Gabriel
iAQ-Core from Hell - SOLVED |
Posted: Wed Apr 26, 2017 8:11 am |
Hi All,
Has ANYONE used this sensor before?
https://ams.com/eng/content/download/686523/1787697/file/iAQ-core_Datasheet_EN_v1.pdf
I have a working driver and the sensor seems to be working properly but only after fighting with the ACKs and NACKs, I finally got it working by looking at the wave form on the Scope and flipping bits until i got 9 distinct byte transfers....
after visually/manually doing so the Chip stopped reporting wrong data, wrong flags, or simply just dropping all comms...seems stable.
This working solution i have seems to be stable only getting a "Busy" (real) flag from time to time which i expected as I'm reading the chip 8 times to produce 1 value.... I'm reading continuously every 1.5 seconds as the data sheet says 1s max rate.
My problem is that the ACK and NACKs that i have on my code are different from what the Data sheet says... but if I follow the datasheet exactly, it fails... Whats up with that?
I'm willing to share compare notes/code with anyone who has this chip...
I have a MLX90614 on the same I2C Bus...(no issues here) with the driver i posted a while back.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093
newguy
Posted: Wed Apr 26, 2017 8:44 am |
Don't question your working code - data sheets are frequently wrong. I'm not entirely surprised given how the data sheet is laid out and written.
Have you mentioned this to the manufacturer? |
Posted: Wed Apr 26, 2017 9:05 am |
The chip has a 5 minute warm-up time. I looked at Arduino code on the
net for this chip, and it's not doing anything special. There is a warning
in the data sheet to never set the Write bit. If you want help, post your
code. |
The behaviour looks completely standard....
I think part of the problem is to understand that they are sometimes referring to the ACK bit, not the level, and (of course), that and 'ACK' is a low bit in I2C, where a NACK is a high bit. So the timing diagrams show 'ACK' in several places where the chip is returning a 'NACK'. This is because the diagram is just labeling the bit, not telling you what it's level will be...
#define CHIP_ADDR 0xB5
#define READ_OK 0
#define COLD 0x10
#define BUSY 0x1
#define ERROR 0x80
#define NOT_FOUND 0xA0
struct {
unsigned int16 pred;
unsigned int8 status;
unsigned int32 resistance;
unsigned int16 Tvoc;
} iAQ;
int8 load_IAQ(void)
int8 * data_ptr;
int8 ctr;
const int8 offset[] = {1, 0, 2, 6, 5, 4, 3, 8, 7};
int1 ack;
data_ptr=&iAQ;
//point to 9 byte structure for data
//note that the chip sends MSB first. I've used a const array
//to correct the byte order.
i2c_start();
ack=i2c_write(CHIP_ADDR);
if (ack!=0)
i2c_stop();
return NOT_FOUND; //chip not found error
//chip has acknowledged
for (ctr=0;ctr<8;ctr++)
*(data_ptr+offset[ctr])=read_i2c();
} //read 8 bytes with an acknowledge
*(data_ptr+offset[8])=read_i2c(1); //no acknowledge on last byte
i2c_stop();
//now if status is not OK signal error
return iAQ.status;
This should give you the structure iAQ filled with the data from the chip.
Have modified this so it returns the status with an added value (NOT_FOUND), for if the chip is not acknowledging.
So you can now just call this, and test the return for the status.
avro698
Joined: 11 Nov 2006 Posts: 9 Location: South Wales, UK.
Posted: Wed Apr 26, 2017 9:24 am |
Hi Gabriel,
Yes, I've used it. You don't mention which version you are using, -P or -C. I used -C
As previously mentioned, you must wait for 5 minutes until 'real' data is available. Easiest way is to just read the whole 9 bytes from the device as follows: (doesn't show what I do with the data )
i2c_start();
i2c_write(device_address);
i2c_read(1);
i2c_read(1);
i2c_read(1);
i2c_read(1);
i2c_read(1);
i2c_read(1);
i2c_read(1);
i2c_read(1);
i2c_read(0);
i2c_stop();
I dump the data straight into a structure (not shown) and just reference that.
avro698 |
Gabriel
Posted: Wed Apr 26, 2017 3:19 pm |
Hi All,
Thank you for your support:
Code: | #define iAQ_Core_Read_Bit 0x01 // Read/Write direction bit - ONLY READ on this chip
#define iAQ_Core_ACK 0x00 // ACK for I2C transaction
#define iAQ_Core_NACK 0x01 // NACK for I2C transaction |
Code: | i2c_start(); // Send Start Bit
if (i2c_write(Command)==iAQ_Core_ACK) // Send "Write" Command to the Device Address
Raw_Data[0]=i2c_read(iAQ_Core_NACK); // Prediction Byte0
Raw_Data[1]=i2c_read(iAQ_Core_NACK); // Prediction Byte1
Raw_Data[2]=i2c_read(iAQ_Core_NACK); // Status Byte
Raw_Data[3]=i2c_read(iAQ_Core_NACK); // Get first 8 data bytes without sending ACK
Raw_Data[4]=i2c_read(iAQ_Core_NACK); // Get first 8 data bytes without sending ACK
Raw_Data[5]=i2c_read(iAQ_Core_NACK); // Get first 8 data bytes without sending ACK
Raw_Data[6]=i2c_read(iAQ_Core_NACK); // Get first 8 data bytes without sending ACK
Raw_Data[7]=i2c_read(iAQ_Core_NACK); // Get first 8 data bytes without sending ACK
Raw_Data[8]=i2c_read(iAQ_Core_ACK); // Needs ACK on last byte only - Wierd.
i2c_stop(); // Hammer Time |
This is my final working "Read" sequence after much simplification and manual correction brutforcing ACKs and NACKS....
Ive had no further issues since but im hoping someone can shed some light on what the hell is up with this NACK ACK confusion..
I am aware of the warm up time and i have a status check function that redirects code and prints to screen different messages depending on the status byte value.
I am also aware of the Write bit restriction and have implemented a safety check to avoid setting it by mistake.
I have the "C" version for Continuous reads...
PLEASE NOTE: The comments might not match the actual working instructions.. i got this working this morning.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
Posted: Wed Apr 26, 2017 3:29 pm |
Under each wave form on the data sheet it explicitly says if there is an ACK/NACK.
Also the level of the ACK/NACK is shown by the wave form on the datasheet... at least im assuming the levels are correct.
Its particularly the requirement for ACK/NACK on the 4 resistance Byte that has me confused.
Posted: Wed Apr 26, 2017 3:59 pm |
Your confusion is caused by CCS defining ACK and NACK differently for
i2c_read() and i2c_write(). See the manual:
Quote: |
i2c_read( )
Syntax:
data = i2c_read();
data = i2c_read(ack);
Parameters:
ack -Optional, defaults to 1.
0 indicates do not ack.
1 indicates to ack.
Quote: | i2c_write( )
Returns:
This function returns the ACK Bit.
0 means ACK, 1 means NO ACK |
In your code, you defined ACK/NACK in terms of how i2c_write() uses it.
But that's inappropriate for i2c_read(). For your read routine, you
should have several ACK's followed by a NACK at the end, at least in
terms of the parameter names. If you use 1's and 0's from the manual's
definition of the i2c_read() parameter, you would avoid the naming conflict. |
Gabriel
Posted: Thu May 04, 2017 8:31 am |
Thanks PCM... i did not know the ACK was diferent from read to write.
Sorry for the delay in response.. I went on holydays! _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ezflyr
Posted: Sat May 06, 2017 10:04 am |
Hi Gabriel,
I, too, have been experimenting with the IAQ module, and it's mostly working fine. I have noted that every other read of the status byte is decimal 160. This occurs both during the warm-up and valid states. Everything else seems as expected except this result! Have you see this? _________________ John
If it's worth doing, it's worth doing in real hardware! |
Posted: Sat May 06, 2017 10:59 am |
Though you now have it working, this is worrying.
Quote from data sheet:
Quote: |
If the status is ERROR constantly (or very frequently) this
indicates that the module is reading non-realistic values, and
the sensor element is probably defective.
However it'd be worth seeing if reducing the frequency of your access has any change on this. |
ezflyr
Posted: Sat May 06, 2017 6:45 pm |
I saw that in the datasheet, but I don't think that explains what I'm seeing. According to the documentation, the actual ERROR status is a return of 0x01. I'm not seeing that. If it's correct, the code I'm seeing doesn't seem to be documented in the docs. The actual data that is being returned by the module seems perfectly fine after the warm-up period, and access frequency does not seem to affect this issue. I've send an email to the manufacturer to see what they think! _________________ John
Posted: Sun May 07, 2017 12:49 am |
No. ERROR is 0x80. 160 in decimal....
0x00: OK (data valid)
0x10: RUNIN (module in warm up phase)
0x01: BUSY (re-read multi byte data!)
0x80: ERROR (if constant: replace sensor)
ezflyr
Posted: Sun May 07, 2017 5:59 am |
Hi Ttelmah,
Yes, you are correct, the ERROR code is 0x80, not 0x01 - my recollection was faulty when I wrote that. But, that is 128 decimal, not 160 decimal, so still undocumented. The return I'm getting 160 decimal is 0xA0. Weird! _________________ John
newguy
Posted: Sun May 07, 2017 10:30 am |
0xA0 is RUNIN | ERROR. I don't believe it's a separate, unique, code - just those two being asserted simultaneously. |
