maier
USB with PIC24EP512GU810 |
Posted: Tue Feb 19, 2019 9:31 am |
I'm trying to get this PIC USB to work. I copied the code and descriptor from a working project (other PIC), but it doesn't work (Error requesting the USB device descriptor, Code 43).
#include <24EP512GU810.h>
#device ICSP=1
#use delay(osc=24MHZ, clock=48MHZ, USB)
#FUSES CKSFSM //Clock Switching is enabled
#FUSES BROWNOUT
#FUSES NOJTAG //JTAG disabled
#FUSES NODEBUG
#define EP1 1
#include <pic24_usb.h> //Microchip PIC18 hardware layer for usb.c
#include "usb_desc_hid.h" //USB Device descriptor
#include <usb.c>
#define SIZE 8
void main( void )
char inbuf[SIZE];
char outbuf[SIZE];
usb_init_cs();
while(TRUE) {
usb_task();
if(usb_enumerated()) {
if (usb_kbhit(EP1)) {
usb_get_packet(EP1,inbuf,SIZE);
if (inbuf[0]==10) {
outbuf[0]='o';
outbuf[1]='k';
outbuf[2]=0;
usb_puts(EP1, outbuf, SIZE, 100 );
Anybody recognize a mistake?
Or is there something special to consider with this PIC?
Is there a way to measure the oscillator? If you could get the PIC to output to USB with a few lines, you could use an oscilloscope to verify the frequency. This would certainly be a very helpful feature for many developers
Uli |
Joined: 01 Jul 2010 Posts: 9515 Location: Greensville,Ontario
Posted: Tue Feb 19, 2019 10:13 am |
I don't use that PIC but...
this...
seems 'wrong' ? Would the pic24 need a PIC 24 HW layer and not PIC18 HW layer ??
I gave up with embedded USB PICs years ago. It's simpler,easier, cheaper to just buy a TTL<>USB module. I've bought dozens over the years and all have worked without any problems.
