rfjhh
Constants |
Posted: Wed Mar 13, 2019 2:51 pm |
I am trying to modify the LCD420.c library to work with port D but I have found things that I do not understand:
How should I interpret the following sequence?
Code: | struct lcd_pin_map const LCD_READ = {0,0,0,0,15};
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_d([b]LCD_READ[/b]);
Joined: 01 Jul 2010 Posts: 9282 Location: Greensville,Ontario
Posted: Wed Mar 13, 2019 6:45 pm |
my copy of the driver has this..
// The following are used for setting
// the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
Note the //comment at the end. It makes 4 pins of the I/O data direction register (TRISx) to be inputs, thus allwoing the PIC to READ the data from the LCD module.
I would have preferred ... LCD_READ = {0,0,0,0,1,1,1,1}, as it 'shows' the format better, at least to me.
hope this helps
Jay |
Re: Constants |
Posted: Wed Mar 13, 2019 7:25 pm |
rfjhh wrote: |
I am trying to modify the LCD420.c library to work with port D |
1. Change the following line:
Quote: | #locate lcd = getenv("SFR:PORTB") |
to this:
Code: | #locate lcd = getenv("SFR:PORTD") |
2. In the following routine, notice the two lines in bold:
Quote: | BYTE lcd_read_byte() {
BYTE low,high;
set_tris_b(LCD_READ);
set_tris_b(LCD_WRITE);
return( (high<<4) | low);
Change them to:
Code: | set_tris_d(LCD_READ); | and
Code: | set_tris_d(LCD_WRITE);
3. In this routine, notice the line in bold:
Quote: | void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
Change it to:
Jerson
Joined: 31 Jul 2009 Posts: 126 Location: Bombay, India
Re: Constants |
Posted: Wed Mar 13, 2019 8:39 pm |
rfjhh wrote: |
LCD_READ is a structure mapped onto a byte value. the value shown is 0x0F. So, the statement set_tris_d(LCD_READ) will be seen as set_tris_d(0x0F) |
rfjhh
Problem fixed |
Posted: Wed Mar 13, 2019 10:50 pm |
Thanks all of you, PCM specially, now it's working well. |
