Large Descriptor
vtrx
Large Descriptor
PostPosted: Tue May 21, 2019 9:08 am     Reply with quote
What do I need to change to use a descriptor greater than 255 bytes?
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines the size of that descriptor.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][3] =
   //config 1
      //interface 0
       63,
      //interface 1
       32,
      //interface 2
       >256//large descriptor part here
I want to try to implement force feedback.
PostPosted: Tue May 21, 2019 10:42 am     Reply with quote
Er. You can't.
The first byte of a USB descriptor, is it's length. A one byte value.
So all USB descriptors are inherently limited to 255 bytes or less.
(since this can only give 1 to 255 as a length).
Why on earth do you think force feedback requires a > 255 byte descriptor?.
<https://www.microchip.com/forums/m958105.aspx>
vtrx
PostPosted: Tue May 21, 2019 11:34 am     Reply with quote
0x05,0x01, // Usage Page Generic Desktop
 0x09,0x04, // Usage Joystick
 0xA1,0x01, // Collection Application
    0x85,0x01, // Report ID 1
0x05,0x09, // [0x03]USAGE PAGE (BUTTON)
0x19,0x01, // [0x04]USAGE_MINIMUM(BUTTON 1)
0x29,0x10, // [0x05]USAGE_MAXIMUM(BUTTON 16)
0x15,0x00, // [0x06]LOGICAL_MINIMUM
0x25,0x01, // [0x07]LOGICAL_MAXIMUM
0x35,0x00, // [0x08]PHYSICAL_MINIMUM
0x45,0x01, // [0x09]PHYSICAL_MAXIMUM
0x75,0x01, // [0x0A]REPORT_SIZE
0x95,0x10, // [0x0B]REPORT_COUNT
0x81,0x02, // [0x0C]INPUT
0x05,0x01, // [0x0D]USAGE PAGE (GENERIC DESKTOP CONTROLS)
0x09,0x39, // [0x0E]USAGE(HAT_SWITCH)
0x15,0x00, // [0x0F]LOGICAL_MINIMUM
0x25,0x07, // [0x10]LOGICAL_MAXIMUM
0x35,0x00, // [0x11]PHYSICAL_MINIMUM
0x46,0x3B,0x01, // [0x12]PHYSICAL_MAXIMUM
0x65,0x14, // [0x13]UNIT
0x75,0x04, // [0x14]REPORT_SIZE
0x95,0x01, // [0x15]REPORT_COUNT
0x81,0x42, // [0x16]INPUT
0x65,0x00, // [0x17]UNIT
0x95,0x01, // [0x18]REPORT_COUNT
0x81,0x01, // [0x19]INPUT
0x09,0x30, // [0x1A]USAGE(X)
0x09,0x31, // [0x1B]USAGE(Y)
0x09,0x32, // [0x1C]USAGE(Z)
0x09,0x33, // [0x1D]USAGE(Rx)
0x15,0x00, // [0x1E]LOGICAL_MINIMUM
0x26,0x00,0x04, // [0x1F]LOGICAL_MAXIMUM
0x35,0x00, // [0x20]PHYSICAL_MINIMUM
0x46,0x00,0x04, // [0x21]PHYSICAL_MAXIMUM
0x75,0x10, // [0x22]REPORT_SIZE
0x95,0x04, // [0x23]REPORT_COUNT
0x81,0x02, // [0x24]INPUT
  Input
  Collection Datalink (sub-collection)
  Physical Interface (Usage: PID State report)
  state report: 5X1bit
  Padding: 3bit
  PID Device Control: 1bit
  Effect Block Index: 7bit
    0x05,0x0F, // Usage Page Physical Interface
    0x09,0x92, // Usage PID State report
    0xA1,0x02, // Collection Datalink (logical)
       0x85,0x02, // Report ID 2
       0x09,0x9F, // Usage Device is Pause
       0x09,0xA0, // Usage Actuators Enabled
       0x09,0xA4, // Usage Safety Switch
       0x09,0xA5, // Usage Actuator Override Switch
       0x09,0xA6, // Usage Actuator Power
       0x15,0x00, // Logical Minimum 0
       0x25,0x01, // Logical Maximum 1
       0x35,0x00, // Physical Minimum 0
       0x45,0x01, // Physical Maximum 1
       0x75,0x01, // Report Size 1
       0x95,0x05, // Report Count 5
       0x81,0x02, // Input (Variable)
       0x95,0x03, // Report Count 3
       0x81,0x03, // Input (Constant, Variable)
       0x09,0x94, // Usage Effect Playing
       0x95,0x01, // Report Count 1
       0x09,0x22, // Usage Effect Block Index
       0x15,0x01, // Logical Minimum 1
       0x25,0x28, // Logical Maximum 28h (40d)
       0x35,0x01, // Physical Minimum 1
       0x45,0x28, // Physical Maximum 28h (40d)
       0x75,0x07, // Report Size 7
    0xC0 , // End Collection
  Output
  Collection Datalink:
  Usage Set Effect Report
  Effect Block Index: 8bit
  subcollection Effect Type
  12 effect types, 8bit each
    0x09,0x21, // Usage Set Effect Report
    0xA1,0x02, // Collection Datalink (Logical)
       0x75,0x08, // Report Size 8
       0x91,0x02, // Output (Variable)
       0x09,0x25, // Usage Effect Type
          0x09,0x26, // Usage ET Constant Force
          0x09,0x27, // Usage ET Ramp
          0x09,0x30, // Usage ET Square
          0x09,0x31, // Usage ET Sine
          0x09,0x32, // Usage ET Triangle
          0x09,0x33, // Usage ET Sawtooth Up
          0x09,0x34, // Usage ET Sawtooth Down
          0x09,0x40, // Usage ET Spring
          0x09,0x41, // Usage ET Damper
          0x09,0x42, // Usage ET Inertia
          0x09,0x43, // Usage ET Friction
          0x09,0x28, // Usage ET Custom Force Data
          0x25,0x0C, // Logical Maximum Ch (12d)
          0x45,0x0C, // Physical Maximum Ch (12d)
          0x91,0x00, // Output
       0x09,0x50, // Usage Duration
       0x09,0x54, // Usage Trigger Repeat Interval
       0x09,0x51, // Usage Sample Period
       0x26,0xFF,0x7F, // Logical Maximum 7FFFh (32767d)
       0x46,0xFF,0x7F, // Physical Maximum 7FFFh (32767d)
       0x66,0x03,0x10, // Unit 1003h (4099d)
       0x55,0xFD, // Unit Exponent FDh (253d)
       0x75,0x10, // Report Size 10h (16d)
       0x55,0x00, // Unit Exponent 0
       0x66,0x00,0x00, // Unit 0
       0x09,0x52, // Usage Gain
       0x26,0xFF,0x00, // Logical Maximum FFh (255d)
       0x46,0x10,0x27, // Physical Maximum 2710h (10000d)
       0x09,0x53, // Usage Trigger Button
       0x25,0x08, // Logical Maximum 8
       0x45,0x08, // Physical Maximum 8
       0x09,0x55, // Usage Axes Enable
          0x09,0x30, // Usage X
          0x09,0x31, // Usage Y
          0x95,0x02, // Report Count 2
       0x09,0x56, // Usage Direction Enable
       0x91,0x03, // Output (Constant, Variable)
       0x09,0x57, // Usage Direction
          0x0B,0x01,0x00,0x0A,0x00, // Usage Ordinals: Instance 1
          0x0B,0x02,0x00,0x0A,0x00, // Usage Ordinals: Instance 2
          0x66,0x14,0x00, // Unit 14h (20d)
          0x55,0xFE, // Unit Exponent FEh (254d)
          0x47,0xA0,0x8C,0x00,0x00, // Physical Maximum 8CA0h (36000d)
       0x09,0xA7, // Usage Undefined
    0x09,0x5A, // Usage Set Envelope Report
       0x09,0x5B, // Usage Attack Level
       0x09,0x5D, // Usage Fade Level
       0x09,0x5C, // Usage Attack Time
       0x09,0x5E, // Usage Fade Time
       0x45,0x00, // Physical Maximum 0
    0x09,0x5F, // Usage Set Condition Report
       0x85,0x03, // Report ID 3
       0x09,0x23, // Usage Parameter Block Offset
       0x75,0x04, // Report Size 4
       0x09,0x58, // Usage Type Specific Block Off...
          0x75,0x02, // Report Size 2
       0x15,0x80, // Logical Minimum 80h (-128d)
       0x25,0x7F, // Logical Maximum 7Fh (127d)
       0x36,0xF0,0xD8, // Physical Minimum D8F0h (-10000d)
       0x09,0x60, // Usage CP Offset
       0x09,0x61, // Usage Positive Coefficient
       0x09,0x62, // Usage Negative Coefficient
       0x09,0x63, // Usage Positive Saturation
       0x09,0x64, // Usage Negative Saturation
       0x09,0x65, // Usage Dead Band
    0x09,0x6E, // Usage Set Periodic Report
       0x85,0x04, // Report ID 4
       0x09,0x70, // Usage Magnitude
       0x09,0x6F, // Usage Offset
       0x09,0x71, // Usage Phase
       0x09,0x72, // Usage Period
    0x09,0x73, // Usage Set Constant Force Rep...
       0x85,0x05, // Report ID 5
       0x16,0x01,0xFF, // Logical Minimum FF01h (-255d)
    0x09,0x74, // Usage Set Ramp Force Report
       0x85,0x06, // Report ID 6
       0x09,0x75, // Usage Ramp Start
       0x09,0x76, // Usage Ramp End
    0x09,0x68, // Usage Custom Force Data Rep...
       0x85,0x07, // Report ID 7
       0x09,0x6C, // Usage Custom Force Data Offset
       0x26,0x10,0x27, // Logical Maximum 2710h (10000d)
       0x09,0x69, // Usage Custom Force Data
       0x15,0x81, // Logical Minimum 81h (-127d)
       0x46,0xFF,0x00, // Physical Maximum FFh (255d)
       0x95,0x0C, // Report Count Ch (12d)
       0x92,0x02,0x01, // Output (Variable, Buffered)
    0x09,0x66, // Usage Download Force Sample
       0x85,0x08, // Report ID 8
    0x09,0x77, // Usage Effect Operation Report
       0x85,0x0A, // Report ID Ah (10d)
       0x09,0x78, // Usage Effect Operation
          0x09,0x79, // Usage Op Effect Start
          0x09,0x7A, // Usage Op Effect Start Solo
          0x09,0x7B, // Usage Op Effect Stop
          0x25,0x03, // Logical Maximum 3
       0x09,0x7C, // Usage Loop Count
    0x09,0x90, // Usage PID Block Free Report
       0x85,0x0B, // Report ID Bh (11d)
    0x09,0x96, // Usage PID Device Control
       0x85,0x0C, // Report ID Ch (12d)
       0x09,0x97, // Usage DC Enable Actuators
       0x09,0x98, // Usage DC Disable Actuators
       0x09,0x99, // Usage DC Stop All Effects
       0x09,0x9A, // Usage DC Device Reset
       0x09,0x9B, // Usage DC Device Pause
       0x09,0x9C, // Usage DC Device Continue
       0x25,0x06, // Logical Maximum 6
    0x09,0x7D, // Usage Device Gain Report
       0x85,0x0D, // Report ID Dh (13d)
       0x09,0x7E, // Usage Device Gain
    0x09,0x6B, // Usage Set Custom Force Report
       0x85,0x0E, // Report ID Eh (14d)
       0x09,0x6D, // Usage Sample Count
    0x09,0xAB, // Usage Create New Effect Report
       0xB1,0x00, // Feature
    0x09,0x3B, // Usage Reserved
    0x26,0xFF,0x01, // Logical Maximum 1FFh (511d)
    0x46,0xFF,0x01, // Physical Maximum 1FFh (511d)
    0x75,0x0A, // Report Size Ah (10d)
    0xB1,0x02, // Feature (Variable)
    0x75,0x06, // Report Size 6
    0xB1,0x01, // Feature (Constant)
 0x09,0x89, // Usage Block Load Status
    0x09,0x8B, // Usage Block Load Status
       0x09,0x8C, // Usage Block Load Success
       0x09,0x8D, // Usage Block Load Full
       0x09,0x8E, // Usage Block Load Error
       0x45,0x03, // Physical Maximum 3
    0x09,0xAC, // Usage Undefined
    0x27,0xFF,0xFF,0x00,0x00, // Logical Maximum FFFFh (65535d)
    0x47,0xFF,0xFF,0x00,0x00, // Physical Maximum FFFFh (65535d)
 0x09,0x7F, // Usage PID Pool Report
    0x09,0x80, // Usage RAM Pool size
    0x09,0x83, // Usage Simultaneous Effects Max
    0x09,0xA9, // Usage Device Managed Pool
    0x09,0xAA, // Usage Shared Parameter Blocks
    0xB1,0x03, // Feature (Constant, Variable)
    0xC0, // End Collection
 0xC0 // End Collection
Reference;
PostPosted: Tue May 21, 2019 2:00 pm     Reply with quote
If you look at the code you are copying from, the descriptor size is just
64bytes. The big block is the report.
vtrx
PostPosted: Tue May 21, 2019 2:22 pm     Reply with quote
Is it possible to implement this example with CCS?
PostPosted: Tue May 21, 2019 2:57 pm     Reply with quote
yes, you can though I can't help as I stay away from USB...too dang slow, too complicated and NOT interrupt driven.
PostPosted: Wed May 22, 2019 12:49 am     Reply with quote
Sorry Jay, but for a force feedback joystick, USB is the only solution.
and (of course) USB is interrupt driven. It's just that there is not a nice
simple interrupt for an event. Instead the handler has to interpret the
packet and work out what it is.
Now on this, the data here is the report descriptor. It contains separate
descriptors for a huge number of different possible packets that the
stick can generate (I count about 23...). This goes into the block starting:
const char USB_CLASS_SPECIFIC_DESC[] =
Have a look at the example for multihid, which shows a larger class
descriptor.
