33EP512GP806 and fprintf (FIXED)
-Terppa-
PostPosted: Mon Jan 08, 2018 11:48 am     Reply with quote
Hello.
I try to put some data to serial port but i can only see "0x00" on windows terminal. Is there problem processor fuses or serial port init?
Thank you for your help.
PIC: 33EP512GP806
Compiler: CCSC PCWHD 5.074
Computer: win7 ultimate x64
Processor FUSES:
#fuses HS, NOWDT, PR, WPOSTS16, NOCKSNOFSM
#use delay(CRYSTAL=10MHz)
Serialport init:
#pin_select U1TX=pin_d7
#pin_select U1RX=pin_d6
#USE RS232(stream=UART1, ERRORS, BAUD=115200, STREAM=HW_CONSOLE)
Main:
fprintf(HW_CONSOLE, "\n\rTesting\n\r");
PostPosted: Mon Jan 08, 2018 12:18 pm     Reply with quote
While I don't use that PIC, this line..
may not be legal....
others may know for sure.
PostPosted: Mon Jan 08, 2018 12:22 pm     Reply with quote
Get rid of the "stream=" and it will probably work.
-Terppa-
PostPosted: Mon Jan 08, 2018 12:30 pm     Reply with quote
I'm not noticed that dual stream name at all! Fixed lines is now:
Now setup is:
#USE RS232(stream=UART1, ERRORS, BAUD=115200)
fprintf:
fprintf(UART1,"Testing..\n\r");
Still one "0x00" mark is coming terminal..
PostPosted: Mon Jan 08, 2018 1:08 pm     Reply with quote
What is the hardware between PIC and PC ?
-Terppa-
PostPosted: Mon Jan 08, 2018 3:21 pm     Reply with quote
It is cheap chinese usb to rs232 module. I think driver is something like CH3xxx. This problem is very strange because it always put that one 0x00 and that's it. Even it there is text "testing.."
-Terppa-
PostPosted: Mon Jan 08, 2018 3:30 pm     Reply with quote
Hmmm.. Can it be max232 circuit on PIC board? Maybe it is 5v version..I check that tomorrow because clock is 11:29am
-Terppa-
PostPosted: Tue Jan 09, 2018 5:38 am     Reply with quote
Fixed!!
I made a new circuit board an different rs232, still same.
I changed a different USB- converter, still same.
code change
this:
#USE RS232(ERRORS, BAUD=115200, STREAM=HW_CONSOLE)
to this:
#use rs232(UART1, baud=115200, ERRORS, stream=HW_CONSOLE)
Maybe I was too tired and did not look at my code exactly enough Embarassed
