Porting from 16F877 to 16F18877
DonWells
PostPosted: Thu Jan 04, 2018 5:08 pm     Reply with quote
I have recently upgraded to CCS V5.075 so as to get support for the more modern chips.
I am now porting a working application from a 16F877 to a 16F1887.
All appears to be working file except for UART Rx.
Tx works ok.
Any suggestions as to what I might have missed?
PostPosted: Thu Jan 04, 2018 5:39 pm     Reply with quote
We'd have to see code to decide what's wrong. That big nor'easter has obscured my xtal ball.
Post a short, complete program that fails. It'll be about 12 lines if it's similar to the FAQ example for testing SIO.
The register map should be the same, maybe the pin is shorted or open..a hardware issue not code ?
Jay
DonWells
PostPosted: Thu Jan 04, 2018 6:15 pm     Reply with quote
Well here goes.
Its an edited version of the code to just include the uart bits.
I'm just trying to find if there are any gotchas porting to the 16f18877
As you can see, my message starts '[' followed by either a 'K' or a 'R'.
I believe the ISR is not being fired.
I believe the hardware is ok 'cos if a plug in a 16F877 it works fine.
#include "16f18877.h"
// Fuses
//     Internal 32Mhz
//     |                     Watchdog disabled
//     |                     |      Power up timer
//     |                     |      |    No FLASH Program Memory Protection
//     |                     |      |    |          Brownout enabled
//     |                     |      |    |          |         No Low Voltage programming
//     |                     |      |    |          |         |      No EE Memory Code Protection
//     |                     |      |    |          |         |      |      FLASH program memory write enable
#fuses RSTOSC_HFINTRC_32MHZ, NOWDT, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT
#use Delay(clock=32000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BITS=8, PARITY=N, ERRORS)
#define RS232_BUFFER_SIZE   21
// variables used for rs232
byte rs232_index;
byte rs232_data_available;
char rs232_rx_data[RS232_BUFFER_SIZE];
byte start_msg;
// serial interface interrupt routine
#INT_RDA
rs232_isr()
   char rcvd = 0;
       rcvd = getc();            // get data from RS232
   if (rcvd == '[')         // check for message start "[", begin record
      rs232_index = 0;
      start_msg = 1;
   if (start_msg == 1)
      rs232_rx_data[rs232_index] = rcvd;
      rs232_index++;
      if (rcvd == ']')      // check for msg end "]", stop record
         start_msg = 0;
                        rs232_data_available = true;
      if (rs232_index > RS232_BUFFER_SIZE)   // reset buffer
         start_msg = 0;
// the one and only...
main()
   // 0 - output, 1 - input
   set_tris_a(0b00010001);   // for leds & buzzer, a4 input, a0 input for adc
   set_tris_b(0b11111111);   // all inputs
   set_tris_c(0b10000000);   // c7 rs232 input
   //           rx
   enable_interrupts(INT_RDA);
   enable_interrupts(PERIPH);
   // loop for a bit
               // other stuff here
      if (rs232_data_available == true)
         rs232_data_available = false;
         if (rs232_rx_data[1] == 'K') // mph - kmph message
            if (rs232_rx_data[2] == 'm')
               show_mph = TRUE;
               show_mph = FALSE;
         if (rs232_rx_data[1] == 'R')   // reset
            // 012
            // [R]
            ascii_trip_tenths = 0x30;   // zero
            ascii_trip_units = 0x30;   // zero
            ascii_trip_tens = 0x20;      // blank
            ascii_trip_hundreds = 0x20;   // blank
            write_eeprom(TRIP_EEPROM_ADDR,     0x30);
            write_eeprom(TRIP_EEPROM_ADDR + 1, 0x30);
            write_eeprom(TRIP_EEPROM_ADDR + 2, 0x20);
             write_eeprom(TRIP_EEPROM_ADDR + 3, 0x20);
   } // end of while loop
PostPosted: Thu Jan 04, 2018 6:40 pm     Reply with quote
Ok 1 thing pops out...
1) no device header....
#include pictype.h
I don't use the 16F1887
then...
2) this...
I don't see rs232_buffer_size set to a value...
DonWells
PostPosted: Thu Jan 04, 2018 7:11 pm     Reply with quote
Sorry, posting error. I have edited my original post.
The maximum size of a received message is 3 characters.
PostPosted: Thu Jan 04, 2018 7:23 pm     Reply with quote
OK.. get rid of the tris statements...let the compiler do it automatically.
The register sets for the 2 PIC are different so maybe that will make the program work ?
Not on test PC can't play computer.
Jay
PostPosted: Thu Jan 04, 2018 8:57 pm     Reply with quote
It is setting up a software UART. To make it setup a hardware UART,
add the two lines shown in bold below, in that exact position:
#pin_select U1TX=PIN_C6
#pin_select U1RX=PIN_C7
Also, the three byte variables shown below are not initialized,
and they should be:
DonWells wrote:
byte rs232_index;
byte start_msg;
Also, there's a problem in your buffer limit test in your #int_rda isr.
You created a buffer 21 bytes in length. It will have indexes of 0 to 20.
But then in the isr your check for "greater than" 21. You should change
the test to check if it's "equal to" 21.
Also, this line below is not needed. It's done automatically when you
enable GLOBAL interrupts.
I didn't see it in your posted code, but since you set PortB to all inputs,
I think you might enable internal pull-ups at some point. In this PIC,
the CCS pull-up functions take a bitmask as the parameter, instead of
True/False with the 16F877. That's because the pull-ups are individually
configurable instead of all or nothing.
DonWells
PostPosted: Thu Jan 04, 2018 11:11 pm     Reply with quote
Thank you PCM Programmer!
Inserting the lines:
fixed the problem.
I use:
port_b_pullups(0b11111111);
but its not shown in my listing
I have initialised the variable as you suggest.
All working now! How come a s/w uart it did not work with the pins in the #use rs232 statement?
PostPosted: Fri Jan 05, 2018 12:51 am     Reply with quote
Your original posted code did make a software UART.
But the CCS software UART routines can't make an #int_rda interrupt.
Only the hardware UART module can make that interrupt.
DonWells
PostPosted: Fri Jan 05, 2018 9:32 am     Reply with quote
Thanks for you help and explanation. Very Happy
