RC522 RFID module SPI
Goto page Previous  1, 2, 3, 4, 5  Next
Mario_KA
PostPosted: Tue Nov 21, 2017 1:57 pm     Reply with quote
I had some issues today which I can't fix before Friday :(.
Anyway I am not too sure how to connect the Reset. In this thread he guys claimed RST is connected to ground?
On some other schematics I see rst connect to 3.3V
NRSTPD
reset and power-down input:
power-down: enabled when LOW; internal current sinks are switched off, the oscillator
is inhibited and the input pins are disconnected from the outside world
reset: enabled by a positive edge
I guess NRSTPD refers to the RST pin on the module. Thats the statement from the datasheet.
PostPosted: Tue Nov 21, 2017 2:29 pm     Reply with quote
The 'N' is a standard abbreviation for -ve. The PD input needs to be high, or the whole chip is disabled. However the data sheet suggests that the RST is an _edge triggered_ signal, with a reset triggered by the rising edge. I'd certainly tie it to +5v, but if it is edge triggered it may well be OK to have it just held to either rail.
Mario_KA
PostPosted: Tue Nov 21, 2017 3:48 pm     Reply with quote
Since the entire chip works on 3.3V I guess I have to tie it up to 3.3 instead of 5V, correct?
I read some RFID MFRC522 libraries for Arduino to easily access the reader.
It is quiet cumbersome to understand the relation between every register and since we lack of time in this project I decided to adjust/port a proper library to PIC C. The library looks quiet ok and what I have to do is basically change the semantics to use it with CCS C Compiler,correct?
https://github.com/ljos/MFRC522
looks like a good one, but it is .cpp, dunno if CCS can handle cpp on the other hand I can just rewrite it without using a class
PostPosted: Tue Nov 21, 2017 5:24 pm     Reply with quote
...as for the hardware, just use a 3 volt power supply and keep set the PIC clock at 8MHz. This will interface properly however you might have damaged the RFID device from supplying 5 volts. It's best to read it's datasheet to see what the maximum any pin on the RFID device can have. Hopefully it's OK...
...as for software, porting over the A-code is in itself quite a task but will work ONCE you've got the basics down. You should be able to write a register as plenty of people have responded to you already.
I can't supply any working code as I don't have the RFID device to test. While I could write 'pseudo-code' without hands on testing, it's still a guess. Sending you code that should work might not due to a hardware problem, like 2 pins shorted on your PCB.
Jay
PostPosted: Wed Nov 22, 2017 2:17 am     Reply with quote
Yes the old "90% of PIC's still use 5v" slip..... Very Happy
Mario_KA
PostPosted: Wed Nov 22, 2017 6:01 am     Reply with quote
Jay
I did not run the RFID with 5 Volts. It should be fine.
I know how to read and write registers but the MFRC522 is just not easy to use because a lot of registers depend on each other. In my previous assignments we used easier chip where we could read 1 or 2 registers in order to receive a value like temperature.
If I read the library now I have to use at least 5-10 registers before and some of them every time I want to read a UID.
A pseudo code would make my day Laughing
Thank you though Smile
PostPosted: Wed Nov 22, 2017 6:01 pm     Reply with quote
Honestly that's what programming is ! Reading hundreds of pages of datasheets, spending weeks cutting code, and drinking pots of coffee into the wee hours to LEARN how to use 'chips'. I've got 5+ decades doing this, last 2 just using PICs and learn something new everyday.
While the RFID device is complicated, there are probably default or factory settings that will allow the device to operate in 'basic' mode.
You can 'cheat' by seeing what others have done, perhaps on another micro. If they use C, you can 'transpose' into CCS C. That is not really hard.
Jay
Mario_KA
PostPosted: Thu Nov 23, 2017 12:44 am     Reply with quote
Jay
That exactly what I wanted to do with the RFID Arduino library, it is C++ but that should not be a problem for me to translate.
I am interested in learning more about that chip and reading the registers etc. Its just due too my limited time. My group members decided to do that project without telling me and they can't even print stuff on a LCD and now everything relies on me and I have got a lot of assigments left and cant spent a lot of time each day. It just the circumstances which makes it impossible for me to figure it out completely alone.
PostPosted: Sat Nov 25, 2017 8:31 pm     Reply with quote
Well I've ordered one and 3 fobs for a 'Winter project' direct from China, should be 16 days to get them based on the last parts I got.
Mario_KA
PostPosted: Sun Nov 26, 2017 10:46 am     Reply with quote
Cool beans,
I have another Question. I have an Arduino Mega here and the RFID reader is working perfectly fine. Anyway I need to use PIC16...
First step is reading the firmware version in the same order as I am doing it with Arduino but the "result" is fluctuating and giving me wrong value/version number.
I measured all the Voltage levels from Arduino to RFID and from PIC16 to RFID the only difference I can measure is that MOSI of PIC is under 1mV and on Arduino it is 3V.
Isnt 1mV too low? Despite that fact the MC3202-C ADC is working fine with that voltage levels.
Can I adjust the Voltage level somehow?
I initialize SPI as follows
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
Indeed, I need to hook up an oscilloscope on Tuedsay to have legit results.
PostPosted: Sun Nov 26, 2017 11:36 am     Reply with quote
You are selecting SPI Mode1. With this the clock _idles_ low.
I think the 522 uses mode0.
SPI_L_TO_H | SPI_XMIT_L_TO_H
Mario_KA
PostPosted: Sun Nov 26, 2017 12:17 pm     Reply with quote
Sounds reasonable but didnt change anything unfortunately
Thats all I want to do know because the rest will be selfexplaining once i get to write/read one register.
output_low(CS);
//spi_write(((VersionReg<<1)&0x7E) | 0x80);
// version = spi_read(0x00);
version =spi_read(((VersionReg<<1)&0x7E) | 0x80);
output_high(CS);
if(!version)
lcd_clear();
text = "not found";
lcd_gotoxy(1, 1);//go to position 1,1 on lcd
lcd_print(text);
if(version)
lcd_clear();
text = "Module found";
lcd_print(text);//print on lcd
sprintf(buffer,"%2X",(version)); //display version in hexadecimal
lcd_gotoxy(1, 2); //go to second line of lcd
lcd_print(buffer);
PostPosted: Sun Nov 26, 2017 12:28 pm     Reply with quote
You didn't give us a full program there. Show us the #define statement
for 'VersionReg'.
Mario_KA
PostPosted: Sun Nov 26, 2017 12:36 pm     Reply with quote
#include <main.h>
#include <lcd16216.c>
#define VersionReg 0x37
//spi modes
char buffer[17],text[17];
byte version;
// setup_oscillator(OSC_8MHZ, 3); //Adjust Oscillator for proper Serial Communication
setup_spi(SPI_MASTER|SPI_MODE_0|SPI_CLK_DIV_16);
lcd_init();
lcd_clear();
output_high(CS);
output_low(CS);
version =spi_read(((VersionReg<<1)&0x7E) | 0x80);;
output_high(CS);
if(!version)
lcd_clear();
text = "not found";
lcd_gotoxy(1, 1);
lcd_print(text);
if(version)
lcd_clear();
lcd_gotoxy(1, 1);
lcd_gotoxy(1, 2);
lcd_print(buffer);
PostPosted: Sun Nov 26, 2017 12:59 pm     Reply with quote
Instead of this,
Mario_KA wrote:
output_low(CS);
output_high(CS);
Try calling the read routine that was posted earlier in this thread.
Substitute the following line for the code listed above:
version = MFRC522_read(VersionReg);
Put this routine above main():
int8 MFRC522_read(int8 addr)
int8 retval;
output_low(MFRC522_CS_PIN);
spi_write(((addr << 1) & 0x7E) | 0x80);
retval = spi_read(0x00);
output_high(MFRC522_CS_PIN);
return(retval);
Page 3 of 5
