| View previous topic :: View next topic   |
			David Pouzar
				| Noritake GT800X480A-C903P SPI seems to not working |
				 Posted: Fri Aug 24, 2018 1:15 pm     |
				Has anyone worked with this display in an i2c or spi interface?  I am using dsPIC33FJ128GP708A.  I have an 2 SPI temperature sensors that work ok.  I am using one of the their inputs to interface with the display.  I download their libraries but could not make sense of them. They were not written in CCS. It could be that it is Friday and my brain is toasted?
GTCP_SPI_Interface.c
@author Cody Johnson
@email support.ele@noritake.com
@website noritake-elec.com
@version v1.1 (ME-N59-1)
@ide IAR
@brief SPI library for MSP430 (MSP-EXP430F5529LP) and Noritake GT-CP modules.
@verbatim
Provide the SPI interface between MSP430 (MSP-EXP430F5529LP) and Noritake GT-CP modules.
@endverbatim
#include "GTCP_SPI_Interface.h"
#include "stdint.h"
#include <stddef.h>
int dataRead;
int statusRead;
int bytesToRead;
Initializes the SPI interface for MSP430 to communicate with a Noritake
GTCP series module.
Wiring reference:
  CS -> P8.1
  MBUSY -> P4.0
  MOSI -> P3.0
  MISO -> P3.1
  SCK -> P3.2
@return none
void initSPI(){
  interface = 1; // interface identifier set to SPI
  WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
  P1DIR |= 0x01; //Set P1.0 for LED1 (DEBUG)
  P2DIR |= BIT6; //Set P2.6 to an output for CS
  P2OUT |= BIT6; // Set CS
  P4DIR &= ~0x01; //Set P4.0 for MBUSY input
  P3SEL |= BIT0 + BIT1 + BIT2; // Select P3.0 (MOSI), P3.1(MISO), P3.2(SCLK) for SPI
  UCB0CTL1 |= UCSWRST; // Hold USCI logic in reset state
  UCB0CTL0 |= UCMST; // Master mode
  UCB0CTL0 |= UCSYNC; // Synchronous mode
  UCB0CTL0 |= UCCKPL; // High clock polarity
  UCB0CTL0 |= UCMSB; // MSB first
  UCB0CTL1 |= UCSSEL_3; // Use the SMCLK
  UCB0BR0 = 0x00; // Bit clock prescaler low byte
  UCB0BR1 = 0x00; // Bit clock prescaler high byte
  UCB0CTL1 &= ~UCSWRST; //Release USCI logic for use
  //UCB0IE |= UCRXIE; //Enable RX interrupt
  //UCB0IE |= UCTXIE; //Enable TX interrupt
  P1OUT &= ~0x01;
Starts SPI write communication.
@return none
void beginWriteSPI(){
  P2OUT &= ~BIT6; // Lower CS
  while(P4IN & 0x01); //Check MBUSY
  while(!(UCB0IFG & UCTXIFG)); // Check to see if transmit buffer is empty
  UCB0TXBUF = 0x44; // Send write identifier
Ends SPI communication
@return none
void endSPI(){
  __delay_cycles(1);
Writes a character to the destination device.
This method must be used after the SPI interface has started.
@param  data The character to be transmitted.
@return none
void writeSPI(char data){
  UCB0TXBUF = data;
  while(!(UCB0IFG & UCRXIFG)); // Check to see if transmit buffer is empty
Writes a string of characters to the destination device.
@param  data The data to be transmitted.
@return none
void writeStringSPI(char* data){
  for(int i = 0; i < arraySize(data); i++){
    UCB0TXBUF = data[i];
Initialize the GTCP series display.
@return none
void initGTCP(){
  UCB0TXBUF = 0x1b;
  UCB0TXBUF = 0x40;
Start the read sequence for SPI.
@return none
void startSPIRead(){
  UCB0TXBUF = 0x54; // Send data read identifier
Reads in a single byte from the connected device.
@return The data read from the device.
uint8_t singleSPIRead(){
  uint8_t rxdata;
  UCB0TXBUF = 0x00; // Send dummy byte
  while(!(UCB0IFG & UCRXIFG)); // think i need this check or else i get garbage
  rxdata = UCB0RXBUF;
  return rxdata;
void readSPI(char* data){ // break into startRead, Read and endRead
  uint8_t rxdata;
  if(bytesToRead <= 63){
    for(int i = 0; i < bytesToRead + 1; i++){
        UCB0TXBUF = 0x00;
        while(!(UCB0IFG & UCRXIFG)); // think i need this check or else I get garbage
        rxdata = UCB0RXBUF;
        if(rxdata == 0x11){
          dataRead = 0;
        data[i] = rxdata;
    P2OUT |= BIT6; // Release CS
Reads the status byte from the device.
@return The number of bytes to be read from the device.
int readSPIStatus(){
  int incomingByte = 0;
  bytesToRead = 0;
  //P8OUT &= ~BIT1; // Lower CS
  P2OUT &= ~BIT6;
  UCB0TXBUF = 0x58; // Send status read identifier
  UCB0TXBUF = 0x00;
  while(!(UCB0IFG & UCRXIFG)); // Check to see if receive buffer has a byte of data
  incomingByte = UCB0RXBUF; // Read data from receive buffer
  __delay_cycles(10); // Avoids a screen clear soft lock error but breaks reading
  if((incomingByte & 0x40) == 0){
    bytesToRead = incomingByte & 0x3F;
  P8OUT |= BIT1; // Release CS
  P2OUT |= BIT6;
  return bytesToRead;
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void){
  switch(__even_in_range(UCB0IV, 4)){
  case 0: //Vector 0 - No Interrupt
  case 2: //Vector 2 - RXIFG
    //__disable_interrupt();
    if(statusRead){
      bytesToRead = UCB0RXBUF;
      statusRead = 0;
    if(dataRead){
      for(int i = 0; i < bytesToRead; i++){
        //RxDataArray[i] = UCB0RXBUF;
      dataRead = 0;
    P8OUT |= BIT1;
  case 4:
  default:
@ide IAR
@verbatim
@endverbatim
#ifndef GTCP_SPI_INTERFACE_H
#define GTCP_SPI_INTERFACE_H
#include "io430.h"
#include "stdint.h"
extern int interface;
void initSPI();
void beginWriteSPI();
void endSPI();
void writeSPI(char data);
void writeStringSPI(char* data);
void initGTCP();
void startSPIRead();
uint8_t singleSPIRead();
void readSPI();
int readSPIStatus();
__interrupt void USCI_A0_ISR(void);
#endif
				 Posted: Fri Aug 24, 2018 1:54 pm     |
				That is written for a different processor, so you are going to have to flow chart what it actually does, and then translate this to match the ports you want to use on the PIC. So:
void initSPI(){
  P1OUT &= ~0x01;
1) Disable watchdog.
2)
#define LED_OUT PIN_xx //whatever pin you are using
#define CHIP_CS PIN_yy //whatever pin you are using.
3)
#USE SPI (SPI1, MODE=3, BAUD=4000000)
//The clock supports up to 8MHz max SPI, all transfer on rising edge
//clock idles high = MODE3
4)
enable_interrupts(INT_SPI1);
This is the equivalent to this paragraph.
Then for example:
  UCB0TXBUF = data;
If simply:
val=spi_xfer(data);
Reading the return value here ensure the transfer waits to complete (which is what their function does).
etc. etc.. |
			David Pouzar
				| The Fog is clearing a little bit |
				 Posted: Mon Aug 27, 2018 6:29 am     |
				Thank you Ttelmah.  I will be starting that today.  I just needed a refresher, love converting code.     I still think this is the best approach?      |
				 Posted: Mon Aug 27, 2018 6:39 am     |
				I'd sit down and work out the basic pin equivalences 'first'. So, it has:
  CS -> P8.1
  MBUSY -> P4.0
  MOSI -> P3.0
  MISO -> P3.1
  SCK -> P3.2
and
P1.0 for an LED
So draw a table:
P8.1 = PIN_A0 (for example).
Then you can type these equivalents into the code, and perhaps a third of the changes are already done!... |
			David Pouzar
				 Posted: Mon Aug 27, 2018 6:42 am     |
				| Wonderful idea.. |
