about int1
Zek_De
about int1
PostPosted: Sun Mar 17, 2019 4:43 am     Reply with quote
Hi, I have seen a variable int1 in Modbus library in CCS C, and I wonder if uint8_t two_characters=0; increment two times like that:
two_characters++; is 1
two_characters++; is 0
two_characters++; is 1 am I right? These are the code.
void incomming_modbus_serial() {
   char c;
   static int1 two_characters=0;
   static unsigned int8 datah,datal,data;
   c = fgetc(MODBUS_SERIAL) & 0x7F;
   if (!modbus_serial_new)
      if(modbus_serial_state == MODBUS_START)
         if(c==':')
            modbus_serial_state++;
      else if(modbus_serial_state == MODBUS_GETADDY)
         if(!two_characters)
            if(c>=0x41)
               datah=((c-0x37)<<4);
               datah=((c-0x30)<<4);
            modbus_serial_lrc=0;
            if(c>=0x41)
               datal=c-0x37;
               datal=c-0x30;
            data=(datah | datal);
            modbus_rx.address=data;
            modbus_calc_crc(data);
         two_characters++;
      else if(modbus_serial_state == MODBUS_GETFUNC)
         if(!two_characters)
            if(c>=0x41)
            if(c>=0x41)
               datal=c-0x37;
               datal=c-0x30;
            modbus_rx.func=data;
            modbus_rx.len=0;
            modbus_rx.error=0;
         two_characters++;
      else if(modbus_serial_state == MODBUS_GETDATA)
         if(c=='\r')
            modbus_rx.len--;
            modbus_serial_lrc-=data;
         else if(!two_characters)
            if(c>=0x41)
            two_characters++;
            if(c>=0x41)
               datal=c-0x37;
               datal=c-0x30;
            if (modbus_rx.len>=MODBUS_SERIAL_RX_BUFFER_SIZE)
               modbus_rx.len=MODBUS_SERIAL_RX_BUFFER_SIZE-1;
            modbus_rx.data[modbus_rx.len]=data;
            modbus_rx.len++;
            two_characters++;
      else if(modbus_serial_state==MODBUS_STOP)
         if(c=='\n')
            modbus_serial_lrc=((0xFF-modbus_serial_lrc)+1);
            if(modbus_serial_lrc==data)
               modbus_serial_new=TRUE;
         modbus_serial_state=MODBUS_START;
         two_characters=0;
   #if (MODBUS_TYPE == MODBUS_TYPE_MASTER)
      modbus_serial_wait=MODBUS_SERIAL_TIMEOUT;
   #endif
PostPosted: Sun Mar 17, 2019 5:35 am     Reply with quote
Yes, by looking at the code (quickly), they use it to determine which incoming data byte is the MSB and the LSB of a 'pair' of data. I'm assuming the MODBUS data is in pairs.
Rather clever really, as a simple quick test determines if high byte or low byte. Actually any '1 of 2' choices.
You could also use it as an 'odd or even' test
Jay
Zek_De
PostPosted: Sun Mar 17, 2019 6:01 am     Reply with quote
Okay temtronic,
changing I wonder here was this
and you checked it is right. Thank you
PostPosted: Sun Mar 17, 2019 6:50 am     Reply with quote
Of course the easy check to this ,is to have the program display the 'two_characters' value, say to a PC or LCD module....
If you have a one spare I/O pin, asttache a TTL<>USB module and use this to send 'debug data' to a PC running a 'terminal program'. This is also a great way to look at ANY variable and any point of the program.
PostPosted: Sun Mar 17, 2019 6:58 am     Reply with quote
The only thing 'puzzling', is the phrasing of your question...
You say "uint8_t two_characters=0;". Er. unt8_8... No the variable is int1,
and importantly _static_. So the value is initialised to '0' on the first pass
(this is what it is explicitly initialised 'to'), and then increments 0,1,0,1 etc..
Zek_De
PostPosted: Mon Mar 18, 2019 5:11 am     Reply with quote
Yes I sould check it using LCD but I didnt have it and I needed learn it very fast, and thank you all help.
