emazzu630
Joined: 14 Aug 2018 Posts: 20 Location: Ouro Verde - SC
| How to round the number to the nearest ten? |
Posted: Wed Feb 27, 2019 11:49 pm |
With the button pressed (AP == 0), counting from 1 to 1 is performed with
the "UP and DOWN" buttons.
With the release button, (AP == 1), the count of 5 to 5 is performed
through the "UP and DOWN" buttons.
The point is that if the count of 1 to 1 is between 0 and 5 or between 5
and 10, the count of "5 to 5" is wrong.
A rounding is required that at the first pressing of the "UP and DOWN"
buttons, only the unit number will
"0" or "5" following the count of 5 to 5.
I declare the library "math.h" and tried unsuccessfully the
"value = ceil();" and "value = floor ();".
In the code below, I got the correct sequence on the display only to
appear when the button is pressed, when I release the number outside
the "0, 5, or 10" sequence appears again.
Anyone who has the solution, would you like to share? Thank you very much.
while((UP == 0)||(DOWN == 0)) {
if (UP == 0)
dados+=c;
dados-=c;
7_seg(dados);
d++;
if ((AP == 1) &&
((dig0 == 1)||(dig0 == 2)||(dig0 == 3)||(dig0 == 4)||
(dig0 == 6)||(dig0 == 7)||(dig0 == 8)||(dig0 == 9))) {
if ((dig0 == 1)||(dig0 == 2)||(dig0 == 3)||(dig0 == 4)) {
dig0 = 0; }
else {
dig0 = 5; }
Posted: Thu Feb 28, 2019 12:07 am |
What you are describing is 4/5 rounding. You do this with:
result=floor(val+4);
This gives 0 for 0,1,2,3,4, and then 5 for 5,6,7,8,9. Hence the '4/5'.
If you were working with floats, the formula is:
result=floor(val+4.99999); |
