SPI comm
rfjhh
SPI comm
PostPosted: Thu Jun 15, 2017 9:05 am     Reply with quote
I'm new in SPI comms. I need to communicate two PICs:
16F887 Master
16F886 Slave
I've written the following two programs:
MASTER:
#include<16f887.h>
#use delay (clock = 20 MHz)
#include<LCD.c>
#fuses HS, NOWDT, NOMCLR, NOBROWNOUT, NOLVP, NOPROTECT, NOFCMEN, NODEBUG
#use fast_io(E)
#use standard_io(C)
#use standard_io(A)
   int8 valor;
   lcd_init();
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
   lcd_gotoxy(1,1);
   printf(lcd_putc, "SPI maestro");
   while(true)
      output_bit(PIN_B0, 1);      // SS
      lcd_gotoxy(1,2);
      printf(lcd_putc, "Recibiendo");
      valor=spi_read();
      delay_ms(2);
      lcd_gotoxy(1,2);
      printf(lcd_putc, "Valor = %u", valor);
      output_bit(PIN_B0, 0);
SLAVE
#include<16f886.h>
#use delay (clock = 8 MHz)
#include<LCD.c>
#fuses INTRC_IO, NOWDT, NOMCLR, NOBROWNOUT, NOLVP, NOPROTECT, NOFCMEN, NODEBUG
#use fast_io(E)
#use standard_io(C)
#use standard_io(A)
/*    RC3   SPI CLK
   RC4   SPI   SDI
   RC5   SPI SDO
   RC0   SPI SS
   int8 valor;
   lcd_init();
   setup_spi(SPI_SLAVE | SPI_H_TO_L);
   lcd_gotoxy(1,1);
   printf(lcd_putc, "SPI esclavo");
   setup_oscillator(OSC_8MHZ);
   while(true)
      if(input(PIN_C0)==1)      // entrada SS
         lcd_gotoxy(1,2);
         printf(lcd_putc, "Enviando");
         spi_write(input_b());
      lcd_gotoxy(1,2);
      printf(lcd_putc, "Terminado");
But I have nothing in SCK, SDO, SDI.
May somebody help me?
Regards
Ricardo
alan
PostPosted: Thu Jun 15, 2017 9:12 am     Reply with quote
If you read the manual your use of spi_read are wrong for master.
Return a value read by the SPI. If a value is passed to the spi_read() the data will be clocked out and the data received will be returned. If no data is ready, spi_read() will wait for the data is a SLAVE or return the last DATA clocked in from spi_write().
If this device is the MASTER then either do a spi_write(data) followed by a spi_read() or do a spi_read(data). These both do the same thing and will generate a clock. If there is no data to send just do a spi_read(0) to get the clock.
rfjhh
PostPosted: Thu Jun 15, 2017 10:11 pm     Reply with quote
I've modified the code as follows:
MASTER
#include<16f887.h>
#include<LCD.c>
#use fast_io(E)
#use standard_io(C)
#use standard_io(A)
   int8 valor;
   set_tris_e(0xfe);
   lcd_init();
   lcd_gotoxy(1,1);
   while(true)
      lcd_gotoxy(1,2);
      output_high(PIN_E0);      // SS
      valor=spi_read(0x96);
      delay_ms(2);
      lcd_gotoxy(1,2);
      output_low(PIN_E0);
SLAVE:
#include<16f886.h>
#include<LCD.c>
#use fast_io(B)
#use fast_io(C)
#use standard_io(A)
/*    RC3   SPI CLK
   RC4   SPI   SDI
   RC5   SPI SDO
   RC0   SPI SS
   int8 valor;
   set_tris_b(0xff);
   set_tris_c(0xdf);
   setup_spi(SPI_SLAVE | SPI_H_TO_L | SPI_CLK_DIV_16);
   while(true)
      valor = input_b();
         spi_write(valor);
Now I have the clock signal, but nothing happens from the slave to the master.
