18F2550 C4 C5 problem
40inD
PostPosted: Thu Mar 14, 2019 2:50 pm     Reply with quote
When I try to toggle defined pins TRI1, TRI2 as C4 and C5 then nothing happens.
But if i define those pins for example as A1 and A2 then it works.
I can't understand, why C4 and C5 does not work?
#include <18F2550.h>
#device ADC=8
#include <stdlib.h>
#fuses  INTRC
#FUSES WDT2048
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC                //Timer1 configured for higher power operation
#FUSES PUT
#FUSES NOLVP   //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(internal=8000000,RESTART_WDT)
#define TRI1 PIN_C4
#define TRI2 PIN_C5
   setup_oscillator(OSC_8MHz);
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_DIV_64|ADC_TAD_MUL_20);
   set_adc_channel(0);
   //setup_WDT( WDT_2S);
  { output_high(TRI1);
   output_high(TRI2);
    output_low(TRI1);
output_low(TRI2);
   }// while true
PostPosted: Thu Mar 14, 2019 2:55 pm     Reply with quote
Well it's time to download the 438 page datasheet and read page 15 !
Table 1-2 will tell you why.....
If I say why, you won't remember for next time. Prof told me that back in '74.
Jay
40inD
PostPosted: Thu Mar 14, 2019 3:04 pm     Reply with quote
Thanks, I always forget about input-only pins.
PostPosted: Thu Mar 14, 2019 3:49 pm     Reply with quote
Ever since PICs grew more than 18 pins, you've needed to read the datasheet. It's amazing what they can jam into the epoxy these days !
Jay
PostPosted: Fri Mar 15, 2019 4:06 am     Reply with quote
Actually I think you needed to read the sheet even when they were 18pin.
After all in those days you were having to learn about TRIS and which
pins took the power etc..
However it was a lot easier when the sheet was only about thirty pages
in total....
PostPosted: Fri Mar 15, 2019 5:12 am     Reply with quote
re:
in total....
I'd do that while the PIC was being erased in the UV chamber....... Very Happy
Jay
