MRF89XA
in_nursery
MRF89XA
PostPosted: Tue Feb 05, 2019 11:08 am     Reply with quote
Hi all
I make research on the forum with no luck. I'm stuck with a MRF89XA.
basic driver
MRF89XA.c
#include <MRF89XA.h>
// First time configuration settings for MRF89XA
unsigned int8 InitConfigRegs[] = {
      /* 0 */     CHIPMODE_STBYMODE | FREQBAND_915 | VCO_TRIM_11,
      /* 1 */     MODSEL_FSK | DATAMODE_PACKET | IFGAIN_0,
      /* 2 */     FREGDEV_80,
      /* 3 */     BITRATE_25,
      /* 4 */     OOKFLOORTHRESH_VALUE,
      /* 5 */     FIFOSIZE_64 | FIFO_THRSHOLD_1,
      /* 6 */     0,
      /* 7 */     0,
      /* 8 */     0,
      /* 9 */     0,
      /* 10 */    0,
      /* 11 */    0,
      /* 12 */    DEF_PARAMP | PA_RAMP_23,
      /* 13 */    IRQ0_RX_STDBY_SYNCADRS | IRQ1_RX_STDBY_CRCOK | IRQ1_TX_TXDONE,
      /* 14 */    DEF_IRQPARAM1 | IRQ0_TX_START_FIFOTHRESH | IRQ1_PLL_LOCK_PIN_ON,
      /* 15 */    RSSIIRQTHRESH_VALUE,
      /* 16 */    PASSIVEFILT_378 | RXFC_FOPLUS100,
      /* 17 */    DEF_RXPARAM1 | FO_100,
      /* 18 */    DEF_RXPARAM2 | POLYPFILT_OFF | SYNC_SIZE_32 | SYNC_ON | SYNC_ERRORS_0,
      /* 19 */    DEF_RXPARAM3,
      /* 20 */    0,
      /* 21 */    OOK_THRESH_DECSTEP_000 | OOK_THRESH_DECPERIOD_000 | OOK_THRESH_AVERAGING_00,
      /* 22 */    0x69, // 1st byte of Sync word,
      /* 23 */    0x81, // 2nd byte of Sync word,
      /* 24 */    0x7E, // 3rd byte of Sync word,
      /* 25 */    0x96, // 4th byte of Sync word,
      /* 26 */    FC_400 | TXPOWER_13,
      /* 27 */    CLKOUT_ON | CLKOUT_12800,
      /* 28 */    MANCHESTER_OFF | 64,
      /* 29 */    NODEADRS_VALUE,
      /* 30 */    PKT_FORMAT_VARIABLE | PREAMBLE_SIZE_4 | WHITENING_OFF | CRC_ON | ADRSFILT_NONE,
      /* 31 */    FIFO_AUTOCLR_ON | FIFO_STBY_ACCESS_WRITE
// Register Set
void RegisterSet(int8 address, int8 value)
   output_low(CSCON);
   address = (address<<1);
   spi_write (address);
   spi_write (value);
   output_high(CSCON);
// Register Read
int8 RegisterRead(int8 address)
   unsigned int8 data_r = 0, dummy_data_r = 0;
   output_low(CSCON);
   delay_ms(50);
   address = ((address<<1)|0x40);
   spi_write(dummy_data_r);
   data_r = spi_read(dummy_data_r);
   output_high(CSCON);
   return data_r;
// SetRFMode(int8 mode)
// Sets the MRF89XA transceiver operating mode to:
// sleep, transmit, receive or standby
void SetRFMode(int8 mode)
   int8   mcparam0_read;
   mcparam0_read = RegisterRead(REG_MCPARAM0);
   switch (mode) {
      case RF_TRANSMITTER:
         RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_TRANSMITTER);
         RF_Mode = RF_TRANSMITTER;            //RF in TX mode
      case RF_RECEIVER:
         RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_RECEIVER);
         RF_Mode = RF_RECEIVER;               //RF in RX mode
      case RF_SYNTHESIZER:
         RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_SYNTHESIZER);
         RF_Mode = RF_SYNTHESIZER;            //RF in Synthesizer mode
      case RF_STANDBY:
         RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_STANDBY);
         RF_Mode = RF_STANDBY;               //RF in standby mode
      case RF_SLEEP:
         RegisterSet(REG_MCPARAM0, (mcparam0_read & 0x1F) | RF_SLEEP);
         RF_Mode = RF_SLEEP;                  //RF in sleep mode
// WriteFIFO(BYTE Data)
// Fills the FIFO
void WriteFIFO(int8 Data)
    output_low(CSDATA);
    spi_write(Data);
    output_high(CSDATA);
//  ReadFIFO(void)
//  Reads the Reiceved frame from the fifo and sets hasPacket accordingly
unsigned int8 ReadFIFO(void)
    output_low(CSDATA);
    return data_r;
//  MRF89XAInit(void)
//  This function reads the Reiceved frame from the fifo and sets hasPacket accordingly
void MRF89XAInit(void)
   int8 input,i=0;
   for (i = 0 ; i <= 31; i++)
      RegisterSet(i, InitConfigRegs[i]);
   input = RegisterRead(REG_MCPARAM0);
   RegisterSet(REG_MCPARAM0, (input & 0x1F) | RF_SYNTHESIZER);
   /* clear PLL_LOCK flag so we can see it restore on the new frequency */\
   input = RegisterRead(REG_IRQPARAM1);
   RegisterSet(REG_IRQPARAM1, (input | 0x02));
   RegisterSet(REG_MCPARAM0, ((input & 0xE7) | FREQBAND_915));
   //Program R, P,S registers
   RegisterSet(REG_R1, 119);
   RegisterSet(REG_P1, 100);
   RegisterSet(REG_S1, 52);
   RegisterSet(REG_MCPARAM0, ((input & 0x1F) | RF_SYNTHESIZER));
   SetRFMode(RF_STANDBY);
   //PHY_IRQ1_En = 1;
// Send_Packet(int8 TxPacketLen)
// Send the packet in the buffer TxPacket
void Send_Packet(int8 TxPacketLen)
   int8 i;
   int8 j;
   RegisterSet(REG_PKTPARAM3, ((InitConfigRegs[REG_PKTPARAM3] & 0xBF)| FIFO_STBY_ACCESS_WRITE));
   RegisterSet(REG_IRQPARAM0, (InitConfigRegs[REG_IRQPARAM0] | IRQ1_FIFO_OVERRUN_CLEAR ));
   RegisterSet(REG_IRQPARAM1, ((InitConfigRegs[REG_IRQPARAM1]) | 0x02));
   WriteFIFO(TxPacketLen+1);
   WriteFIFO(0x05);      //Node_adrs
   for(i=0; i< TxPacketLen; i++)
      WriteFIFO(TxPacket[i]);
   SetRFMode(RF_TRANSMITTER);
   //Reset FIFO
   j = RegisterRead(REG_IRQPARAM0);
   RegisterSet(REG_IRQPARAM0, (j | 0x01));
// ReceiveFrame(void)
void ReceiveFrame(void)
   int8 data, node_adrs;
   int8 i = 0;
   int8 j = 0;
  // if(IRQ1_Received)
      RxPacketLen = ReadFIFO();
         DRxPacketLen =RxPacketLen;
      node_adrs = ReadFIFO();
         Dnode_adrs =node_adrs;
      RxPacketLen = (RxPacketLen-1);
      while(RxPacketLen--)
         data = ReadFIFO();
         RxPacket[i] = data;
         i++;
      RxPacketLen = i;
 //  IRQ1_Received = FALSE;
   hasPacket = TRUE;
   //Reset FIFO
MRF89XA.h
 *                  MRF89XA Radio specific defs.
 * Company:         Microchip Technology, Inc.
 * Software License Agreement
 * The software supplied herewith by Microchip Technology Incorporated
 * (the “Company”) for its PICmicro® Microcontroller is intended and
 * supplied to you, the Company’s customer, for use solely and
 * exclusively on Microchip PICmicro Microcontroller products. The
 * software is owned by the Company and/or its supplier, and is
 * protected under applicable copyright laws. All rights are reserved.
 * Any use in violation of the foregoing restrictions may subject the
 * user to criminal sanctions under applicable laws, as well as to
 * civil liability for the breach of the terms and conditions of this
 * license.
 * THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
 * WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
 * TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
 * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
 * IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
 * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#ifndef _MRF89XA_
#define _MRF89XA_
MRF89XA Operating modes
#define RF_SLEEP                         0x00
#define RF_STANDBY                       0x20
#define RF_SYNTHESIZER                   0x40
#define RF_RECEIVER                      0x60
#define RF_TRANSMITTER                   0x80
MRF89XA Register Description
#define REG_MCPARAM0                     0
   #define CHIPMODE_SLEEPMODE  0x00   //000 [7:5]
   #define CHIPMODE_STBYMODE    0x20   //001 ;default
   #define CHIPMODE_FSMODE       0x40   //010
   #define CHIPMODE_RX          0x60   //011
   #define CHIPMODE_TX          0x80   //100
   #define FREQBAND_902      0x00   //902-915 00 [4:3]
   #define FREQBAND_915      0x08   //915-928 01 ;default
   #define FREQBAND_950      0x10   //950-960 or 863-870 10
   #define VCO_TRIM_00         0x00   // [2:1] Vtune determined by tank inductor values
   #define VCO_TRIM_01         0x02
   #define VCO_TRIM_10         0x04
   #define VCO_TRIM_11         0x06
#define REG_MCPARAM1                     1
   #define MODSEL_OOK         0x40   //01 [7:6]
   #define MODSEL_FSK         0x80   //10 ;default
   #define OOKTHRESHTYPE_FIXED 0x00   //00 [4:3]
   #define OOKTHRESHTYPE_PEAK   0x08   //01
   #define OOKTHRESHTYPE_AVG   0x10   //10
   #define DATAMODE_CONTINUOUS 0x00   //00 [Bit2,Bit5];default
   #define DATAMODE_BUFFERED   0x20   //01
   #define DATAMODE_PACKET       0x04   //1x
   #define IFGAIN_0         0x00   //00 [1:0] 0dB ;default
   #define IFGAIN_45         0x01   //01 -4.5dB
    #define IFGAIN_9         0x02   //10 -9dB
   #define IFGAIN_135         0x03   //11 -13.5dB
#define REG_FREGDEV                      2      //default D = 00000011, FDEV = 133 kHz
      //values may change - should be calculated based on crystal frequency - 12.8 MHz (fxtal/32/(D+1))
      #define FREGDEV_33      0x0B
      #define FREGDEV_40      0x09
      #define FREGDEV_50      0x07
      #define FREGDEV_67      0x05
      #define FREGDEV_80      0x04
      #define FREGDEV_100      0x03
      #define FREGDEV_133      0x02
      #define FREGDEV_200      0x01
#define REG_BITRATE                      3
                                    //default C = 0000111, BR = 25 Kbps
      #define BITRATE_200      0x00
      #define BITRATE_100      0x01
      #define BITRATE_66      0x02
      #define BITRATE_50      0x03
      #define BITRATE_40      0x04
      #define BITRATE_25      0x07
      #define BITRATE_20      0x09
      #define BITRATE_16      0x0B
      #define BITRATE_10      0x13
      #define BITRATE_5      0x27
      #define BITRATE_2      0x63
      #define BITRATE_1_56   0x7F
      #define BITRATE_2_41   0x52
      #define BITRATE_4_76   0x29
      #define BITRATE_8      0x18
      #define BITRATE_9_52   0x14
      #define BITRATE_12_5   0x0F
      #define BITRATE_16_67   0x0B
#define REG_OOKFLOORTHRESH               4
   // OOK threshold (reg4)
   #define OOKFLOORTHRESH_VALUE 0x0C
#define REG_MCPARAM5                     5
   #define FIFOSIZE_16         0x00   //00 [7:6] - 16bytes - default
   #define FIFOSIZE_32         0x40
   #define FIFOSIZE_48         0x80
   #define FIFOSIZE_64         0xC0
   #define FIFO_THRSHOLD_31   0x0F   //31 bytes - default [5:0]
   #define FIFO_THRSHOLD_1    0x01
#define REG_R1                           6
#define REG_P1                           7
#define REG_S1                           8
#define REG_R2                           9
#define REG_P2                           10
#define REG_S2                           11
#define REG_MCPARAM12                    12
   #define PA_RAMP_3         0x00   //[4:3] - 3us
   #define PA_RAMP_85         0x08   //8.5us
   #define PA_RAMP_15         0x10   //15us
   #define PA_RAMP_23         0x18   //23us
   #define DEF_PARAMP         0x20
#define REG_IRQPARAM0                    13
   // IRQ Param 0 (reg13)
   // Select RX&STDBY IRQ_0 sources (Packet mode) (reg13)
   #define IRQ0_RX_STDBY_PAYLOADREADY    0x00
   #define IRQ0_RX_STDBY_WRITEBYTE       0x40
   #define IRQ0_RX_STDBY_FIFOEMPTY       0x80
   #define IRQ0_RX_STDBY_SYNCADRS        0xC0
   // Select RX&STDBY IRQ_1 sources (Packet mode) (reg13)
   #define IRQ1_RX_STDBY_CRCOK           0x00
   #define IRQ1_RX_STDBY_FIFOFULL        0x10
   #define IRQ1_RX_STDBY_RSSI            0x20
   #define IRQ1_RX_STDBY_FIFOTHRESH      0x30
   // Select TX IRQ_1 sources (Packet mode) (reg13)
   #define IRQ1_TX_FIFOFULL              0x00
   #define IRQ1_TX_TXDONE                0x08
   // Select TX IRQ_1 sources (Continuous mode) (reg13)
   #define IRQ1_TX_DCLK                   0x00
   // FIFO overrun/clear  (reg13)
   #define IRQ1_FIFO_OVERRUN_CLEAR       0x01
#define REG_IRQPARAM1                    14
   // IRQ Param 1
   #define DEF_IRQPARAM1              0x08
   // Select TX start condition and IRQ_0 source (Packet mode)
   #define IRQ0_TX_START_FIFOTHRESH      0x00
   #define IRQ0_TX_START_FIFONOTEMPTY    0x10
   // RSSI IRQ flag
   #define IRQ1_RSSI_IRQ_CLEAR           0x04
   // PLL_Locked flag
   #define IRQ1_PLL_LOCK_CLEAR           0x02
   // PLL_Locked pin
   #define IRQ1_PLL_LOCK_PIN_OFF         0x00
   #define IRQ1_PLL_LOCK_PIN_ON          0x01
   // RSSI threshold for interrupt
   #define RSSIIRQTHRESH_VALUE           0x00
#define NODEADRS_VALUE          0x00
#define REG_RSSIIRQTHRESH                15
#define REG_RXPARAM0                     16
   // RX Param 0
   // Passive filter (kHz)
   #define PASSIVEFILT_65            0x00      //65 KHz
   #define PASSIVEFILT_82            0x10      //82 KHz
   #define PASSIVEFILT_109           0x20
   #define PASSIVEFILT_137           0x30
   #define PASSIVEFILT_157           0x40
   #define PASSIVEFILT_184           0x50
   #define PASSIVEFILT_211           0x60
   #define PASSIVEFILT_234           0x70
   #define PASSIVEFILT_262           0x80
   #define PASSIVEFILT_321           0x90
   #define PASSIVEFILT_378           0xA0
   #define PASSIVEFILT_414           0xB0
   #define PASSIVEFILT_458           0xC0
   #define PASSIVEFILT_514           0xD0
   #define PASSIVEFILT_676           0xE0
   #define PASSIVEFILT_987           0xF0
   // Butterworth filter (kHz)
   #define RXFC_VALUE                  0x03
   // !!! Values defined below only apply if XTAL frequency == 12.8MHz !!!
   #define RXFC_FOPLUS25               0x00
   #define RXFC_FOPLUS50               0x01
   #define RXFC_FOPLUS75               0x02
   #define RXFC_FOPLUS100              0x03
   #define RXFC_FOPLUS125              0x04
   #define RXFC_FOPLUS150              0x05
   #define RXFC_FOPLUS175              0x06
   #define RXFC_FOPLUS200              0x07
   #define RXFC_FOPLUS225              0x08
   #define RXFC_FOPLUS250              0x09
   #define RXFC_FOPLUS275            0x0A
   #define RXFC_FOPLUS300            0x0B
   #define RXFC_FOPLUS325            0x0C
   #define RXFC_FOPLUS350            0x0D
   #define RXFC_FOPLUS375            0x0E
   #define RXFC_FOPLUS400            0x0F
#define REG_RXPARAM1                     17
   // RX Param 1
   #define DEF_RXPARAM1           0x08
   // Polyphase filter center value (kHz)
   #define FO_VALUE                  0x30
   // !!! Values defined below only apply if RFCLKREF = DEFAULT VALUE = 0x07 !!!
   #define FO_50                     0x10
   #define FO_75                     0x20
   #define FO_100                    0x30
   #define FO_125                    0x40
   #define FO_150                    0x50
   #define FO_175                    0x60
   #define FO_200                    0x70
   #define FO_225                    0x80
   #define FO_250                    0x90
   #define FO_275                    0xA0
   #define FO_300                    0xB0
   #define FO_325                    0xC0
   #define FO_350                    0xD0
   #define FO_375                    0xE0
   #define FO_400                    0xF0
#define REG_RXPARAM2                     18
   // Rx Param 2
   // Polyphase filter enable
   #define POLYPFILT_ON              0x80
   #define POLYPFILT_OFF             0x00
   #define DEF_RXPARAM2            0x20
   #define SYNC_ON                  0x20   //[5] - 0 - off, 1 - on
   #define SYNC_SIZE_8               0x00   //[4:3] - 00 - 8 bits
   #define SYNC_SIZE_16            0x08
   #define SYNC_SIZE_24            0x10
   #define SYNC_SIZE_32            0x18
   #define SYNC_ERRORS_0            0x00   //[2:1] - 00 - 0 error
   #define SYNC_ERRORS_1            0x02
   #define SYNC_ERRORS_2            0x04
   #define SYNC_ERROS_3            0x06
#define REG_RXPARAM3                     19            //Reserved
   #define DEF_RXPARAM3            0x07
#define REG_RSSIVALUE                    20
   //RSSI value (READ ONLY)
#define REG_OOKSETTINGS                  21
   // Rx Param 5
   // Decrement step of RSSI threshold in OOK demodulator (peak mode)
   #define OOK_THRESH_DECSTEP_000    0x00
   #define OOK_THRESH_DECSTEP_001    0x20
   #define OOK_THRESH_DECSTEP_010    0x40
   #define OOK_THRESH_DECSTEP_011    0x60
   #define OOK_THRESH_DECSTEP_100    0x80
   #define OOK_THRESH_DECSTEP_101    0xA0
   #define OOK_THRESH_DECSTEP_110    0xC0
   #define OOK_THRESH_DECSTEP_111    0xE0
   // Decrement period of RSSI threshold in OOK demodulator (peak mode)
   #define OOK_THRESH_DECPERIOD_000  0x00
   #define OOK_THRESH_DECPERIOD_001  0x04
   #define OOK_THRESH_DECPERIOD_010  0x08
   #define OOK_THRESH_DECPERIOD_011  0x0C
   #define OOK_THRESH_DECPERIOD_100  0x10
   #define OOK_THRESH_DECPERIOD_101  0x14
   #define OOK_THRESH_DECPERIOD_110  0x18
   #define OOK_THRESH_DECPERIOD_111  0x1C
   // Cutoff freq of average function of RSSI threshold in OOK demodulator (average mode)
   #define OOK_THRESH_AVERAGING_00   0x00
   #define OOK_THRESH_AVERAGING_11   0x03
#define REG_SYNCBYTE0                    22
#define REG_SYNCBYTE1                    23
#define REG_SYNCBYTE2                    24
#define REG_SYNCBYTE3                    25
#define REG_TXPARAM                      26
   // TX Param
   // Interpolator filter Tx (kHz)
   #define FC_VALUE                   0x70
   #define FC_25                      0x00
   #define FC_50                      0x10
   #define FC_75                      0x20
   #define FC_100                     0x30
   #define FC_125                     0x40
   #define FC_150                     0x50
   #define FC_175                     0x60
   #define FC_200                     0x70
   #define FC_225                     0x80
   #define FC_250                     0x90
   #define FC_275                     0xA0
   #define FC_300                     0xB0
   #define FC_325                     0xC0
   #define FC_350                     0xD0
   #define FC_375                     0xE0
   #define FC_400                     0xF0
   #define TXPOWER_13               0x00   //[3:1] - 13dB
   #define TXPOWER_10               0x02
   #define TXPOWER_7                  0x04
   #define TXPOWER_4                  0x06
   #define TXPOWER_1                  0x08
   #define TXPOWER_2                  0x0A
   #define TXPOWER_5                  0x0C
   #define TXPOWER_8                  0x0E
#define REG_OSCPARAM                     27
   // OSC Param
   // CLKOUT enable
   #define CLKOUT_ON                 0x80
   #define CLKOUT_OFF                0x00
   // CLKOUT frequency (kHz)
   #define CLKOUT_12800              0x00
   #define CLKOUTint64_t00           0x04
   #define CLKOUT_3200               0x08
   #define CLKOUT_2133               0x0C
   #define CLKOUT_1600               0x10
   #define CLKOUT_1280               0x14
   #define CLKOUT_1067               0x18
   #define CLKOUT_914                0x1C
   #define CLKOUT_800                0x20
   #define CLKOUT_711                0x24
   #define CLKOUT_64                0x28
   #define CLKOUT_582                0x2C
   #define CLKOUT_533                0x30
   #define CLKOUT_492                0x34
   #define CLKOUT_457                0x38
   #define CLKOUT_427                0x3C
#define REG_PKTPARAM0                    28
   #define MANCHESTER_ON            0x80   //[7] 0 - off, 1 - on
   #define MANCHESTER_OFF            0x00
#define REG_NODEADDRESS                  29
#define REG_PKTPARAM2                    30
   #define PKT_FORMAT_FIXED         0x00   //[7] 0 - fixed length, 1- variable length
   #define PKT_FORMAT_VARIABLE         0x80
   #define PREAMBLE_SIZE_1            0x00    //[6:5] 00 - 1 byte
   #define PREAMBLE_SIZE_2            0x20
   #define PREAMBLE_SIZE_3            0x40
   #define PREAMBLE_SIZE_4            0x60
   #define WHITENING_ON            0x10   //[4] 0 - off, 1 - On
   #define WHITENING_OFF            0x00
   #define CRC_ON                  0x08   //[3] 0 - off, 1 - On
   #define CRC_OFF                  0x00
   // Address filtering
   #define ADRSFILT_NONE            0x00   /* no filtering */
   #define ADRSFILT_ME_ONLY         0x02   /* only Node_adrs accepted (register 29) */
   #define ADRSFILT_ME_AND_00         0x04   /* Node_adrs and 0x00 accepted */
   #define ADRSFILT_ME_AND_00_AND_FF   0x06   /* Node_adrs and 0x00 and 0xff accepted */
#define REG_PKTPARAM3                    31
   #define FIFO_AUTOCLR_ON            0x00   //[7] 0 - On, 1 - Off
   #define FIFO_AUTOCLR_OFF         0x80
   #define FIFO_STBY_ACCESS_WRITE      0x00   //[6] 0 - Write, 1 - Read
   #define FIFO_STBY_ACCESS_READ      0x40
TX.C
#include <18f46k20.h>
#fuses   INTRC       // Internal RC Osc
#fuses   NODEBUG    // No Debug mode for ICD
#fuses   NOWRT       // Program memory not write protected
#fuses   NOCPD       // No EE protection
#fuses   NOLVP       // No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#fuses   NOPUT       // No Power Up Timer
#fuses   NOBROWNOUT    // Reset when brownout detected
#fuses   BORV30       // Brownout reset at 3.0V
#fuses   NOWDT       // No Watch Dog Timer
#fuses   MCLR        // Master Clear pin enabled
//        Clock
#use delay(internal=4000000, restart_wdt) // inclure procédure de délais (delay_ms() et delay_us())
//        Define
// CSCON    => D2
// CSDATA   => D0
// SDI      => C5
// SDO      => C4
// SCK      => C3
// IRQ0     => NC
// IRQ1     => NC
// RESET    => D1
#define PACKET_LEN 64
#define CSDATA    PIN_D0  // Serial Interface CS data
#define CSCON     PIN_D2  // Serial Interface CS Conf
#define RESET     PIN_D1   // Reset
//        Global
int8 RF_Mode;
int8 TxPacket[PACKET_LEN];
int8 RxPacketLen=0;
int8 RxPacket[PACKET_LEN];
int1 hasPacket = FALSE;
//        Debug
int8 Dnode_adrs;
int8 DRxPacketLen;
//        Include
#include <MRF89XA.c>
//        Main
output_high(CSCON);
output_high(PIN_C6); // pin Power ON
output_high(PIN_B2); // Led Green
output_high(RESET);  // reset pin
//Setup OSC
setup_oscillator(OSC_4MHZ|OSC_INTRC);
//Setup SPI
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H );
//Init radio
MRF89XAInit();
//TX
TxPacket[0] = 1;
TxPacket[1] = 2;
TxPacket[2] = 3;
TxPacket[3] = 4;
// RX
RxPacket[0] = 0;
   //send
   output_high(PIN_B5); //led blue
   Send_Packet(64);
   output_low(PIN_B5); // led blue
RX.C
//        Clock
//        Define
// CSCON    => D2
// CSDATA   => D0
// SDI      => C5
// SDO      => C4
// SCK      => C3
// IRQ0     => NC
// IRQ1     => NC
// RESET    => D1
//        Global
int8 RF_Mode;
int8 RxPacketLen=0;
//        Debug
int8 Dnode_adrs;
int8 DRxPacketLen;
//        Include
//        Main
delay_ms(2000);
output_high(CSCON);
//Setup OSC
//Setup SPI
//Init radio
MRF89XAInit();
//TX
TxPacket[0] = 1;
TxPacket[1] = 2;
TxPacket[2] = 3;
TxPacket[3] = 4;
// RX
RxPacket[0] = 0;
   SetRFMode(RF_RECEIVER);
   ReceiveFrame();
   if (RXpacket[0]==1)
      output_high(PIN_B5); // led Blue
      output_low(PIN_B5);  // led Blue
Fifo in RX is always empty, I don't use IRQ0 and IRQ1 for the moment.
PostPosted: Tue Feb 05, 2019 11:47 am     Reply with quote
Without looking at all the code...a couple of 'low level' questions...
1) do you have the correct power for the devices ? Most 'peripherals' are 3 volts these days...have you enough current to power it as well ?
2) can you actually set and read various registers of the device for both xmtr and rcvr units ??
Jay
in_nursery
PostPosted: Tue Feb 05, 2019 2:45 pm     Reply with quote
So voltage is 3.3V
after some small issue I check that I can read and write configuration on each.
but still no RX.
I change:
#fuses INTRC_IO
and
output_low(RESET); // reset pin
