soonc
IDE Reset bookmarks |
Posted: Fri Jun 07, 2019 9:36 am |
Does anyone know: How can I reset all bookmarks in the PCWHD IDE ?
If I close a file and open a different file the bookmarks are still referencing the closed file!
This gets really confusing when running two instances of the IDE.
Thanks |
Posted: Fri Jun 07, 2019 10:02 am |
On the toolbar at the top. Search.
Then you should have two buttons shown, for 'toggle' and 'goto'.
On the right of the toggle button, there is a small arrow. Click on it.
Bottom of the box that drops down, there is a tab 'Remove All'.
The same tab is available if you right click on the page, and again
select 'Toggle Bookmark'. |
soonc
Not on menu |
Posted: Fri Jun 07, 2019 1:06 pm |
Ttelmah wrote: | On the toolbar at the top. Search.
Thanks... I don't use the toolbar as it eats too much space.
I don't normally use the menu for bookmarks just the keyboard.
It is there under "Edit/Toggle" the bottom of the sub menu but has not Keys assigned to it.
I assigned Ctrl+Alt+R, that works.
Thanks for the help. |
Posted: Fri Jun 07, 2019 10:16 pm |
Must admit 'not exactly obvious'....
Glad you have it sorted. |
