printf vs char array assignment speed
dluu13
PostPosted: Thu May 16, 2019 8:01 am     Reply with quote
I have been looking at using BCD conversion because of another thread on this forum because of its speed benefits over scaling by div/10 and even over %lw and I came across a peculiar problem. I started to describe it here in the other thread:
http://www.ccsinfo.com/forum/viewtopic.php?p=224145#224145
Here is the code again:
 * File:   CuriosityPrint.c
 * Author: dluu
 * Created on Apr 5, 2019
#include<24FJ128GA204.h>
#FUSES NOWDT, NODEBUG, NOWRT, NOPROTECT, NOJTAG, ICSP1
#FUSES NOLVR, NOBROWNOUT, NOIOL1WAY, NODSBOR, NODSWDT
#FUSES NOALTCMPI, FRC_PLL, PLL_FROM_FRC, PLL8X
#PIN_SELECT U3RX=PIN_B5
#PIN_SELECT U3TX=PIN_B6
#USE DELAY(clock=32MHZ)
#USE RS232(BAUD=115200, UART3, BITS=8, PARITY=N, STOP=1, STREAM=PC, ERRORS, RECEIVE_BUFFER=128)
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
// slightly modified from gaugeguy on CCS forum
uint32_t Int16toBCD5(uint16_t local_convert)
    //converts 16bit value, to four BCD digits. Tries to do it fairly
    //efficiently, both in size, and speed.
    uint16_t bit_cnt = 16;
    uint32_t BCD;
    BCD = 0;
        do
            if ((BCD & 0x0000000F) >= 0x00000005) BCD += 0x00000003;
            if ((BCD & 0x000000F0) >= 0x00000050) BCD += 0x00000030;
            if ((BCD & 0x00000F00) >= 0x00000500) BCD += 0x00000300;
            if ((BCD & 0x0000F000) >= 0x00005000) BCD += 0x00003000;
            if ((BCD & 0x000F0000) >= 0x00050000) BCD += 0x00030000;
            //            if ((BCD & 0x00F00000) >= 0x00500000) BCD += 0x00300000;
            //            if ((BCD & 0x0F000000) >= 0x05000000) BCD += 0x03000000;
            //            if ((BCD & 0xF0000000) >= 0x50000000) BCD += 0x30000000;
            shift_left(&BCD, 3, shift_left(&local_convert, 2, 0));
        while (--bit_cnt != 0);
    return BCD;
#define BCDNIBBLES 5
void printScaledBCD(uint16_t num, uint8_t decimalPlaces)
    uint32_t BCD5 = Int16toBCD5(num);
    if (decimalPlaces == BCDNIBBLES) fprintf(PC, "0");
    for (int i = 0; i < BCDNIBBLES; ++i)
        if (BCDNIBBLES - i == decimalPlaces) fprintf(PC, ".");
        fprintf(PC, "%x", (BCD5 >> ((BCDNIBBLES - 1 - i) << 2))&0x0F);
void ScaledBCDtoStr(uint16_t num, uint8_t decimalPlaces, char * buf) // very slow...
    uint8_t decimal = 0;
    uint8_t j = 0;
    if (decimalPlaces > 0) decimal = 1;
    if (decimalPlaces == BCDNIBBLES) buf[j++] = '0';
    for (int i = 0; i < BCDNIBBLES+decimal; ++i)
        if (BCDNIBBLES - i == decimalPlaces) buf[j++] = '.';
        buf[j] = ((BCD5 >> ((BCDNIBBLES - 1 - i) << 2))&0x0F)+0x30;
        ++j;
    buf[BCDNIBBLES+decimal] = '\0';
int main(void)
    uint16_t test[] = {11, 222, 3333, 44444, 55555, 12222, 23333, 34444, 45555};
    fprintf(PC, "\r\n\r\n");
    fprintf(PC, "test BCD dec: ");
    output_high(PIN_B8);
    for (int i = 0; i < 9; ++i)
        printScaledBCD(test[i], 3);
        fprintf(PC, ",");
    output_low(PIN_B8); // 5.5 ms
    fprintf(PC, "\r\n");
    fprintf(PC, "test BCD str: ");
    char bcdstr[10];
    output_high(PIN_B9);
        ScaledBCDtoStr(test[i], 3, bcdstr);
        fprintf(PC, "%s,", bcdstr);
    output_low(PIN_B9); // over 200 ms...
    while (1)
    return 0;
In this code, I have a function to directly print out the BCD and inserting a decimal point where I want one, and another to do the same thing but instead of printing it out, it puts it into a char array.
The puzzling thing is that the one that puts the BCD into a char array is about 40 times slower!
I have found out that in the char array method, it is
that's making it slow, but I don't know why. I use this in my fprintf as well, except without the +0x30 at the end.
Looking at the .lst file, the two are nearly identical.
....................         fprintf(PC, "%x", (BCD5 >> ((BCDNIBBLES - 1 - i) << 2))&0x0F);
00AC0:  MOV     #4,W4
00AC2:  MOV     8C4,W3
00AC4:  SUB     W4,W3,W5
00AC6:  SL      W5,#2,W0
00AC8:  MOV     W0,W4
00ACA:  MOV     8C0,W5
00ACC:  MOV     8C2,W6
00ACE:  INC     W4,W4
00AD0:  DEC     W4,W4
00AD2:  BRA     Z,ADA
00AD4:  LSR     W6,W6
00AD6:  RRC     W5,W5
00AD8:  BRA     AD0
00ADA:  AND     W5,#F,W5
00ADC:  CLR     W6
00ADE:  MOV     W5,W0
00AE0:  MOV     W6,W1
00AE2:  MOV     #0,W2
00AE4:  MOV     #0,W3
00AE6:  MOV     #2710,W4
00AE8:  CALL    A36
00AEC:  INC     08C4
00AEE:  GOTO    AA4
....................         buf[j] = ((BCD5 >> ((BCDNIBBLES - 1 - i) << 2))&0x0F)+0x30;
00B56:  MOV     8C2,W4
00B58:  CLR.B   9
00B5A:  MOV     W4,W0
00B5C:  ADD     8C0,W0
00B5E:  MOV     W0,W5
00B60:  MOV     #4,W4
00B62:  MOV     8C8,W3
00B64:  SUB     W4,W3,W6
00B66:  SL      W6,#2,W0
00B68:  MOV     W0,W4
00B6A:  MOV     8C4,W6
00B6C:  MOV     8C6,W7
00B6E:  INC     W4,W4
00B70:  DEC     W4,W4
00B72:  BRA     Z,B7A
00B74:  LSR     W7,W7
00B76:  RRC     W6,W6
00B78:  BRA     B70
00B7A:  AND     W6,#F,W6
00B7C:  CLR     W7
00B7E:  MOV     #30,W4
00B80:  ADD     W6,W4,W0
00B82:  ADDC    W7,#0,W1
00B84:  MOV.B   W0L,[W5]
Anybody have an idea why it's so much slower?
If instead of
I put
buf[j] = 'a';
then instead of over 200 ms, it only takes 5.4 ms.
gaugeguy
PostPosted: Thu May 16, 2019 8:27 am     Reply with quote
Doing a rotate (or shift) by a variable amount takes a lot of time for the calculations and looping. Doing a rotate by a fixed value is very fast.
dluu13
PostPosted: Thu May 16, 2019 8:48 am     Reply with quote
I'll try using a ptr increment as you suggested a little later.
As for shifting by a variable amount, I do it in my print function and it nowhere as slow as doing it in my string function...
dluu13
PostPosted: Thu May 16, 2019 10:35 am     Reply with quote
It's certainly not pretty, but it works. Using this function instead of the old one will decrease the time to print all 9 numbers in my array from 222 ms to 5.4 ms.
    uint8_t j = 0;
    char* ptr = buf;
    if (decimalPlaces == BCDNIBBLES) *ptr++ = '0';
        if (BCDNIBBLES - i == decimalPlaces) *ptr++ = '.';
        switch(i)
        case 0:
            *ptr++ = ((BCD5 >> 16)&0x0F)+0x30;
        case 1:
            *ptr++ = ((BCD5 >> 12)&0x0F)+0x30;
        case 2:
            *ptr++ = ((BCD5 >> 8)&0x0F)+0x30;
        case 3:
            *ptr++ = ((BCD5 >> 4)&0x0F)+0x30;
        case 4:
            *ptr++ = ((BCD5 >> 0)&0x0F)+0x30;
    *ptr = '\0';
Thanks for your comment, gaugeguy and Ttelmah in the other thread.
PostPosted: Thu May 16, 2019 3:06 pm     Reply with quote
Wow 40X faster !!! Who cares about 'pretty' ? Just add a few comments so 3 days or 3 hrs (for me ) from now you'll say, yes, that's what that means.....'
dluu13
PostPosted: Thu May 16, 2019 3:08 pm     Reply with quote
The mystery is that I use variable shifts in the function that prints instead of writing to a string, and that runs just as fast this one...
PostPosted: Fri May 17, 2019 12:56 am     Reply with quote
Look to find what is different:
1) Is the variable a local 'fixed' variable, or itself addressed by a pointer
or as an array?. Indexed addressing costs a lot.
2) Is the variable a byte, int16 or int32?. The bigger the variable, the more
the overhead is.
Variable shifts always cost a lot, but the overhead more than doubles when
you go to int16, and leaps up when indexed addressing is used. I'm
guessing you will find that something about the nature of the operation
is actually different.
dluu13
PostPosted: Fri May 17, 2019 7:17 am     Reply with quote
I must be really missing something here as to why it's not working...
Anyway since it's working now I might revisit it some other time. There's a lot of other work to do :D
