allenhuffman
Joined: 17 Jun 2019 Posts: 540 Location: Des Moines, Iowa, USA
[Explained] Prototype mismatching function - no warning? |
Posted: Thu Jan 30, 2020 9:27 am |
Is there a way to enable a warning when something like this happens?
header file:
Code: | void foo(); // no return value |
source file:
Code: | int16 foo() // returns an in16
return 42;
A coworker had a mismatch in his code like this, and was getting a "Contact CCS" error and it wouldn't build. I tried to recreate that on my system, and don't get that error, but also don't get a warning.
When I use GCC, I crank up all the warnings. I'm not sure how to do that (if even possible) inside the CCS IDE. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Posted: Thu Jan 30, 2020 9:32 am |
That won't give an error, unless the code tries to use the foo
function before it's declaration. It'll treat the prototype as being for
a different overloaded version of the function. |
allenhuffman
Posted: Thu Jan 30, 2020 9:33 am |
Ah, a difference because of the C++ stuff that has moved into C. That makes sense.
Is there any way to turn on "prototypes required" in this compiler? _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ? |
