Using 2 Analog Input channels on PIC18F4520
Dean
PostPosted: Tue Jan 30, 2018 5:41 am     Reply with quote
Hi Everyone
I am trying to read two analog inputs on the PIC18F4520,
looks like my problem is simple however I could not solve it.
The program keeps giving me an error when I define the second input pin ( AN1 ).
It works fine with ( AN0) input pin, but gives error ( Undefined Identifier AN1 ) when AN1 pin is added .
AN0 is not defined by me in the code, so AN1, where should I define AN1 pin if that is the case ??
This is the code
#include <TestAnalogRead.h>
void Antest()
      setup_adc_ports(ALL_ANALOG);
      setup_adc_ports(AN0);                 //sets   AN0 pin  to analog input
      setup_adc_ports(AN1);                 //sets  AN1 pin  to analog input
      set_adc_channel(0);                    //the next read_adc call will read
channel 0
      setup_adc(ADC_CLOCK_DIV_4);
  //    setup_adc_ports( ALL_ANALOG );
  //    setup_adc(ADC_CLOCK_INTERNAL );
  //    set_adc_channel( 0 );
  //    value = read_adc();
  //    setup_adc( ADC_OFF );
   setup_adc_ports(AN0_TO_AN3);
      //TODO: User Code
and the code in the *.h file is
#include <18F4520.h>
#device ADC=10
#use delay(crystal=20000000)
I did set All analog to pins and this is supposed to make AN0 to AN4 pins
analog input. Any ideas for the reason of this error ?
Dean
Find a way Or Make one .
PostPosted: Tue Jan 30, 2018 6:04 am     Reply with quote
I'd open up the device header and look at the list. In the ADC section it'll show the valid (known) variables.
This is from the header....
// Constants used in SETUP_ADC_PORTS() are:
// First argument:
#define NO_ANALOGS   0x0F   // None
#define ALL_ANALOG   0x00   // A0 A1 A2 A3 A5 E0 E1 E2 B2 B3 B1 B4 B0
#define AN0_TO_AN11  0x03   // A0 A1 A2 A3 A5 E0 E1 E2 B2 B3 B1 B4
#define AN0_TO_AN10  0x04   // A0 A1 A2 A3 A5 E0 E1 E2 B2 B3 B1
#define AN0_TO_AN9   0x05   // A0 A1 A2 A3 A5 E0 E1 E2 B2 B3
#define AN0_TO_AN8   0x06   // A0 A1 A2 A3 A5 E0 E1 E2 B2
#define AN0_TO_AN7   0x07   // A0 A1 A2 A3 A5 E0 E1 E2
#define AN0_TO_AN6   0x08   // A0 A1 A2 A3 A5 E0 E1
#define AN0_TO_AN5   0x09   // A0 A1 A2 A3 A5 E0
#define AN0_TO_AN4   0x0A   // A0 A1 A2 A3 A5
#define AN0_TO_AN3   0x0B   // A0 A1 A2 A3
#define AN0_TO_AN2   0x0C   // A0 A1 A2
#define AN0_TO_AN1   0x0D   // A0 A1
#define AN0          0x0E   // A0
#define AN0_TO_AN11_ANALOG     0x03   //!old only provided for compatibility
#define AN0_TO_AN10_ANALOG     0x04   //!old only provided for compatibility
#define AN0_TO_AN9_ANALOG      0x05   //!old only provided for compatibility
#define AN0_TO_AN8_ANALOG      0x06   //!old only provided for compatibility
#define AN0_TO_AN7_ANALOG      0x07   //!old only provided for compatibility
#define AN0_TO_AN6_ANALOG      0x08   //!old only provided for compatibility
#define AN0_TO_AN5_ANALOG      0x09   //!old only provided for compatibility
#define AN0_TO_AN4_ANALOG      0x0A   //!old only provided for compatibility
#define AN0_TO_AN3_ANALOG      0x0B   //!old only provided for compatibility
#define AN0_TO_AN2_ANALOG      0x0C   //!old only provided for compatibility
#define AN0_TO_AN1_ANALOG      0x0D   //!old only provided for compatibility
#define AN0_ANALOG             0x0E   //!old only provided for compatibility
As you can see 1/2 way down, how CCS wants you to select AN0 and AN1.
This is explained in the comments of the ADC section of the header. It's a good reason as to why you should open and look at device headers. There's also comments for the other internal peripherals so it is a 'must read'.
You should always post your compiler version...the error could be a bug.
Jay
PostPosted: Tue Jan 30, 2018 7:04 am     Reply with quote
The key lesson here is:
Read the header file for your chip.
A lot of the more modern PIC's do allow you to select analog port pins in any combination you want. This one is an older chip where they can only be selected in certain patterns.
The other thing though is that settings like this are not cumulative. Each setup_adc_ports line overrides the one before.
There are then a couple of other comments (made in remarks):
//Nothing is ever calling this function
void Antest()
channel 0
      //If this was being called is this legitimate for 10MHz?.
      //No - maximum clock rate for this division is 5.71MHz (data sheet).
      //You need ADC_CLOCK_DIV_16 for a 20Mhz clock.....
//This is your whole program
   //port is setup, but not the clock.
      //No adc reading is ever actually made....
      //TODO: User Code
Dean
PostPosted: Wed Jan 31, 2018 3:00 am     Reply with quote
Thank you guys, problem solved.
Just had to define AN1 the way the header states.
Very Happy Very Happy
PostPosted: Wed Jan 31, 2018 8:39 am     Reply with quote
Hopefully though you have corrected the ADC clock as well. Smile
