I want to get the sine wave using excel.
ertansuluagac
PostPosted: Thu Dec 26, 2019 9:21 am     Reply with quote
hello everyone.
PIC16F1784 dac output from I want to get the sine wave using excel.
How can I do?
The outputs for the sine wave was calculated as follows, the values were rounded to the nearest integer value:
#define WAVE_POINTS 100
DEGREE_INC_VALUE = 360 / WAVE_POINTS = 360 / 100 =
DEGREE_INC_VALUE = 3.6
For outputs 0 - 99:
Output[i] = (DAC_MAX_VALUE / 2) (sin(i * DEGREE_INC_VALUE) + 1)
Es
PostPosted: Thu Dec 26, 2019 10:02 am     Reply with quote
One way is to send the data as 'CSV' (Comma Separated Variables) to a PC terminal program and have it save to a file (maybe named 'DACoutput.CSV')
You then open Excel and import' 'DACoutput.CSV'.
The numbers wll 'magically' be put into a spreadsheet.
You should also send 'start of data', 'end of data' markers just so you know all data is sent.
Jay
ertansuluagac
PostPosted: Thu Dec 26, 2019 10:38 am     Reply with quote
ex_sine.c in made in this sample from ccs .how these values are formed. and how it applies to Excel.
BYTE CONST SINE_WAVE[200] = {
128,132,136,139,143,147,150,154,158,161,165,169,172,176,179,
182,186,189,192,195,199,202,204,207,210,213,215,218,220,223,
225,227,229,231,233,235,237,238,240,241,242,243,244,245,246,
247,247,247,248,248,248,248,248,247,247,247,246,245,244,243,
242,241,240,238,237,235,233,231,229,227,225,223,220,218,215,
213,210,207,204,202,199,195,192,189,186,182,179,176,172,169,
165,161,158,154,150,147,143,139,136,132,128,124,120,117,113,
109,106,102,98,95,91,87,84,80,77,74,70,67,64,61,57,54,52,49,
46,43,41,38,36,33,31,29,27,25,23,21,19,18,16,15,14,13,12,11,
10,9,9,9,8,8,8,8,8,9,9,9,10,11,12,13,14,15,16,18,19,21,23,
25,27,29,31,33,36,38,41,43,46,49,52,54,57,61,64,67,70,74,77,
80,84,87,91,95,98,102,106,109,113,117,120,124};
Es
PostPosted: Thu Dec 26, 2019 12:31 pm     Reply with quote
here's what I think
1st sine waves are AC( + and - values) , PIC DAC is DC ( +ve only)
Those numbers represent an 'offset' sine wave broken into 200 points. So 360* / 200 = 1.8* ( * means degrees) uisng 8 bit 'math'.
The numbers are unsigned integers ( 0 - 255)
'128' is the middle and so represents the 'zero' voltage line
'248' represent the maximum positive level
'8' represents the maximum negative level
The more 'points', the smoother the sinewave will be,but requires more time to create it. Usually you add an R-C filter to the DAC output and you'll get a very nice 'sine' wave. Using a 16 or 32bit DAC will result in an even better 'sine wave' but costs more money in hardware.
Others will reply,hopefully with better explanations.
Jay
ertansuluagac
PostPosted: Thu Dec 26, 2019 1:03 pm     Reply with quote
how do i apply these values to excel. I want to see the sinus wave in excel.
Es
ertansuluagac
PostPosted: Thu Dec 26, 2019 1:24 pm     Reply with quote
how create this values.
const int8 sine_output[WAVE_POINTS] = {128, 136, 143, 151, 159, 167, 174, 182, 189, 196,
                                       202, 209, 215, 220, 226, 231, 235, 239, 243, 246,
                                       249, 251, 253, 254, 255, 255, 255, 254, 253, 251,
                                       249, 246, 243, 239, 235, 231, 226, 220, 215, 209,
                                       202, 196, 189, 182, 174, 167, 159, 151, 143, 136,
                                       128, 119, 112, 104,  96,  88,  81,  73,  66,  59,
                                        53,  46,  40,  35,  29,  24,  20,  16,  12,   9,
                                         6,   4,   2,   1,   0,   0,   0,   1,   2,   4,
                                         6,   9,  12,  16,  20,  24,  29,  35,  40,  46,
                                        53,  59,  66,  73,  81,  88,  96, 104, 112, 119};
Es
PostPosted: Thu Dec 26, 2019 1:37 pm     Reply with quote
Go here to learn how to create a graph in Excel.
https://www.workzone.com/blog/how-to-make-a-graph-in-excel/
Using that info it took me 5 minutes to create the graph using your data.
I saved the values to a CSV file (with no CRLFs except at the end) then opened the file in Excel which created one row of data.
I then used Insert Graph and selected the data to create the graph of a clean sine wave.
ertansuluagac
PostPosted: Thu Dec 26, 2019 2:05 pm     Reply with quote
using these values I see the sine wave. How do I make these values. so , this numbers how can create?
how these numbers are calculated. I wrote a formula above. I think when I apply this formula to excel, these numbers occur. te te how do I apply that formula to excel.
this formula;
For outputs 0 - 99:
Es
ertansuluagac
PostPosted: Fri Dec 27, 2019 12:50 am     Reply with quote
does anyone know how it occurs these values?
yes, from excel in these values very beautiful sinus waves see. but, how it occurs these values
Es
ertansuluagac
PostPosted: Fri Dec 27, 2019 2:52 am     Reply with quote
[SOLVED]
the problem is solved.
thanks
Es
