Microchip Class B IEC60730 code implementation in CCS
mvanvliet
PostPosted: Fri Jan 24, 2020 9:37 am     Reply with quote
I'm trying to implement the Class B (IEC60730) files into a CCS program, I've eliminated most errors, but there are a few left which I can't solve. One of them is:
* © 2013 - 2014 Microchip Technology Inc.
* Project Name:     Class B Library
* FileName:         CLASSB_ClockTest.c
* Dependencies:     CLASSB_ClockTest.h
* Processor:        PIC16F1xxx
* Compiler:         XC8
* IDE:              MPLAB® IDE or MPLAB® X
* Description:     This file contains functions to check the MCU clock
*                  source.
 * MICROCHIP SOFTWARE NOTICE AND DISCLAIMER: You may use this software, and
 * any derivatives created by any person or entity by or on your behalf,
 * exclusively with Microchip's products in accordance with applicable
 * software license terms and conditions, a copy of which is provided for
 * your referencein accompanying documentation. Microchip and its licensors
 * retain all ownership and intellectual property rights in the
 * accompanying software and in all derivatives hereto.
 * This software and any accompanying information is for suggestion only.
 * It does not modify Microchip's standard warranty for its products. You
 * agree that you are solely responsible for testing the software and
 * determining its suitability. Microchip has no obligation to modify,
 * test, certify, or support the software.
 * THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
 * EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED
 * WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS FOR A
 * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE, ITS INTERACTION WITH
 * MICROCHIP'S PRODUCTS, COMBINATION WITH ANY OTHER PRODUCTS, OR USE IN ANY
 * APPLICATION.
 * IN NO EVENT, WILL MICROCHIP BE LIABLE, WHETHER IN CONTRACT, WARRANTY,
 * TORT (INCLUDING NEGLIGENCE OR BREACH OF STATUTORY DUTY), STRICT
 * LIABILITY, INDEMNITY, CONTRIBUTION, OR OTHERWISE, FOR ANY INDIRECT,
 * SPECIAL, PUNITIVE, EXEMPLARY, INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE,
 * FOR COST OR EXPENSE OF ANY KIND WHATSOEVER RELATED TO THE SOFTWARE,
 * HOWSOEVER CAUSED, EVEN IF MICROCHIP HAS BEEN ADVISED OF THE POSSIBILITY
 * OR THE DAMAGES ARE FORESEEABLE. TO THE FULLEST EXTENT ALLOWABLE BY LAW,
 * MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN ANY WAY RELATED TO THIS
 * SOFTWARE WILL NOT EXCEED THE AMOUNT OF FEES, IF ANY, THAT YOU HAVE PAID
 * DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
 * MICROCHIP PROVIDES THIS SOFTWARE CONDITIONALLY UPON YOUR ACCEPTANCE OF
 * THESE TERMS.
* REVISION HISTORY:
* Author            Date      Comments on this revision
* CT                09/15/2008  First release of source file
* Mike Cahill       11/11/2010   Updated for HI-TECH v9.80
* MVL               02/22/2011   Modified for HI-TECH v9.81
* Corey Simoncic    03/25/2013  Updated for XC-8 PRO v1.12
* Willem J Smit     10/20/2014  RamMarchBTest and RamCheckerBoardTest update
* Version       3.01
* ADDITIONAL NOTES:
#include "CLASSB_ClockTest.h"
uint16_t CLASSB_timerCount = 0;
uint16_t CLASSB_Clockcount = 0;
uint8_t CLASSB_TRISC_temp;
uint8_t CLASSB_INTCON_temp;
uint8_t CLASSB_T1CON_temp;
uint8_t CLASSB_PIE1_temp;
* Description:
*   The Clock test implements the independent time slot monitoring H.2.18.10.4
*   defined by the IEC 60730 standard. It verifies the reliability of the system
*   clock (i.e., the system clock should be neither too fast nor too slow)
* Input:
*   clockFrequency      - system clock frequency.
*   referenceFrequency  - reference clock frequency.
*   msec                - the time in milliseconds to run the test.
*   tolerance           - the tolerance level of the system oscillator.
* Return Values:
*     CLASSB_TEST_PASS    :  return value = 0
*     CLASSB_TEST_FAIL    :  return value = 1
CLASSBRESULT CLASSB_ClockTest(uint32_t clockFrequency, uint32_t referenceFrequency, size_t msec, uint8_t tolerance)
    uint32_t Clock_expectedCount;
    uint32_t Clock_toleranceCount;
    uint32_t systemFreq = clockFrequency/4;
    //SETUP
    CLASSB_ClockTestSetup();
    CLASSB_timerCount = ((uint32_t)msec*referenceFrequency)/1000; //number of expected reference counts
    if(CLASSB_timerCount == 0)
        CLASSB_timerCount = 1;
    Clock_expectedCount = 0;
    Clock_expectedCount = (uint16_t)(((systemFreq*msec)/1000)/CYCLES); //number of expected system counts
    Clock_toleranceCount = ((Clock_expectedCount*tolerance)/100);///CYCLES);
    //TMR1 = 0;
    set_timer1(0);
    CLASSB_ClockTestTimer();
    TMR1ON = 0;
    if(CLASSB_Clockcount == 0)
        CLASSB_ClockTestRestore();
        return CLASSB_TEST_TIMEOUT;
    if(CLASSB_Clockcount < (Clock_expectedCount - Clock_toleranceCount))
        return CLASSB_TEST_FAIL;
    if(CLASSB_Clockcount > (Clock_expectedCount + Clock_toleranceCount))
    return CLASSB_TEST_PASS;
void CLASSB_ClockTestTimer (void)
#asm
    TimerTest:
        BANKSEL (_CLASSB_timerCount)
        MOVF BANKMASK(_CLASSB_timerCount)+1,W
        BANKSEL TMR1H
        NOP
        SUBWF TMR1H,W
        BTFSS STATUS, 0x2
        GOTO IncCounter
        NOP
        NOP
        NOP
        NOP
//        NOP
        BANKSEL _CLASSB_timerCount
        MOVF BANKMASK(_CLASSB_timerCount),W
        BANKSEL TMR1L
        SUBWF TMR1L, W
        BTFSC STATUS, 0x0
        GOTO TimerTestEnd
    IncCounter:
        BANKSEL (_CLASSB_Clockcount)
        INCF BANKMASK(_CLASSB_Clockcount),F
        BTFSC STATUS, 0x2
        INCF BANKMASK(_CLASSB_Clockcount)+1,F
        GOTO TimerTest
    TimerTestEnd:
        RETURN
#endasm
void CLASSB_ClockTestSetup(void)
    //CLASSB_TRISC_temp = TRISC;
    CLASSB_INTCON_temp = INTCON;
    CLASSB_T1CON_temp = T1CON;
    CLASSB_PIE1_temp = PIE1;
    //TRISC0 = 1;
    //TRISC1 = 1;
    INTCON = 0;
    T1CON = 0b10001000;
    TMR1IF = 0;
    TMR1IE = 1;
    //TMR1 = 0xFE00;
    set_timer1(0xFE00);
    TMR1ON = 1;
    while(!TMR1IF);
    TMR1IE = 0;
    TMR1IF = 0;
void CLASSB_ClockTestRestore(void)
    //TRISC = CLASSB_TRISC_temp;
    INTCON = CLASSB_INTCON_temp;
    T1CON = CLASSB_T1CON_temp;
    PIE1 = CLASSB_PIE1_temp;
Gives Error 95 on BANKSEL (_CLASSB_timerCount)
I don't know how to solve this, does anyone know?
PostPosted: Fri Jan 24, 2020 10:03 am     Reply with quote
I had a quick look......
I didn't see where this variable
_CLASSB_timerCount
is defined or created ??
There is this one.
but I seriously doubt you'd need 16 bits for 'bank selection' though without knowing what PIC is being used, hard to say....
Have to 'chuckle' about a computer testing itself for accurate speed...
PostPosted: Fri Jan 24, 2020 12:08 pm     Reply with quote
The CCS compiler automatically handles bank selection within an #asm
block. You don't have to do it. In the test program farther below, I create
a variable and assign its address as 0x300 in RAM. Notice in the .LST file
below, the compiler has inserted a MOVLB instruction to set the bank at 3:
.................... #asm
.................... MOVWF MyVar
00036: MOVLB 3
00038: MOVWF MyVar
0003A: MOVLB 0
.................... #endasm
Test program:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#include <stdint.h>
uint8_t MyVar = 0;
#locate MyVar = 0x300
#asm
MOVWF MyVar
#endasm
while(TRUE);
mvanvliet
PostPosted: Wed Jan 29, 2020 2:56 am     Reply with quote
@temtronic: As I've read the underscore is to switch from C to ASM with the same variable in the Microchip XC8 compiler. It is defined as uint16_t CLASSB_timerCount = 0;
@PCMprogrammer: So I need to remove the Banksel code and then the compiler should assign it to the correct bank or do I need to add the #locate code?
In this code I've removed the BANKSEL and changed the BANKMASK sentences, could this be working:
#asm
    TimerTest:
        //BANKSEL (_CLASSB_timerCount)
        MOVF CLASSB_timerCount+1,W
        //BANKSEL TMR1H
        NOP
        SUBWF TMR1H,W
        BTFSS STATUS, 0x2
        GOTO IncCounter
        NOP
        NOP
        NOP
        NOP
//        NOP
        //BANKSEL _CLASSB_timerCount
        MOVF CLASSB_timerCount,W
        //BANKSEL TMR1L
        SUBWF TMR1L, W
        BTFSC STATUS, 0x0
        GOTO TimerTestEnd
    IncCounter:
        //BANKSEL (_CLASSB_Clockcount)
        INCF CLASSB_Clockcount,F
        BTFSC STATUS, 0x2
        INCF CLASSB_Clockcount+1,F
        GOTO TimerTest
    TimerTestEnd:
        RETURN
#endasm
PostPosted: Wed Jan 29, 2020 3:29 am     Reply with quote
Yes, I compiled that code and looked at the .LST file, and it looks good.
The compiler inserts bank select instructions in the correct places.
The #locate code is put in there for my test. You don't normally use #locate.
Your code does not need it.
mvanvliet
PostPosted: Wed Jan 29, 2020 4:37 am     Reply with quote
Thanks for your reaction. Most of the errors I receive now are the ones for the function below.
The errors for EEADR and PMADR have I solved to add
#byte EEADR = getenv("DATA_EEPROM")
#byte PMADR = getenv("PROGRAM_MEMORY")
in the main .c program, is that correct?
But how to solve the PMCON bits? I can find CFGS and RD in the EECON1 register, but if the PIC doesn't have an EEPROM these bits are not used. So I don't know which they mean.
* Description:
*     This function reads the flash at the startAddress.
* Input:
*     addr      :  the address of the flash memory to be tested
* Returns:
*     EEDAT     :  The data in the flash address of addr
uint16_t CLASSB_flashRead(uint16_t addr)
#ifdef _EECON1_RD_POSN //this will decide between EECON or PMCON for devices without EEPROM
    EEADR = addr;
    EECON1bits.CFGS = 0;    // Do not select Configuration Space
    EECON1bits.EEPGD = 1;   // Do select Program Memory
    EECON1bits.RD = 1;      // Initiate read
    #asm
    NOP                  //
    NOP                  //
    #endasm
    return EEDAT;
#else
    PMADR = addr;
    PMCON1bits.CFGS = 0;    // Do not select Configuration Space
    PMCON1bits.RD = 1;      // Initiate read
    #asm
    NOP                  //
    NOP                  //
    #endasm
    return PMDAT;
#endif
PostPosted: Wed Jan 29, 2020 5:12 am     Reply with quote
What processor?.
On some processors these bits are in the PMCON register instead of
EECON. The switch for this is controlled by 'EECON1_RD_POSN'.
If these are not in your EECON1 register, you need to #define
EECON1_RD_POSN, and use the PMCON register instead.
mvanvliet
PostPosted: Wed Jan 29, 2020 5:13 am     Reply with quote
The processor I would like to use for the Class B test is 16F15313 (which has CRC), which doesn't have an eeprom.
On the 16F1824 (which I've used in the past) these EEPROM register bits are findable.
Do you have a type in mind which do have the PMCON register? So I can check the datasheet.
PostPosted: Wed Jan 29, 2020 6:18 am     Reply with quote
I was thinking about this code over the weekend...
comment.
You are aware that you'll have to compare the CCS version of the assembled code of this function to the original ?
It appears this is the actual 'timer test', so every line of code has to be the same, otherwise the 'timing' will be incorrect.
Jay
