georpo
Joined: 18 Nov 2008 Posts: 278 Location: Athens, Greece.
call function with const tables. |
Posted: Wed Jul 10, 2019 11:03 pm |
Hi all!
I am using an oled with fonts created with "TheDotFactory".
Then I set/clear the pixels with my custom code:
void OledText(int TextX,int TextY,int Size){
int Character=0,Offset=0,Width=0,Height=0,S=0,E=0,p=0;
int BitComp=0;
while(TextBuffer[p]){
Character=TextBuffer[p++];
Character-=32;
if(Size==1){
Width=arialUnicodeMS_8ptDescriptors[Character][0];
Height=arialUnicodeMS_8ptDescriptors[Character][1];
Offset=arialUnicodeMS_8ptDescriptors[Character][2];
if(Size==2){
Width=arialUnicodeMS_10ptDescriptors[Character][0];
Height=arialUnicodeMS_10ptDescriptors[Character][1];
Offset=arialUnicodeMS_10ptDescriptors[Character][2];
if(Size==3){
Width=arialUnicodeMS_12ptDescriptors[Character][0];
Height=arialUnicodeMS_12ptDescriptors[Character][1];
Offset=arialUnicodeMS_12ptDescriptors[Character][2];
if(Size==4){
Width=arialUnicodeMS_14ptDescriptors[Character][0];
Height=arialUnicodeMS_14ptDescriptors[Character][1];
Offset=arialUnicodeMS_14ptDescriptors[Character][2];
if(Size==5){
Width=arialUnicodeMS_16ptDescriptors[Character][0];
Height=arialUnicodeMS_16ptDescriptors[Character][1];
Offset=arialUnicodeMS_16ptDescriptors[Character][2];
BitComp=1;
for(S=0;S<Height;++S){ //Do 'Height' vertical pixels
for(E=0;E<Width;++E){ //Do 'width' horizontal pixels
if(Size==1){
if(arialUnicodeMS_8ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
else ClearPixel(TextX+E,TextY+S);
if(Size==2){
if(arialUnicodeMS_10ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
if(Size==3){
if(arialUnicodeMS_12ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
if(Size==4){
if(arialUnicodeMS_14ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
if(Size==5){
if(arialUnicodeMS_16ptBitmaps[Offset+E]&BitComp) SetPixel(TextX+E,TextY+S);
} //Finished 1 line of pixels
ClearPixel(TextX+E,TextY+S); //Clear 1 pixel to delete previous content.Related to 1 pixel space below
BitComp*=2; // Move to Higher bit for next compare
if(BitComp>128){
BitComp=1; //Reset comparison to lowest bit
Offset+=Width; //and move to next set of bytes
} //finished 1 character
TextX+=Width+1; //increment X by last character width +1 pixel space
I will need to add more fonts, so is there any more efficient way instead of all those "IFs"?
Thanks for any feedback! _________________ George. |
allenhuffman
Joined: 17 Jun 2019 Posts: 540 Location: Des Moines, Iowa, USA
Posted: Fri Jul 12, 2019 10:38 am |
You might consider making it table driven. What data type are the "arialUnicodeMS_8ptDescriptors" things?
You'd have a structure that contains the Size you want to look up, and the addresses of each of your fonts. Something like this:
typedef struct
int Size;
int8 *FontPtr; // Whatever your font type is
} FontInfoStruct;
FontInfoStruct FontInfo[] =
// Size Font
{ 1, arialUnicodeMS_8ptDescriptors },
{ 2, arialUnicodeMS_10ptDescriptors },
{ 3, arialUnicodeMS_12ptDescriptors },
{ 4, arialUnicodeMS_14ptDescriptors },
{ 5, arialUnicodeMS_16ptDescriptors },
{ 0, 0 } // End of Table
Then you could just loop through that table looking for the matching size, and when you find it, you also have the address for the font structure you want to use. Something like this:
// Size is your target size
// Character is your character
int Width, Height, Offset;
Width = 0;
Height = 0;
Offset = 0;
int Entry = 0;
do
if (FontInfo[Entry].Size == Size)
Width = FontInfo[Entry].FontPtr[Character][0];
Height = FontInfo[Entry].FontPtr[Character][1];
Offset = FontInfo[Entry].FontPtr[Character][2];
Entry++;
} while (FontInfo[Entry].Size != 0);
printf( "Size: %u Character: %u Width: %u Height %u Offset: %u\r\n",
Size, Character, Width, Height, Offset);
This is just pseudo code to give you an idea of what I mean. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ? |
