Pcb interface
aaronik19
Pcb interface
PostPosted: Tue Jan 09, 2018 10:03 am     Reply with quote
Dear all i have a question and i think it will be suitable to everyone. What is calling this type of pcb layout? Seems like a pcb stamp shape. Is there any adaptors for dil?
PostPosted: Tue Jan 09, 2018 10:30 am     Reply with quote
'leadless' ?
What you do is solder pins to each of the gold U shaped areas that are the 'pinouts'.
Be sure to measure the spacing or check the datasheet as they can be either metric or std (.1") !
Usually the seller supplies 2 'strips' of pins to allow you to plug the module into a socket or breadboard.
Jay
Re: Pcb interface
PostPosted: Tue Jan 09, 2018 11:48 am     Reply with quote
Castllated holes:
http://prototypepcb.com/castellated-holes/
https://learn.sparkfun.com/tutorials/how-to-solder---castellated-mounting-holes
Also they are called plated "half holes":
https://www.multi-circuit-boards.eu/en/pcb-design-aid/drills-throughplating/plated-half-holes.html
PostPosted: Tue Jan 09, 2018 1:13 pm     Reply with quote
The data sheet for the module gives the PCB pad layout required. Remember you must _not_ have a ground plane or power plane under the antenna area. This needs to be sticking out beyond the tracking or have a large void.
aaronik19
PostPosted: Tue Jan 09, 2018 2:57 pm     Reply with quote
Thanks to all for your help. Hope that others will find this query useful as well.
