Temperature controlled fan using PIC 16F877A
jwoo
PostPosted: Mon Jan 01, 2018 2:34 pm     Reply with quote
Hello, I use 12V fan(2 wire), L293D, I want to adjust the speed of the fan according to the temperature. Fan is running but fan speed does not change according to temperature. I do not understand what the problem is, I'm happy to help.
#define LCD_RS_PIN      PIN_D0
#define LCD_RW_PIN      PIN_D1
#define LCD_ENABLE_PIN  PIN_D2
#define LCD_DATA4       PIN_D3
#define LCD_DATA5       PIN_D4
#define LCD_DATA6       PIN_D5
#define LCD_DATA7       PIN_D6
//End LCD module connections
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#device ADC=10
#use delay(clock = 4MHz)
#include <lcd.c>
char temperature[] = " 00.0 C";
unsigned int16 temp;
void motor();
void main(){
  setup_adc(ADC_CLOCK_DIV_8); // Divisor for 4 MHz crystal
  setup_adc_ports(AN0);                          // Configure AN0 pin as analog
  set_adc_channel(0);                           // Select channel 0 (AN0)
  delay_us(20);
  lcd_init();
  setup_ccp1(CCP_PWM);
  setup_timer_2(T2_DIV_BY_16, 125, 1);    //Setting timers for PWM
  set_timer1(0);
  lcd_putc('\f');                                // Clear LCD
  lcd_gotoxy(1, 1);                               // Go to column 1 row 1
  printf(lcd_putc, "Temp:");
  while(TRUE){
    temp = read_adc() * 0.489;                   // Read analog voltage and convert it to degree celsius (0.489 = 500/1023)
    if (temp > 99)
      temperature[0]  = 1 + 48;                  // Put 1 (of hundred)
    temperature[0]  = ' ';                     // Put space
    temperature[1]  = (temp / 10) % 10  + 48;
    temperature[2]  =  temp % 10  + 48;
    temperature[5] = 223;                        // Degree symbol
    lcd_gotoxy(6, 1);                            // Go to column 5 row 2
    printf(lcd_putc, temperature);             // Display LM35 temperature result
   motor(); }
void motor()
  if(temperature<10)
   setup_ccp1(CCP_OFF);
  if(temperature>10)
      if(temperature>=10&&temperature<=29)
        set_pwm1_duty((int16)204);         //20% duty cycle PWM
      else if(temperature>=30&&temperature<=35)
       set_pwm1_duty((int16)510);          //50% duty cycle PWM
      else if(temperature>=36&&temperature<=45)
         set_pwm1_duty((int16)715);      //70% duty cycle PWM
      else if(temperature>=46&&temperature<=150)
         set_pwm1_duty((int16)919);     //90% duty cycle PWM
PostPosted: Mon Jan 01, 2018 3:07 pm     Reply with quote
'temperature' is declared as a character array.
Your test test it as if it is a numeric value. It isn't.
temperature<10 won't work at all.
temperature' where you use it will be the address of the array in memory. Won't change.....
You have the numeric value in 'temp'. It is this value that you need to be testing against.
jwoo
PostPosted: Mon Jan 01, 2018 3:39 pm     Reply with quote
Yeaa my fool, thank you. Now it works properly.
PostPosted: Tue Jan 02, 2018 2:09 am     Reply with quote
Smile
Perhaps the lesson, is to think about your names.
If you called the text array 'degree_text', and the temperature numeric value 'temperature', it'd have been obvious where it was going wrong...
Glad it worked.
PostPosted: Tue Jan 02, 2018 11:16 am     Reply with quote
re: 'fan'
50% duty cycle won't give you 50% speed or volume of air, same holds true for 30%. you need to make some tests to get the real numbers.
also
if the 'fan' has a tachometer output ( aka PC CPU cooling fan) it's easy to get the actual RPM of the fan and control the speed.
just stuff to know and ponder about.
Jay
