Booleans and printf?
JAM2014
PostPosted: Thu Sep 27, 2018 8:23 pm     Reply with quote
Hi All,
I’d like to send the state of two Boolean (int1) variables via printf, but there doesn’t seem to be a specific specifier for this purpose in CCS C? Other than encode the 2 variables into decimal value and then decode on the receiving end, is there another way?
Jack
PostPosted: Thu Sep 27, 2018 9:27 pm     Reply with quote
If you want to send 0 or 1, then use %c with printf. But be aware that
printf will still send a byte. The byte will be 0x00 or 0x01. Example:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
int1 temp;
temp = 1;
printf("%c", temp);
while(TRUE);
JAM2014
PostPosted: Mon Oct 01, 2018 9:38 am     Reply with quote
Hi PCM,
Thanks for the input! That method didn't really work for me (PCH v5.050), but I'm not sure if it was the compiler, the Hyperterminal representation, or my VB application? When I attempted to send the boolean variables using '%c' and printf, the response seemed somewhat unpredictable. Sometimes it would print '0', sometimes a space ' ', and sometimes a smiley face.
I ended up doing this instead:
OutputStatus = 0;
if (bCoolingOn) OutputStatus += 1;
if (bHeatingOn) OutputStatus += 2;
printf(usb_cdc_putc, "!PID:P:%03d,%03d,%u,%03d,%03u\r", ProcessTemp, SetpointTemp, OutputStatus, Error, PWMCommand);
Jack
PostPosted: Mon Oct 01, 2018 10:00 am     Reply with quote
just a comment..
Since you send a byte anyway...Why not just send an 'H' for Heating, On, 'C' for Cooling and '-' for off ? 'h' could mean 'heating mode but off, c for cooling mode but off...
Jay
newguy
PostPosted: Mon Oct 01, 2018 12:12 pm     Reply with quote
temtronic wrote:
just a comment..
Jay
Big +1 from me regarding this approach. Very explicit. No ambiguity.
PostPosted: Mon Oct 01, 2018 12:25 pm     Reply with quote
yeah the older you get, the easier you need computers to tell you 'stuff'. I've yet to figure out how to get Win7 to 'bkp/restore' like XP (like pick a day from the calendar'...
sigh..
Jay
PostPosted: Mon Oct 01, 2018 12:43 pm     Reply with quote
and (of course) it is worth remembering that in C you can give an output character from a boolean with the syntax:
(temp==TRUE)?'H':'C'
which will return the character 'H' or 'C' according to whether 'temp' is TRUE or FALSE.
