frequency measuring
ertansuluagac
frequency measuring
PostPosted: Wed Jun 26, 2019 8:00 am     Reply with quote
Hello there,
1- I want to something ask. I want to measure the frequency with the incoming pulse.
2- Can I measure frequency directly from an inside ?
I using microprocessor dsPIC33EP256MC502. I using crystal 16mhz with clock 120mhz.
Es
gaugeguy
PostPosted: Wed Jun 26, 2019 8:30 am     Reply with quote
What is the frequency range of the signal you want to measure?
Will the signal be conditioned to a square wave input 0-VDD?
ertansuluagac
PostPosted: Wed Jun 26, 2019 8:34 am     Reply with quote
I do not know that. It is flow meter. I will calculate according to the incoming pulse. I only get a pulse from a Vout. This is constantly changing. So I can't say anything clear.
Es
PostPosted: Wed Jun 26, 2019 8:57 am     Reply with quote
'Flow meters' tend to be low frequency devices though the mfr of it will have charts/data of flow rate vs frequency (PPS). Even the cheap ones from China have data on the website. There will be a relationship of volume of water to pulse (1 revolution) so you could create an ISR to count pulses and calculate both flow and volume.
Jay
Mike Walne
PostPosted: Wed Jun 26, 2019 3:58 pm     Reply with quote
Have a look at your input pulse with a 'scope. If it's not close to being a 0 to Vdd square wave then you will need to process it.
There are two general ways of measuring frequency:-
1) Count the No. of pulses in a fixed time (say 1s).
2) Measure the period of one (or several) pulse(s) and convert.
For a flow meter you will probably use the 2nd method.
Mike
