ADC trouble
Drone601
ADC trouble
PostPosted: Tue Jan 29, 2019 12:07 pm     Reply with quote
Hi all, and a preemptive thanks.
I'm new to ADC, and trying to use it on a PIC16F18345. The trouble seems to be that the pin I'm trying to use for ADC goes into a permanent pull-down state. Any voltage applied just gets sunk to near 0V and the ADC value doesn't change. But that pin works fine when I use it as a standard input. So the error seems to be me. Did try setup_adc_ports(sAN4, VSS_VDD), but that didn't help. Suggestions? Condemnations? Aspersions?
#include <16F18345.h>
#fuses PUT,RSTOSC_HFINTRC_PLL,BROWNOUT,NOMCLR,NOCLKOUT,NOEXTOSC,PROTECT
#use delay(internal=4000000)
#use RS232(baud=9600, xmit=PIN_A0, ERRORS)
#define LCD_INIT       22
#define LCD_CLR_DSP    12
#define TX PIN_A0
    set_tris_a(00111010);
    set_tris_b(00000000);
    set_tris_c(00000000);
    int16 r;
    setup_adc_ports(sAN4);
    setup_adc(ADC_CLOCK_DIV_8);
    set_adc_channel(0);
   output_high(TX); // LCD handling stuff
   delay_ms(100);   // ""
   putc(LCD_INIT);  // ""
   putc(LCD_CLR_DSP);  // ""
   delay_ms(5); // ""
      r =read_adc();
      printf("AD is  %4LD \r\n", r);
PostPosted: Tue Jan 29, 2019 12:32 pm     Reply with quote
set_adc_channel(0);
You've set it up to use ch. 4 in the 1st line, but then you select channel 0.
You should select channel 4 in the 3rd line.
Drone601
PostPosted: Tue Jan 29, 2019 2:15 pm     Reply with quote
Ah, right. Embarassed I had changed that in panicked random button pushing. Thanks!
And yes, that did help greatly. But...still have a problem with the pin pulling down the voltage too much. As soon as I connect to that pin...vooop. It's gone. I'd think I'd fried the port, but it works (or at least did last I checked) in non-ACD mode.
PostPosted: Tue Jan 29, 2019 2:43 pm     Reply with quote
What is the nature of the source feeding the ADC?.
The maximum recommended impedance for any source is 10KR.
Drone601
PostPosted: Tue Jan 29, 2019 3:05 pm     Reply with quote
It's a phototransistor. I *seem* to be connecting it as recommended by the manufacturer and some examples online. Surely it's just me being a dolt, trying to hammer it in with a rock or something.
newguy
PostPosted: Tue Jan 29, 2019 3:11 pm     Reply with quote
Can you post a schematic please?
dluu13
PostPosted: Tue Jan 29, 2019 3:20 pm     Reply with quote
Ttelmah makes a good point. You can use a opamp buffer to ensure that you have a nice low impedance output to drive your ADC pin. If you are expecting voltages close to zero, make sure you get a negative power rail for your opamp, or use one with rail to rail output.
PostPosted: Tue Jan 29, 2019 3:26 pm     Reply with quote
Most (all) photoransistors are a very nonlinear device (actually log ) so you'll need to calibrate the PIC program for each device. Mfrs post the graphs with the device info. As stated using a in/out rail-to-rail opamp will help.
Jay
