luckyluke
| is these same? |
Posted: Sun Feb 17, 2019 4:34 am |
hello
i am controlling two motors with h-bridge controller.
i want to ask a question about frequent update of pwm duty.
#include <18f2520.H>
#fuses XT, NOWDT,NOBROWNOUT,PUT,NOLVP,NOMCLR
void main(){
setup_timer_2(T2_DIV_BY_4,200,6);
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
while(1){
while (!interrupt_active(INT_TIMER1));
clear_interrupt(INT_TIMER1);
set_timer1(64536);
set_pwm1_duty(200);
set_pwm2_duty(200);
void main(){
set_pwm1_duty(200);
set_pwm2_duty(200);
while(1){
set_timer1(64536);
so is these code same for motor? |
Posted: Sun Feb 17, 2019 5:35 am |
The PWM gets updated on the next cycle, and since the update is to the same number it'll remain unchanged.
Honestly 'better' to make your indentation reflect actual operations:
; //This is the operation being handled by the 'while'
clear_interrupt(INT_TIMER1); //these lines are not
set_timer1(64536);
set_pwm1_duty(200);
set_pwm2_duty(200);
Otherwise it is terribly easy to forget which operations are in which loop |
luckyluke
Posted: Sun Feb 17, 2019 6:15 am |
It was for fixed 1 ms interval.
I intended to fill 1ms with\
| Code: | | while (!interrupt_active(INT_TIMER1)) ; |
Actual program is like:
set_timer1(64536);
sensor_read();
decision();
motor();
Is this wrong logic or bad for readability? |
