Iīve read in the CCS manual that the #FAST_IO directive affects how the compiler will generate code for input and output instrucctions.
Itīs also said that the fast method of doing I/O will cause the compiler to perform I/O without programming of the direction register.
What does all the above mean? What happen if we donīt specify the #fast_io directive for a certain port? How the I/O is done then?
Thanks for all,
Imanol
Neutone
Re: #FAST_IO directive
Posted: Fri Jan 09, 2004 12:14 pm
Thanks for all,
Imanol
Each pin can be either an input or an output but not both at the same time. If you have a pin that will only be used as an output it may be set as an output only once instead of every time the output value is changed. If you use a pin as both an input and an output the pin must be specified as an output or an input before each read or write to the pin.
#standard_IO is the default and it will specify the direction (in or out) before you use the pin, each time you use it.
