Error in Adc Pic 16F886
jose_pic16f887
PostPosted: Thu Sep 06, 2018 1:18 pm     Reply with quote
Friends, best regards, I am commenting on a digital voltmeter with pic 16f886 to use the ADC but when compiling I get an error, this is a part of the code, well I am using the internal oscillator of the pic.
#include <16f886.h>
#fuses intrc,nowdt
#use delay(clock=4Mhz)
#device ADC=10
#define use_portb_lcd TRUE
#include <LCD.C>
#include <math.h>
#use standard_io (All)
float t;
float s;
 void med_ir ()
  setup_adc_ports (AN0);
  setup_adc (ADC_CLOCK_DIV_32);
  set_adc_channel (0);
  delay_us (20);
  t = read_adc();
  s= 5.0 *t / 1024;
the compiler is located in Instruction # Device ADC = 10
and this is the mistakes:
Compiling I:\Proyecto CCs Compiler\Volt3 on 06-sept.-18 at 14:09
*** Error 23 "Volt3.c" Line 4(9,15): Can not set this option this far into the code
*** Error 12 "Volt3.c" Line 14(20,23): Undefined identifier AN0
2 Errors, 0 Warnings.
Build Failed.
I hope you can help me friends and thanks.
Confused
fernandokestering
PostPosted: Thu Sep 06, 2018 2:19 pm     Reply with quote
Correct code:
#include <16f886.h>
#device adc=10
#fuses intrc,nowdt
#include <LCD.C>
#include <math.h>
float t;
float s;
void main ()
setup_adc_ports (sAN0);
delay_us (20);
t = read_adc();
s= 5.0 *t / 1024;
jose_pic16f887
PostPosted: Fri Sep 07, 2018 7:57 am     Reply with quote
thank you very much friend for helping me, the code compiled without any error, can you please tell me what were my errors in my code and thanks Question
dyeatman
PostPosted: Sat Sep 08, 2018 6:19 am     Reply with quote
Processor include and #device lines have to always come first, then the fuses.
Google and Forum Search are some of your best tools!!!!
