[i]= njl_value;
0030C:  BCF    STATUS.C
0030E:  RLCF   i,W
00310:  CLRF   @03
00312:  ADDLW  max_njl
00314:  MOVWF  FSR0L
00316:  MOVLW  max_njl+-85
00318:  ADDWFC @03,W
0031A:  MOVWF  FSR0H
0031C:  MOVFF  PREINC0,03
00320:  MOVF   POSTDEC0,F
00322:  MOVFF  INDF0,01
00326:  MOVF   @03,F
00328:  BNZ   0348
0032A:  MOVF   njl_value,W
0032C:  SUBWF  @01,W
0032E:  BC    0348
00330:  BCF    STATUS.C
00332:  RLCF   i,W
00334:  CLRF   @03
00336:  ADDLW  max_njl
00338:  MOVWF  FSR0L
0033A:  MOVLW  max_njl+-85
0033C:  ADDWFC @03,W
0033E:  MOVWF  FSR0H
00340:  CLRF   PREINC0
00342:  MOVF   POSTDEC0,F
00344:  MOVFF  njl_value,INDF0
.....      if( njl_value<min_njl[i])      min_njl[i]= njl_value;
00348:  BCF    STATUS.C
0034A:  RLCF   i,W
0034C:  CLRF   @03
0034E:  ADDLW  min_njl
00350:  MOVWF  FSR0L
00352:  MOVLW  min_njl+-45
00354:  ADDWFC @03,W
00356:  MOVWF  FSR0H
00358:  MOVFF  PREINC0,03
0035C:  MOVF   POSTDEC0,F
0035E:  MOVFF  INDF0,01
00362:  MOVF   @03,F
00364:  BNZ   036C
00366:  MOVF   @01,W
00368:  SUBWF  njl_value,W
0036A:  BC    0384
0036C:  BCF    STATUS.C
0036E:  RLCF   i,W
00370:  CLRF   @03
00372:  ADDLW  min_njl
00374:  MOVWF  FSR0L
00376:  MOVLW  min_njl+-45
00378:  ADDWFC @03,W
0037A:  MOVWF  FSR0H
0037C:  CLRF   PREINC0
0037E:  MOVF   POSTDEC0,F
00380:  MOVFF  njl_value,INDF0
00384:  INCF   i,F
00386:  BRA    02C2
00388:  BRA    02BA
hamid9543
PostPosted: Tue Feb 25, 2020 10:12 pm     Reply with quote
is it ok?
void read_sensor{
        set_adc_channel(13);
         delay_us(10);
         if(njl_value>(threshold[0]))     {njl[0]=1;on_line++;}
   else if(njl_value<(threshold[0]))       njl[0]=0;
         set_adc_channel(11);
         delay_us(10);
         if(njl_value>(threshold[1]))     {njl[1]=1;on_line++;}
   else if(njl_value<(threshold[1]))       njl[1]=0;
         set_adc_channel(9);
         delay_us(10);
         if(njl_value>(threshold[2]))     {njl[2]=1;on_line++;}
   else if(njl_value<(threshold[2]))       njl[2]=0;
         set_adc_channel(8);
         delay_us(10);
         if(njl_value>(threshold[3]))     {njl[3]=1;on_line++;}
   else if(njl_value<(threshold[3]))       njl[3]=0;
         set_adc_channel(10);
         delay_us(10);
         if(njl_value>(threshold[4]))     {njl[4]=1;on_line++;}
   else if(njl_value<(threshold[4]))       njl[4]=0;
         set_adc_channel(12);
         delay_us(10);
         if(njl_value>(threshold[5]))     {njl[5]=1;on_line++;}
   else if(njl_value<(threshold[5]))       njl[5]=0;
          set_adc_channel(26);
         delay_us(10);
         if(njl_value>(threshold[6]))     {njl[6]=1;on_line++;}
   else if(njl_value<(threshold[6]))       njl[6]=0;
         set_adc_channel(25);
         delay_us(10);
         if(njl_value>(threshold[7]))     {njl[7]=1;on_line++;}
   else if(njl_value<(threshold[7]))       njl[7]=0;
         set_adc_channel(24);
         delay_us(10);
         if(njl_value>(threshold[8]))     {njl[8]=1;on_line++;}
   else if(njl_value<(threshold[8]))       njl[8]=0;
         set_adc_channel(19);
         delay_us(10);
         if(njl_value>(threshold[9]))     {njl[9]=1;on_line++;}
   else if(njl_value<(threshold[59]))       njl[9]=0;
         set_adc_channel(17);
         delay_us(10);
         if(njl_value>(threshold[10]))     {njl[10]=1;on_line++;}
   else if(njl_value<(threshold[10]))       njl[10]=0;
         set_adc_channel(23);
         delay_us(10);
         if(njl_value>(threshold[11]))     {njl[11]=1;on_line++;}
   else if(njl_value<(threshold[11]))       njl[11]=0;
         set_adc_channel(22);
         delay_us(10);
         if(njl_value>(threshold[12]))     {njl[12]=1;on_line++;}
   else if(njl_value<(threshold[12]))       njl[12]=0;
         set_adc_channel(21);
         delay_us(10);
         if(njl_value>(threshold[5]))     {njl[13]=1;on_line++;}
   else if(njl_value<(threshold[5]))       njl[13]=0;
         set_adc_channel(20);
         delay_us(10);
         if(njl_value>(threshold[5]))     {njl[14]=1;on_line++;}
   else if(njl_value<(threshold[5]))       njl[14]=0;
         set_adc_channel(4);
         delay_us(10);
         if(njl_value>(threshold[15]))     {njl[15]=1;on_line++;}
   else if(njl_value<(threshold[15]))       njl[15]=0;
         set_adc_channel(3);
         delay_us(10);
         if(njl_value>(threshold[16]))     {njl[16]=1;on_line++;}
   else if(njl_value<(threshold[16]))       njl[16]=0;
         set_adc_channel(2);
         delay_us(10);
         if(njl_value>(threshold[17]))     {njl[17]=1;on_line++;}
   else if(njl_value<(threshold[17]))       njl[17]=0;
         set_adc_channel(1);
         delay_us(10);
         if(njl_value>(threshold[18]))     {njl[18]=1;on_line++;}
   else if(njl_value<(threshold[18]))       njl[18]=0;
         set_adc_channel(0);
         delay_us(10);
         if(njl_value>(threshold[19]))     {njl[19]=1;on_line++;}
   else if(njl_value<(threshold[19]))       njl[19]=0;
hamid9543
PostPosted: Tue Feb 25, 2020 10:17 pm     Reply with quote
Please give more explanation
PostPosted: Wed Feb 26, 2020 1:25 am     Reply with quote
is it ok?
Compile it and look at the .LST file in your project folder.
See if the amount of ASM code is low enough for your requirements.
PostPosted: Wed Feb 26, 2020 3:05 am     Reply with quote
Two comments:
First, Tacq for the chip is 7.45uSec, so you can save 2uSec on each sample
by reducing the delay to 8uSec instead of 10uSec. Small but significant.
However the biggest saving is to make use of the time.
            set_adc_channel(AN[0]);
            delay_us(8);
            read_adc(ADC_START_ONLY);
            //Now takes 12 Tad cycles to perform conversion
            //12uSec at Fosc/64.
            delay_us(4);
               delay_us(8);
               njl_value=read_adc(ADC_READ_ONLY);
               set_adc_channel(AN[i+1]); //select next channel
               delay_us(8);
               read_adc(ADC_START_ONLY); //start next conversion
Now the key point here is you start by reading a value that has already been converted. You then select the next channel. Wait Tacq, and start a new
conversion. Then while this conversion is happening, you perform
the time expensive array accesses.
Now I did a quick 'count', and with the Tad at Fosc/64 (which is what is
required at this clock rate), a conversion takes about 12uSec. The
array accesses take about 4uSec. So you still have to delay about 8uSec
before the conversion will be complete. However you are then actually
converting _while_ you are doing these accesses. Result much more
efficient....
