PIC16F18875 - Strange Problem with TIMER 1 setup
PAPA
PostPosted: Thu Jun 27, 2019 12:52 pm     Reply with quote
Hello All,
I need some help.
I have a problem when I try to setup the timer 1 using the SETUP_TIMER1() function and also when I try to write the memory register.
When I start the PIC microcontroller the CPU blocks and the code inside the while(true) is not executed. If I comment the Setup_Timer1() the CPU doesn´t block but the timer interrupt is not executed as I wanted.
CCS compiler version: 5.073
Code using the SETUP_TIMER1:
#include <16F18875.h>
#device ADC=10
#FUSES NOBROWNOUT
#FUSES NOLVP
#FUSES HS
#FUSES NOWDT
#use delay(crystal=10000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#pin_select U1TX=PIN_C6
#pin_select U1RX=PIN_C7
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
#define LEDRED    PIN_C1
int aux=0;
#INT_RDA
void trata_INT_RDA()
  output_toggle(LEDYEL);
#INT_TIMER1
void trata_1()
aux++;
if(aux>10)
   output_toggle(LEDRED);
   aux=0;
set_timer1(3036);
  set_tris_a(0b10110011);
  set_tris_b(0b00110010);
  set_tris_c(0b10101100);
  set_tris_d(0b10001011);
  set_tris_e(0b00000110);
  setup_adc(ADC_CLOCK_DIV_8);
  setup_adc_ports(sAN0 | sAN1 | sAN9 | sAN12 | sAN13 | sAN21 | 0x00000008 | 0x00000080); //A0 A1 B1 B4 B5 C5 D3 D7
  SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_4);
  SET_TIMER1(3036);
  enable_interrupts(INT_RDA);
  enable_interrupts(global);
      //TODO: User Code
Code for configure the Timer1 writing the memory register
#device ADC=10
#FUSES NOBROWNOUT
#FUSES NOLVP
#FUSES HS
#FUSES NOWDT
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#byte T1CON = 0x20E    //For Register configuration
#byte T1CLK = 0x211
int aux=0;
#INT_RDA
#INT_TIMER1
void trata_1()
aux++;
if(aux>10)
   aux=0;
set_timer1(3036);
  T1CON = 0b00100011;     // T1_INTERNAL | T1_DIV_BY_4
  T1CLK = 0b00000001;     //Fosc/4
  SET_TIMER1(3036);
      //TODO: User Code
Thanks in advanced
Always looking to the future
PostPosted: Thu Jun 27, 2019 5:47 pm     Reply with quote
You need to fix this:
#INT_RDA
You must get the character in the interrupt.
As a bare minimum, you need to do this:
  int8 c;
  c = fgetc(PORT1);
This will throw away the character after getting it, but at least your
program will not lock up.
Also, you should add the ERRORS parameter to your #use rs232()
statement.
PAPA
PostPosted: Fri Jun 28, 2019 1:52 am     Reply with quote
#INT_RDA
  int8 c;
  c = fgetc(PORT1);
statement.
I noticed that mistakes but the main problem is relate with the timer 1 setup that after configuration the PIC blocks and nothing happen, the function inside the while (true) is not executed.
Are there any special bits configuration for the timer 1 in this PIC?
PostPosted: Fri Jun 28, 2019 2:28 am     Reply with quote
I would have install your version, 5.073, which is about 2 years old and
look at the .LST file. I can do that tomorrow.
PAPA
PostPosted: Fri Jun 28, 2019 5:04 am     Reply with quote
I've tested the timer 0, and to put it works properly I needed to enable interrupts Peripheral.
But with timer1 the problem persist.
I don´t know if it can help, but below you can see some of the .lst output
....................   setup_timer_1(T1_INTERNAL | T1_DIV_BY_4 );  //16bits
086B:  MOVLW  01
086C:  MOVLB  04
086D:  MOVWF  11
086E:  MOVLW  27
086F:  MOVWF  0E
0870:  CLRF   0F
0871:  CLRF   10
....................   SET_TIMER1(3036);
0872:  CLRF   0C
0873:  MOVLW  0B
0874:  MOVWF  0D
0875:  MOVLW  DC
0876:  MOVWF  0C
....................   enable_interrupts(INT_TIMER1);
0877:  MOVLB  0E
0878:  BSF    1A.0
....................   enable_interrupts(INT_RDA);
0879:  BSF    19.5
....................   enable_interrupts(global);
087A:  MOVLW  C0
087B:  IORWF  0B,F
....................   enable_interrupts(PERIPH);
087C:  BSF    0B.6
PostPosted: Fri Jun 28, 2019 7:51 am     Reply with quote
sigh...
this ... enable interrupts Peripheral...
... must be a 'new' PIC thing.
gets me wondering if there's more than one 'enable interrupts Peripheral.' command needed, as an SFR holds 8 bit , what if there's 10 peripherals ?
guess I'm getting cynical in my old age...
Jay
dluu13
PostPosted: Fri Jun 28, 2019 8:18 am     Reply with quote
Hmmm, I don't recall ever doing any enable_interrupts(PERIPH). I assume that's the PEIE bit in INTCON. Looks like it's a "global peripherals enable" kind of bit.
I used PIC16F1939 and PIC16F19175/76 which at a cursory glance appears to have the same interrupt structure. It appears to need PEIE = 1 even though I never set that bit before. It could be that the compiler automatically sets that, so I never paid attention.
PostPosted: Fri Jun 28, 2019 4:07 pm     Reply with quote
I installed CCS vs. 5.085 and compiled the first program posted.
It works. It blinks the two LEDs at different rates. The Timer1 blinks
at an apparent rate of about 1/2 Hz. It's on for roughly 1 second and off
for roughly 1 second.
I will now check it with vs. 5.073. This is a 2-year old version of the compiler.
PAPA
PostPosted: Fri Jun 28, 2019 5:28 pm     Reply with quote
yes, that is how the program works.
It seems to be some problem with the compiler version, I look forward your test results and possible solutions to handle it.
PostPosted: Sat Jun 29, 2019 3:12 am     Reply with quote
Vs. 5.073 doesn't clear the Timer1 interrupt flag when it exits the isr.
Instead it clears bit 0 in PortE. This is caused by an incorrect bank
selection. To fix it, you can add the line shown below. But the CCS code
will still be write a 0 to bit 0 of Port E. That bug is still there.
#INT_TIMER1
void trata_1()
aux++;
if(aux>10)
aux=0;
set_timer1(3036);
clear_interrupt(INT_TIMER1);
There are probably more bugs. I suggest you upgrade your compiler.
PAPA
PostPosted: Sat Jun 29, 2019 6:43 am     Reply with quote
#INT_TIMER1
void trata_1()
aux++;
if(aux>10)
aux=0;
set_timer1(3036);
Thank you for your help, I'll consider your suggestion.
