russk2txb
command line compiler |
Posted: Sat Apr 08, 2017 4:51 pm |
I'm trying to automate some processes and so am trying to use the command line compiler. I read the help file on it but it seems incomplete. For example it shows a -FH option for PCH, but no option for PCW. I am not sure - maybe FH will work anyway, but no way to tell as I get an immediate error reported on line 2 of the processor include file.
My command line is like "ccsc -FH build=test.ccspjt"
The error is "18F4682.h, Line 2 unknown device type - try PCH. I thought I was trying PCH.
Any help?
Thanks, Russ |
Posted: Sat Apr 08, 2017 6:13 pm |
Look in the Output Window in MPLAB vs. 8.92 after it builds. It lists what it does:
Quote: | Executing: "C:\Program files\Picc\CCSC.exe" +FH "PCH_Test.c" +DF +LN -T -A +M -Z +Y=9 +EA #__18F4682=TRUE
This section in the CCS manual lista what each of those parameters does:
Quote: | Invoking the Command Line Compiler |
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf |
russk2txb
Posted: Sat Apr 08, 2017 6:28 pm |
Ok, thanks for that. I don't use MPLAB so had no idea. I'll give it a try.
Regards, Russ |
Posted: Sun Apr 09, 2017 7:45 am |
Also, PCW, is the IDE (W=Windows).
It is what calls the command line compiler.
PCB
PCM
PCH
PCD are the names of the compiler modules for the different chip families.
So, 'of course' there is no option for PCW using the the command line compiler!.... |
