put .hex file on 24LC32A via mach x?
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
picj1984
PostPosted: Tue Jul 17, 2018 11:30 am     Reply with quote
Pretty much the subject.
I've got a hex file from a partner that I'm trying to put on a 24LC32A. I have a mach x laying around and I assumed I could use that. It seems in the "devices" drop down on mach x that the only thing that is there are microcontrollers - not eeproms like the 24LC32A.
Is there a way to do this with the mach x?
PostPosted: Sat Jul 21, 2018 2:07 pm     Reply with quote
CCS doesn't list eeproms in the Device Support list for MachX:
http://www.ccsinfo.com/devices.php?page=icddevices
You could read the eeprom hex data into a PIC, and then program it
into the eeprom with write_ext_eeprom() statements. That's one way to
do it, if you don't have a dedicated eeprom programmer.
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
