max6675
Goto page 1, 2, 3  Next
madhusuthanan
max6675
PostPosted: Wed Aug 23, 2017 8:24 am     Reply with quote
Hi, I'm communicating with a max6675 through a pic16f72. I have the code below that shows only 00.0 in 7-segment display. Please help me to resolve this problem.
#include <16F72.h>
#device adc=8
#FUSES NOWDT
#FUSES HS
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
#USE SPI (MASTER, CLK=PIN_C3, DI=PIN_C5, DO=PIN_C4,ENABLE=PIN_C6, MODE=0, BITS=8, STREAM=SPI_1, MSB_FIRST)
#define MAX_CS PIN_C6
#define MAX_DO PIN_C5
#define MAX_CLK PIN_C3
int thermocouple_error;
int16 data;
int16 value;
void init_TC(void)
    output_low(MAX_CLK);
    //output_low(MAX_DO);
    output_low(MAX_CS);
    setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
    delay_cycles(1);
    output_high(MAX_CS);
int16 read_TC(void)
    BYTE datah, datal=0;
    int16 data=0;
    output_low(MAX_CS);
    delay_cycles(1);
    datah=SPI_READ(0);
    datal=SPI_READ(0);
    if( bit_test(datal,2))
      thermocouple_error = 1;
        bit_set(data,15);
        return(data);
      thermocouple_error = 0;
    data = datah<<8;
    data = data | datal;
    return(data);
int16 sortout(int16 raw)
    return(0x0FFF & (raw>>3));
int16 toCalc_TC(int16 tmp)
   return((int16)tmp * 10/4);
int16 do_everything(void)
   init_TC();
   return(toCalc_TC(sortout(read_TC())));
unsigned int Hex(int a)
 switch(a)
      case 1: return 0x06;
      case 2: return 0x5B;
      case 3: return 0x4F;
      case 4: return 0x66;
      case 5: return 0x6D;
      case 6: return 0x7D;
      case 7: return 0x07;
      case 8: return 0x7F;
      case 9: return 0x6F;
      case 0: return 0x3F;
      case 'e': return 0x79;
      case 'r': return 0x70;
   int16 value;
   unsigned long Temp;
   char error[] = "err";
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_bit);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
   set_timer0(0);
   set_timer1(0);
   setup_adc_ports(AN0_AN1_AN3);
   set_adc_channel(0);
   delay_us(10);
   while(1) {
      if (input(pin_A4)) {
        if (!(thermocouple_error)) {
            Temp = value*10 /4;
            output_b(Hex(Temp %10));
            output_low (pin_c2);
            output_high (pin_c1);
            output_high (pin_c0);
            delay_ms(8);
            output_b((Hex((Temp/10) %10)) | 0x80);
            output_high (pin_c2);
            output_low (pin_c1);
            delay_ms(8);
            output_b(Hex((Temp/100) %10));
            output_low (pin_c0);
            delay_ms(8);
        else {
            output_b(Hex(error[0]));
            delay_ms(8);
            output_b(Hex(error[1]));
            delay_ms(8);
            output_b(Hex(error[2]));
            delay_ms(8);
PostPosted: Wed Aug 23, 2017 1:04 pm     Reply with quote
You are mixing SPI operations.
Look at the data sheet. Look at the entry for #use spi. Do you see any reference to setup_spi, or spi_read?. Look at spi_setup. Do you see any reference to #use?. The setup, was the older way of oeperating SPI, with more limited capabilities. #use spi, is designed to work with spi_xfer _only_ they are not designed for cross mixing.
You are also making things more complex than they need to be.
The device is designed to have the clock idling low, with data transferred on the rising edge of the clock. This is mode 0. So:
#USE SPI (MASTER, CLK=PIN_C3, DI=PIN_C5, DO=PIN_C4, MODE=0, BITS=16, STREAM=SPI_1)
//Then use no other setup or read commands.
//Just use:
   unsigned int16 value; //any suitable 16bit variable
   output_low(MAX_CS);
   value=spi_xfer(SPI_1, 0L); //transfer the value
Nothing more is needed to read the 16bits from the SPI using #USE!.
This transfers the whole 16bits, in one operation.
There may well be other problems in your code, but start by using this and verifying you are getting the 16bits from the chip.
madhusuthanan
max6675
PostPosted: Sun Nov 26, 2017 9:33 am     Reply with quote
hi i'm communicating the max6675 through software spi communication. I have the 7 segment problem. It is not displaying correct value.
#include <16F72.h>
#device adc=8
#FUSES NOWDT
#FUSES HS
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
int16 data;
int16 value;
void init_TC(void)
    output_low(MAX_DO);
    output_low(MAX_CS);
    delay_cycles(1);
int16 read_TC(void)
    int16 data=0;
    int i;
    output_low(MAX_CS);
   for (i = 0; i<16; i++) {
      output_high(MAX_CLK);
      delay_cycles(1);
      shift_left(&data,2,input(MAX_DO));
  thermocouple_error = bit_test(data,2);
    return(data);
   init_TC();
unsigned int Hex(int a) {
 switch(a) {
   int16 value;
   unsigned long Temp;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);      //52.4 ms overflow
   set_timer0(0);
   set_timer1(0);
   set_adc_channel(0);
   delay_us(10);
   while(1) {
            value = do_everything();
            Temp = value*100/4;
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
        else {
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
Pease help me to resolve.
PostPosted: Sun Nov 26, 2017 12:10 pm     Reply with quote
madhusuthanan wrote:
void init_TC(void)
output_low(MAX_CS);
delay_cycles(1);
You are using the wrong SPI mode. You are using SPI mode 1.
MAX6675 uses SPI mode 0. This is shown on page 6 of the data sheet
in this diagram:
Figure 1b. Serial Interface Timing
Look at the diagram. The clock idles at a low level and samples the data
on the rising edge. This is mode 0.
Here are the #define statements for the SPI modes:
// SPI mode definitions (for 16F and 18F PICs).
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
madhusuthanan
PostPosted: Tue Nov 28, 2017 12:17 am     Reply with quote
hi pcm programmer,
I changed to spi mode 0. still this is showing the same problem. I'm using thermocouple module max6675 .
#include <16F72.h>
#device adc=8
#FUSES NOWDT
#FUSES HS
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
int16 data;
int16 value;
void init_TC(void)
    output_low(MAX_DO);
    output_low(MAX_CS);
    setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_16);
    delay_cycles(1);
int16 read_TC(void)
    int datah, datal=0;
    int16 data=0;
    int i;
    output_low(MAX_CS);
      delay_cycles(1);
      delay_cycles(1);
  delay_cycles(1);
    return(data);
    return(0x0FFF & (raw>>3));      //returns only the bits converning temperature
   return((int16)tmp * 10/4);      //adjusts data to floating point format, and accounts for the decimal point
   init_TC();
 switch(a) {
   int16 value;
   unsigned long Temp;
   set_timer0(0);
   set_timer1(0);
   set_adc_channel(0);
   delay_us(10);
   while(1) {
            //value = value>>3;
            Temp = value*100/4;
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
        else {
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
PostPosted: Tue Nov 28, 2017 1:52 am     Reply with quote
Er. Nowhere in the code you show, do you actually read the chip.....
Your main sets up three timers, and enables the GLOBAL interrupt (why?...). Configures the internal ADC (incorrectly - what does the data sheet say about using the internal RC clock?). It then loops testing a value 'thermocouple_error', and the input bit A4, but doesn't ever call any of the thermocouple routines. Duh...
You are not going to get anything from the chip till you call the routines to access it. It doesn't communicate by telepathy.
madhusuthanan
temperature value
PostPosted: Fri Dec 01, 2017 3:49 am     Reply with quote
I check this code this always read only 00.0 value only from max6675 module. Please guide me to solve this issue.
#include <16F72.h>
#device adc=8
#FUSES NOWDT
#FUSES HS
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
int16 data;
int16 value;
void init_TC(void)
    output_low(MAX_DO);
    output_low(MAX_CS);
    setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4);
    delay_cycles(1);
int16 read_TC(void)
    int datah, datal=0;
    int16 data=0;
    int i;
    output_low(MAX_CS);
      delay_cycles(1);
      delay_cycles(1);
  delay_cycles(1);
    return(data);
   init_TC();
 switch(a) {
   int16 value;
   unsigned long Temp;
   set_timer0(0);
   set_timer1(0);
   set_adc_channel(0);
   delay_us(10);
   while(1) {
            //value = value>>3;
            Temp = value*100/4;
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
        else {
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
PostPosted: Fri Dec 01, 2017 6:29 am     Reply with quote
ALL of Mr. T's comments are still valid !
Your program NEVER accesses the TC device, the ADC is setup wrong, and the ISRs are enabled...
fix those 3 items and it may work
I can't confirm as I don't have those device here to physically test.
PostPosted: Fri Dec 01, 2017 6:49 am     Reply with quote
I wonder.
Does the poster realise that declaring a routine, does not result in it being executed?.
The processor only executes the 'main', and anything it calls.
Currently the code is never calling the routines to access the chip.
PostPosted: Fri Dec 01, 2017 7:40 am     Reply with quote
the 'hint'
in your code....
while(1) {
// you
// need
// to
// add
// function calls
// here
// to
// read( access )
// the
//TC device
madhusuthanan
termocouple value
PostPosted: Fri Dec 01, 2017 8:04 am     Reply with quote
thank you temtronic,
Still I'm getting 00.0 value in the display . Please guide me to solve this issue.
#include <16F72.h>
#device adc=8
#FUSES NOWDT
#FUSES HS
#FUSES NOPUT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
int16 data;
int16 value;
void init_TC(void)
    output_low(MAX_DO);
    output_low(MAX_CS);
    delay_cycles(1);
int16 read_TC(void)
    int datah, datal=0;
    int16 data=0;
    int i;
    output_low(MAX_CS);
      delay_cycles(1);
      delay_cycles(1);
  delay_cycles(1);
    return(data);
   init_TC();
 switch(a) {
   int16 value;
   unsigned long Temp;
   set_timer0(0);
   set_timer1(0);
   set_adc_channel(0);
   delay_us(10);
   while(1) {
            //value = value>>3;
            Temp = value*100/4;
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
        else {
            delay_ms(8);
            delay_ms(8);
            delay_ms(8);
PostPosted: Fri Dec 01, 2017 8:17 am     Reply with quote
OK...
here..
// value = do_everything(); //temporarily delete this
// add this
value = 123 // a KNOWN number
See what is displayed. Change 'value' for several numbers within you desired range of valid numbers.
IF the numbers are NOT correct, the error is in your 'display' code.
IF the numbers ARE correct, the error is in your 'TC data acquistions' code.
PostPosted: Fri Dec 01, 2017 8:27 am     Reply with quote
There are a couple of very dubious things with the code:
First he is setting up the hardware SPI, but then reads the chip using software SPI. This in itself may cause problems. One or the other...
Then the setup should only be done once.
madhusuthanan
max6675
PostPosted: Fri Dec 01, 2017 9:12 am     Reply with quote
thank you Ttelmah. Please give me the sample software spi program.
PostPosted: Fri Dec 01, 2017 9:49 am     Reply with quote
You are using software SPI. Use the hardware:
int16 read_TC(void)
    int datah, datal;;
    int16 data=0;
    int i;
    output_low(MAX_CS);
    datah=spi_read(0);
    datal=spi_read(0);
    data=make_16(datah,datal);
    return(data);
The code you copied here was obviously using hardware SPI (since it already had the two variables for the separate bytes declared), but you had it doing software manually. However you had already enabled the hardware SPI module on the same pins....
Honestly provided your compiler is reasonably modern, using #USE SPI and either hardware or software is even easier.
Only call the init code once. Before your while loop. In the loop just read the chip.
Page 1 of 3
