using C1 on 18F45k22
tysie
PostPosted: Thu Dec 21, 2017 4:16 am     Reply with quote
I want to use C1 as a normal output at the 18F45K22.
I cannot use it because by default it is used for SOSCI.
How can I disable SOSCI and use the pin as an output in ccs?
PostPosted: Thu Dec 21, 2017 4:51 am     Reply with quote
By default it will be available to you. Depends on how you have the timers and clock setup. On some chips there is a fuse that has to be set, but not on this one.
It is not used as SOSC 'by default'. Only if the secondary oscillator is enabled for something.
If it is not working for you post a small program (clock, timer settings etc., only), that will compile and show the problem.
tysie
PostPosted: Thu Dec 21, 2017 4:53 am     Reply with quote
part of the main:
   setup_adc_ports(sAN11);
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);      //32,7 ms overflow
   setup_timer_2(T2_DIV_BY_16,190,1);
   setup_ccp4(CCP_PWM);
   //set_pwm4_duty((int16)300);
   set_pwm4_duty((int16)0);
header:
#include <18F45K22.h>
#device ADC=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(internal=16MHz)
#use FIXED_IO( A_outputs=PIN_A7,PIN_A6,PIN_A5,PIN_A4,PIN_A1,PIN_A0 )
#use FIXED_IO( B_outputs=PIN_B3,PIN_B2,PIN_B1,PIN_B0 )
#use FIXED_IO( C_outputs=PIN_C7,PIN_C6,PIN_C5,PIN_C4,PIN_C3,PIN_C2,PIN_C0 )
#use FIXED_IO( D_outputs=PIN_D7,PIN_D6,PIN_D5,PIN_D4,PIN_D3,PIN_D2,PIN_D1,PIN_D0 )
#use FIXED_IO( E_outputs=PIN_E2,PIN_E1,PIN_E0 )
#define LED   PIN_A0
#define S1   PIN_A1
#define DISPLAY2C   PIN_A4
#define DISPLAY2B   PIN_A5
#define DISPLAY2D   PIN_A6
#define DISPLAY2E   PIN_A7
#define DISPLAY3C   PIN_B0
#define DISPLAY3B   PIN_B1
#define DISPLAY3A   PIN_B2
#define ACTIVATESENSOR   PIN_B3
#define SENSORSIGNAL   PIN_B4
#define S4   PIN_B5
#define S3   PIN_B6
#define S2   PIN_B7
#define DISPLAYCOM1   PIN_C0
#define DISPLAYCOM2   PIN_C1
#define DISPLAY3F2   PIN_C2
#define DISPLAY3G2   PIN_C3
#define POWERENABLE   PIN_C4
#define DISPLAY3B2   PIN_C5
#define DISPLAY3A2   PIN_C6
#define DISPLAY1BC   PIN_C7
#define DISPLAY3E2   PIN_D0
#define BUZZER   PIN_D1
#define DISPLAY3D2   PIN_D2
#define DISPLAY3C2   PIN_D3
#define DISPLAY3F   PIN_D4
#define DISPLAY3G   PIN_D5
#define DISPLAY3E   PIN_D6
#define DISPLAY3D   PIN_D7
#define DISPLAY2A   PIN_E0
#define DISPLAY2F   PIN_E1
#define DISPLAY2G   PIN_E2
I toggle display com2 together with many other pins. All the pins are toggling except com2
RF_Developer
PostPosted: Thu Dec 21, 2017 5:05 am     Reply with quote
You have not included it in the pins you are using as outputs, so it will be an input:
#use FIXED_IO(C_outputs=PIN_C7,PIN_C6,PIN_C5,PIN_C4,PIN_C3,PIN_C2,PIN_C0 )
There is little point in using fixed or fast io modes. They also open you up to this sort of error. In 99% of all PIC code it's better, and simpler, to use standard IO mode and let the compiler manage TRIS stuff.
PostPosted: Thu Dec 21, 2017 12:25 pm     Reply with quote
RF-D is correct, though a bit off. I'd say 99.99999% of all the prorgams posted here do not require fixed or fast_Io().
My rule of thumb.. cut code using standard IO and test for a week. If, IF, it doesn't work THEN try fast_io. I've only truly needed it 3 or 4 times in 20 +years. All applications were 'time critical', using 4MHz xtals.
