[Solved] CCS returning a constant string.
allenhuffman
PostPosted: Thu Feb 20, 2020 11:59 am     Reply with quote
In a PIC24 project I worked on a few months ago, I had debugging functions that would print out a text version of a value, such as:
printf ("Command: %d (%s)\r\n", command, GetCommandString(command));
It worked well.
Another developer here is using a routine to return a string for a mode to display on an LCD, and sometimes it ends up pointing to 0s instead of the hard-coded string constant. I wrote a quick test program, and found mine also seems to point to NULL. I tested using 5.082 and 5.092.
I created a very simple test program, identical in flow to the routines I used earlier that worked. But today, it doesn't work for me (and the other project works, unless he add some lines of code, then it starts returning a pointer to 0s).
#include <main.h>
// Prototypes
const char *GetName(int nameValue);
// Functions
   printf (__DATE__" "__TIME__"\r\n");
   for (int idx = 0; idx < 5; idx++)
      printf ("%d = '%s'\r\n", idx, GetName(idx));
   while(TRUE);
   printf ("GetName(%d)\r\n", nameValue);
   switch (nameValue)
      case 0:
         return "Zero";
      case 1:
         return "One";
      case 2:
         return "Two";
      default:
         return "???";
// End of main.c
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Thu Feb 20, 2020 12:09 pm     Reply with quote
You need to either be enabling PSV, or using PASS_STRINGS=IN_RAM to
support this. Much more efficient to enable PSV,
allenhuffman
PostPosted: Thu Feb 20, 2020 12:16 pm     Reply with quote
Ah, that could have been enabled in the project I was doing this in, though we don't use any strings (no I/O).
I just added that in my master header file, but no change. The ptr being returns is correct, however, and matches where the data in flash is located.
allenhuffman
PostPosted: Thu Feb 20, 2020 12:34 pm     Reply with quote
Changing from constant quotes to const strings works. Oddly.
#include <main.h>
// Prototypes
// Functions
      printf ("%d = 0x%x '%s'\r\n", idx, GetName(idx), GetName(idx));
   while(TRUE);
const char *zero = "Zero";
const char *one = "One";
const char *two = "Two";
const char *unknown = "???";
   //printf ("GetName(%d)\r\n", nameValue);
   switch (nameValue)
      case 0:
         //return "Zero";
         return zero;
      case 1:
         //return "One";
         return one;
      case 2:
         //return "Two";
         return two;
      default:
         //return "???";
         return unknown;
// End of main.c
20-Feb-20 12:33:14
0 = 0x802 'Zero'
1 = 0x808 'One'
2 = 0x80c 'Two'
3 = 0x810 '???'
4 = 0x810 '???'
allenhuffman
PostPosted: Thu Feb 20, 2020 2:15 pm     Reply with quote
CCS replied.
#device CONST=ROM
That makes the 'return "string"' work. Cool. That must have been in the pre-exiting project that I was working with.
CONST=READ_ONLY
Uses the ANSI keyword CONST definition, making CONST variables read only, rather than located in program memory.
CONST=ROM
Uses the CCS compiler traditional keyword CONST definition, making CONST variables located in program memory.
allenhuffman
PostPosted: Thu Feb 20, 2020 3:43 pm     Reply with quote
Well, it was working. Now it's not working again. Back to my original issue. Dunno.
PostPosted: Thu Feb 20, 2020 4:05 pm     Reply with quote
keep going back in versions until it works again.....
I copy/change/compile/test....
If I don't like it, I go back....
pgmv1,pgmv2,......pgmv999
I know it's a lot of HD space, but there's lots available.
Once the project is done,I then delete all but last 3-5 versions. Well I should but really HD space is unlimited, right ?
allenhuffman
PostPosted: Thu Feb 20, 2020 4:19 pm     Reply with quote
Yeah, the history in the CCS editor is a nice bonus.
PostPosted: Fri Feb 21, 2020 2:24 am     Reply with quote
Is the current failure with 5.092?.
This seems to have an 'oddity' if you do a lot of changes, that it then
stops working. Creates different output from what it gives after a clean
'launch'. I've noted it and reported this to CCS.
Could explain why you are seeing it working 'sometimes'....
Might be tempted to suggest you try re-installing the compiler. I have
(very occasionally) seen odd issues that seem to come down to a corrupted
installation. Have just tried you code with every combination I could think
of (PSV, PASS_STRINGS, const= etc.), and all worked correctly....
allenhuffman
PostPosted: Fri Feb 21, 2020 10:06 am     Reply with quote
I am so glad we aren't the only ones! :-) I am in the habit of closing all windows and shutting down CCS, then double-clicking the next project file to make that one open. It seems to write files from the old project into the new one if I select it other ways. I may do a quick remove/clean install today, though I'm on my temporary Windows 7 machine again while the DELL laptop is back in the shop.
