Int8 Rom problem
niccolo.calandri
Int8 Rom problem
PostPosted: Sat Apr 29, 2017 10:08 am     Reply with quote
int8 rom number=10;
char mess[20]="";
number=0;
sprintf(mess,"%d",number);
usb_cdc_puts(mess);
number=1;
usb_cdc_puts(mess)
Why my output is
0
0
and not
0
1
PostPosted: Sat Apr 29, 2017 12:07 pm     Reply with quote
Declaring it as rom, means it can't be written to/changed.
However the compiler is looking ahead at your code, and seeing the first value being assigned after the declaration, and putting this in at compile time, instead of the 10 in the declaration.
The code then can't change it.
niccolo.calandri
PostPosted: Sat Apr 29, 2017 2:55 pm     Reply with quote
Ok, Thanks Ttelmah,
if I need to store a variable in the Rom. How can i do it? How can i write in rom?
PostPosted: Sat Apr 29, 2017 3:43 pm     Reply with quote
Post your PIC and your compiler version.
PostPosted: Sat Apr 29, 2017 6:04 pm     Reply with quote
I also thought 'rom' meant read-only, but I ran it in MPLAB 8.92 simulator
and it worked. So then I ran it in hardware and it also worked.
This is with compiler version 5.071. The test program shown below
displays the following output in TeraTerm:
0
1
The .LST file shows the compiler is writing to program memory,
This is the initialization of 'number'. It's value is set when the PIC is
programmed by the Pickit 3:
int8 rom number=10;
ROM data:
00FFFE: 0A
At run-time, 'number' is changed to 0:
...... number=0;
001CA:  CLRF   @@1B
001CC:  CLRF   TBLPTRU
001CE:  SETF   TBLPTRH
001D0:  MOVLW  FE
001D2:  MOVWF  TBLPTRL
001D4:  CLRF   FSR0H
001D6:  MOVLW  @@1B
001D8:  MOVWF  FSR0L
001DA:  MOVLW  01
001DC:  MOVWF  @WRITE_PROGRAM_MEMORY.P2
001DE:  MOVLB  0
001E0:  RCALL  0024
Next, it's changed to 1:
...... number=1;
00220:  MOVLW  01
00222:  MOVWF  @@1B
00224:  CLRF   TBLPTRU
00226:  SETF   TBLPTRH
00228:  MOVLW  FE
0022A:  MOVWF  TBLPTRL
0022C:  CLRF   FSR0H
0022E:  MOVLW  @@1B
00230:  MOVWF  FSR0L
00232:  MOVLW  01
00234:  MOVWF  @WRITE_PROGRAM_MEMORY.P2
00236:  RCALL  0024
Test program:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
int8 rom number=10;
char mess[20]="";
number=0;
puts(mess);
number=1;
puts(mess);
while(TRUE);
niccolo.calandri
PostPosted: Sun Apr 30, 2017 12:00 am     Reply with quote
So maybe is my PIC?
PIC18F26J50 - Compiler version:
Do you know if I have to set some fuses? I use ICD and CCS 5.070.
Moreover, I test again my code. What is happening to me is that when i try to set the variable the number is always SET to 0. Why?
I want used the program memory to store some variable. Because I want shut down the PIC and when power suppply is recovered I want be sure that the variable is correct.
Do you use a different method?
hmmpic
PostPosted: Sun Apr 30, 2017 2:12 am     Reply with quote
When i use "rom" to store something, I thereafter use "read_program_memory" to get it back into a var.
PostPosted: Sun Apr 30, 2017 2:22 am     Reply with quote
Interesting. Looks like the compiler has added the feature to allow direct writing to ROM without using the program memory commands.
However 'think about it'. Problem is that you can't just erase a word of ROM.
You can change a bit from '1' to '0' by writing, but can't change a bit from '0' to '1', without erasing a whole page.
Now in your example, you have 'b00001010'. This you can then write to '0b00000000', by writing. However you can't then change it to '0b00000001', without erasing the whole page in the ROM.....
The 'write program memory' function, that it's using, will erase a page, if you write to the first address in a page. So looks as if PCM_Programmers example, has his ROM value stored at the first address of a page, while yours doesn't.....
Now obviously you can make this work, by explicitly locating the ROM value to an address at the start of a page. However you then have the 'caveat', that everything else in this page will also be erased.
So realistically you need to store all the values you want in ROM that you are going to change, in one page of memory, then have a routine that reads them all into RAM, changes the one you want, and writes the whole page back. Given the new ability to do this with a rom 'variable', declare yourself a structure that is going to contain everything you want stored this way. Then to change a value, copy this structure into RAM, change the value you want, and write the whole structure back.
On your chip a page (the smallest area that can be erased), is 1024 bytes.
Remember that every time you erase a page, it uses one 'life' of the program memory. 10000 lives only. So make sure if you have several values to change you do them 'all in one go', not 'one at a time'....
Alternatively, much more economically on lives, CCS supply a set of code in the drivers, that allows you to treat a page using functions like EEPROM. This uses a flag to 'walk' through the page storing changes, and only erases the page when it runs out of space.
PostPosted: Sun Apr 30, 2017 2:33 am     Reply with quote
Beware. Two diiferent meanings of 'ROM'....
#ROM, locates numbers at a particular location in program memory. These are not variables, and have to be accessed by read_program_memory.
rom as being shown here, is an alternative form of the 'const' declaration. This also locates values in the rom, but allows them to be directly read as a variable. Also supports pointers to the rom memory.
As we have now discovered CCS have also added the ability to write to these (sometime recently), but haven't actually told us this, and also have not handled the limitations of ROM memory, regarding writing. It's be hard for them to handle this, because of the sheer amount of RAM involved in saving a page.
niccolo.calandri
PostPosted: Sun Apr 30, 2017 10:24 am     Reply with quote
Ok! I understand it.
Now it is perfectly clear to me! Thanks to much
PostPosted: Sun Apr 30, 2017 11:37 am     Reply with quote
Ttelmah is talking about the CCS driver file, virtual_eeprom.c, which is
explained on this CCS page, with a short sample program of how to use it:
http://www.ccsinfo.com/newsdesk_info.php?newsdesk_id=192
The virtual_eeprom.c file is in your CCS compiler \Drivers folder.
PostPosted: Mon May 01, 2017 12:22 am     Reply with quote
Thanks PCM_programmer.
I've been posting for a couple of weeks 'without the compiler', since I was away. Had to rely on memory, and unlike an EEPROM, mine tends to forget 'details'... Smile
dan king
PostPosted: Mon May 01, 2017 1:23 pm     Reply with quote
maybe you need to implement some wear levelling ;)
PostPosted: Mon May 01, 2017 1:26 pm     Reply with quote
I think it's all getting towards the life limit....
