Fastest way to forward data from uart 1 to uart 2
Manu59114
PostPosted: Mon May 13, 2019 10:22 am     Reply with quote
Hello to all!
I was thinking that i need to transfer Data receive from UART1 and forward these data to the UART2 without modification...
What is the fastest way to do that and where is the best place to do that...
( inside the RDA interrupt like this?)
#INT_RDA //RS232 RECEIVE DATA AVAILABLE - One CHAR is READY to be READ.
void  RDA_isr(void)
  int t;
   buffer[next_in]=fgetc(PORT1); // get the data on port 1
   fputc(buffer[next_int],PORT2); // send the data on port 2
   t=next_in;
   if(++next_in==BUFFER_SIZE)
      {next_in=0;} // alors mettre 0 dans next_in pour revenir au début, ainsi
   if(next_in==next_out) //
     next_in=t; //
   Compteur_Data_In++;
or it's better to use the transmit circular buffer too?
2/ Pic33 with DMA Channel?
is it better and quicker to use DMA channel to do that?
Thank you for your reply.
Wish you a great day!
Manu
CCS + ICD3 + PIC18F46K80
PostPosted: Mon May 13, 2019 1:48 pm     Reply with quote
fastest ? ... use HW... a piece of wire Very Happy
really
OK, if you want a 'controllable' SW solution, 2 choices.
1) Have the PIC control a reed switch connected between UART1 RCV and UART 2 XMT pins.
2) Use 2 ISRs, one for each UART, basically what you presented. How you code depends on other factors but using ISRs should be the fastest SW approach. I could get 1Mbaud having PC send to U1 which sent to U2 then to PC, using an 18F46K22. Test went overnight with zero problems.
Jay
PostPosted: Mon May 13, 2019 1:56 pm     Reply with quote
The speed is limited by the baud rate. Nothing else.
If you use DMA, it'll transfer the byte whenever the receive interrupt
triggers without using any processor time. _But_ the issue is that you won't
receive a 'transfer complete; interrupt until the specified number of bytes
for the DMA transfer has been moved. So if (for instance) you want to
process on a carriage return for example, you won't know this has
actually happened.
DMA is great if you have a fixed packet size, but otherwise can be awkward.
asmallri
Re: Fastest way to forward data from uart 1 to uart 2
PostPosted: Mon May 13, 2019 2:02 pm     Reply with quote
Manu59114 wrote:
Hello to all!
void  RDA_isr(void)
  int t;
   t=next_in;
     next_in=t; //
   Compteur_Data_In++;
Manu
If the only data ever transmitted to port 2 is the traffic received from port one and both ports are identically configured, then the solution you have listed is fine as it is.
Regards, Andrew
PostPosted: Mon May 13, 2019 4:00 pm     Reply with quote
#INT_RDA
void RDA_isr(void)
int t;
You are doing two array accesses to send the byte. That's slow, compared to this:
#int_rda
void  RDA_isr(void)
  int8 c;
  int8  next_in;
  c = fgetc(PORT1); // Get incoming byte in a char
  fputc(c, PORT2);  // Send the char back out
  buffer[next_in] = c; // Then save it in the array
  // Put the rest of #int_rda code here
Here's the .LST file:
....................   c = fgetc(PORT1);
000B6:  BTFSS  F9E.5
000B8:  BRA    00B6
000BA:  MOVFF  FAE,59
....................   fputc(c, PORT2);
000BE:  MOVF   59,W
000C0:  RCALL  00AE
....................   buffer[next_in] = c;
000C2:  CLRF   03
000C4:  MOVF   5A,W
000C6:  ADDLW  19
000C8:  MOVWF  FE9
000CA:  MOVLW  00
000CC:  ADDWFC 03,W
000CE:  MOVWF  FEA
000D0:  MOVFF  59,FEF
The byte is quickly sent, and the costly array access is done after that.
Manu59114
PostPosted: Wed May 15, 2019 2:18 am     Reply with quote
Thanks to all
Thank to Temtronic for the wire!!! why not the red relay but i can't add this on the existing PCB! Wink
Thank to Ttelmah for the DMA explanation. Wink
Thank to asmallri to confirm that my idea is not so bad! Wink
Thank to PCM programmer for the code length demonstration Wink
Manu
Manu59114
PostPosted: Wed May 15, 2019 2:34 am     Reply with quote
Thanks to all
Manu
