Icd-u40
JerryR
Icd-u40
PostPosted: Sun Oct 07, 2018 4:29 pm     Reply with quote
I have a bunch of CCS ICD-40 debuggers. Are they still usable with CCS IDE? Debugger reports communication error and does not connect. Connects and operates fine with ICD-U64. Thanks
PostPosted: Mon Oct 08, 2018 12:33 am     Reply with quote
They should work.
Just plugged one in, and it is merrily seen by CCSLoad. Had to update the firmware, but it was then recognised, and successfully programmed a chip.
In fact it accepted a chip that a few months ago was 'not supported', following the update. Smile
JerryR
PostPosted: Mon Oct 08, 2018 5:07 am     Reply with quote
Thanks for the reply. I’ll update the firmware and give it a try. Regards
PostPosted: Mon Oct 08, 2018 6:32 am     Reply with quote
Did have an issue a while ago, with a 'not communicating' error, when I tried to use an unpowered hub. Remember they do draw noticeable power.
JerryR
PostPosted: Mon Oct 08, 2018 8:42 am     Reply with quote
Ttelmah:
Thanks again. That may be the issue. I'll use a powered hub and try again.
Regards
drolleman
PostPosted: Mon Oct 08, 2018 3:50 pm     Reply with quote
I have found the most reliable way, is not to use a usb hub at all.
dave
dyeatman
PostPosted: Wed Oct 10, 2018 4:21 pm     Reply with quote
I plug mine directly into the front USB port on my desktop computer and it has
always worked with no problems.
Google and Forum Search are some of your best tools
PostPosted: Wed Oct 10, 2018 5:11 pm     Reply with quote
also..
Check the USB port settings it's plugged into.!
Somehow, some program or 'ap' CHANGED the current limit on one of my PC's USB ports ! I have no idea how or when or why...just went through the dbl toothpicks thinking that I had done something.
Once I saw it (using USBView) I was able to change it back to full power.
That was 2-3 years ago..still bugs me that it happened.
Jay
