Help With 12f683 Two Analog Inputs
Goto page 1, 2  Next
Rez
PostPosted: Tue Feb 19, 2019 1:04 pm     Reply with quote
I have two timers and I am controlling the time with A0 and A1 as inputs (2 10k pots). I am not sure if I am setting up the ports correctly but I can't get them both to work. If I have input A0 by itself it works.
This is my setup for the ports.
#use delay(clock = 4000000)
#fuses INTRC_IO,NOWDT,NOPROTECT,NOMCLR
setup_adc(ADC_CLOCK_INTERNAL); //internal clock
setup_adc_ports(sAN0 | sAN1); //setup port A0
set_adc_channel(0); //output to port A0
set_adc_channel(1); //output to port A1
setup_comparator(NC_NC_NC_NC); //turn off comp
PostPosted: Tue Feb 19, 2019 1:23 pm     Reply with quote
quick comment....
from the datasheet, ADC section, table 9-1....
notes:
4: When the device frequency is greater than 1 MHz, the FRC clock source is only recommended if the
conversion will be performed during Sleep.
You've decised on a 4MHz clock ,so...you only have 2 choices according to the table.
Rez
PostPosted: Tue Feb 19, 2019 1:47 pm     Reply with quote
temtronic wrote:
quick comment....
notes:
I am new to ADC so I don't understand enough of what the data sheet is saying, could you help out and explain some of it to me so I can learn some more about it, thx.
PostPosted: Tue Feb 19, 2019 1:51 pm     Reply with quote
Then set_adc_channel(0), is not a 'setup'.
It physically connectes AN0 to the ADC.
Once you gave done this, you have to wait for Tacq, and then read the ADC
This will then return the digital value corresponding to the voltage on AN0.
You can then set_adc_channel(1), again wait for Tacq, and then read the
port again to read the value from AN1.
Rez
PostPosted: Tue Feb 19, 2019 2:29 pm     Reply with quote
I got this to work, is this a correct way of doing it, is there a better way?
setup_adc_ports(sAN0 | sAN1); //read port A0 and A1
result = read_adc();
delay_us(10);
resultACT = read_adc();
delay_us(10);
Rez
PostPosted: Tue Feb 19, 2019 2:55 pm     Reply with quote
delay_us(10);
delay_us(10);
I thought this was working ,but its not quit right the AN1's timer is working but AN0 is not.
Rez
PostPosted: Tue Feb 19, 2019 3:08 pm     Reply with quote
delay_us(10);
delay_us(10);
It is working I didn't have one of my jumpers in the correct spot.
Rez
PostPosted: Tue Feb 19, 2019 3:24 pm     Reply with quote
delay_us(10);
delay_us(10);
I am driving myself crazy, I thouhgt yet again it was working,but its not, I am so lost.
PostPosted: Tue Feb 19, 2019 4:26 pm     Reply with quote
this is still wrong
HOW do you see the 'result'?
you need to post your complete program...
arachid
PostPosted: Tue Feb 19, 2019 5:07 pm     Reply with quote
you Don't use the delay_us(10) at right moment, you need to wait after change channel not after read, and you frotgot to indicate the reference.
like this:
setup_adc(ADC_CLOCK_INTERNAL); // adc internal clock
setup_adc_ports(sAN0 | sAN1|VSS_VDD); //read port A0 and A1 analog input
set_adc_channel(0); //input of the adc is on port A0 pin 7
delay_us(10); //wait after change input of adc channel
result = read_adc(); // start and read the adc
set_adc_channel(1); //input of the adc is on port A1 pin 6
resultACT = read_adc(); // start and read the adc
arachid
PostPosted: Tue Feb 19, 2019 5:15 pm     Reply with quote
sorry not need raference if you not use vref
setup_adc_ports(sAN0 | sAN1); //read port A0 and A1 analog input
is ok because
VSS_VDD is 0x0000
them it is by default.
Rez
PostPosted: Tue Feb 19, 2019 5:18 pm     Reply with quote
temtronic wrote:
this is still wrong
I got this code to work.
Please explain to me about this being wrong, thx. setup_adc(ADC_CLOCK_INTERNAL);
#include <12F683.h>
#define ACT PIN_A5
#define IN PIN_A3 //Main Input
//time 1
int result;
void Time(void)
delay_us(10);
for(int i = 0; i < result; i++)
   delay_ms(120);
//time 2
int resultACT;
void TimeACT(void)
delay_us(10);
for(int i = 0; i < resultACT; i++)
   delay_ms(15);
//setup_oscillator(0);
set_adc_channel(0); //use port A0
set_adc_channel(1); //use port A1
if(input(IN)) //push button to start time
   output_high(ACT);
   TimeACT();
   output_low(ACT);
   Time();
   output_high(ACT);
   TimeACT();
   output_low(ACT);
while(input(IN));
delay_ms(50);
while(!input(IN));
PostPosted: Tue Feb 19, 2019 6:11 pm     Reply with quote
this
is still wrong
arachid
PostPosted: Tue Feb 19, 2019 6:30 pm     Reply with quote
try:
//time 1
int result;
void Time(void)
delay_us(10);
delay_ms(120);
arachid
PostPosted: Tue Feb 19, 2019 6:32 pm     Reply with quote
try
#include <12F683.h>
#define ACT PIN_A5
//time 1
int result;
void Time(void)
delay_us(10);
   delay_ms(120);
//time 2
int resultACT;
void TimeACT(void)
delay_us(10);
   delay_ms(15);
   output_high(ACT);
   TimeACT();
   output_low(ACT);
   Time();
   output_high(ACT);
   TimeACT();
   output_low(ACT);
while(input(IN));
delay_ms(50);
while(!input(IN));
Goto page 1, 2  Next
Page 1 of 2
