Passing a String in a function is it possible.
David Pouzar
PostPosted: Fri Aug 31, 2018 11:21 am     Reply with quote
I am hoping there is a better way to rewrite this piece of code. It is from a vendor library.
Original Code (not modified)
Writes a string of characters to the destination device.
This method must be used after the SPI interface has started.
@param  data The data to be transmitted.
@return none
void writeStringSPI(char* data){
  for(int i = 0; i < arraySize(data); i++)
    while(!(UCB0IFG & UCTXIFG)); // Check to see if transmit buffer is empty
    UCB0TXBUF = data[i];
Modified (does not compile)
@return none
  for(int i = 0; i < strlen(data); i++)
      spi_xfer(SPI_STREAM,data[i],8);
Error#90 Attempt to create a pointer to a constant.
I know I can do replace this piece of code with a prinf like below,
printf(writeString2SPI,"INSTANT FLOW RATE");
void writeString2SPI(char b)
   spi_xfer(SPI_STREAM,b,8);
I am hoping someone has a better idea for me.
PostPosted: Fri Aug 31, 2018 11:32 am     Reply with quote
The problem is not in what you post. It is in where you call it.
You are presumably using something like:
WriteString("Something");
Problem at this point is that "Something", is a constant string (stored in ROM). This can't have a pointer constructed to it. Hence the warning.
Solutions:
1) Add #device PASS_STRINGS=IN_RAM
at the top of your code just after the processor include. This makes the compiler automatically copy constant strings into RAM and allow a pointer to be constructed to this, using a small RAM buffer.
2) strcpy the constant strings to RAM buffers, and pass this to the function. Does the same thing really, but you are doing it manually.
David Pouzar
PostPosted: Fri Aug 31, 2018 12:16 pm     Reply with quote
That worked thank you for the help. Very Happy
