BCD to byte and back
picker
PostPosted: Mon Jan 05, 2004 2:34 am     Reply with quote
I need to increment a BCD value. My thoughts were to convert the BCD to a byte add 1 and then convert back to BCD. Does anyone have any code that converts BCD to Byte and back?
Kevin
PostPosted: Mon Jan 05, 2004 2:54 am     Reply with quote
I think you could write code to do it without converting back
and forth to binary, but to answer your question:
There is code in the archives to do this. Do a search for bin2bcd
and you'll find that routine and its mate, bcd2bin.
Re: BCD to byte and back
PostPosted: Mon Jan 05, 2004 5:21 am     Reply with quote
Kevin
More work than is needed. :-)
int8 BCDval
if ((++BCDval & 0xF)==0xA) BCDval+=5;
A lot less work than performing the two conversions.
picker
PostPosted: Mon Jan 05, 2004 6:06 am     Reply with quote
Thanks guys...
KerryW
BCD math
PostPosted: Mon Jan 05, 2004 9:03 am     Reply with quote
int8 BCDval
Shouldn't that be
if ((++BCDval & 0xF)==0xA) BCDval+=6; ?
Re: BCD math
PostPosted: Mon Jan 05, 2004 4:38 pm     Reply with quote
KerryW wrote:
int8 BCDval
Shouldn't that be
Yes...
Sorry, a 'mistype'.
