Memory usage difference between MPLAB and CCS
Arakel
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Wed Mar 08, 2017 8:38 am     Reply with quote
Good day to everyone and happy Spring!
I have a question about the memory usage accuracy of MPLABX and CCS. On CCS I get very high usage, while on MPLABX I get low RAM and ROM memory. Which one is accurate?
I am using MPLABX 3.50 with the CCS compiler plugin. I got similar results on a few projects.
[img]
https://www.dropbox.com/s/ov678uws005ye1j/MPLABX-1.png?dl=0
[/img]
[img]
https://www.dropbox.com/s/7y0fp79pfuckj40/CCS1.png?dl=0
[/img]
Yo! I love learning and technology! I just do not have experience so do not be angry if I ask a stupid question about a detail! From so much to remember sometimes I forget the details in order to remember the big problems!
PostPosted: Wed Mar 08, 2017 9:03 am     Reply with quote
What does the .LST file show ? The usage will be listed at the top of the file.
PostPosted: Wed Mar 08, 2017 9:12 am     Reply with quote
It almost sounds as if the chip selection is not set right somewhere.
Arakel
PostPosted: Wed Mar 08, 2017 10:56 am     Reply with quote
I put a random project, so I hit the ROM correctly.
MPLAB .lst file
[img]https://www.dropbox.com/s/03fubv336vtol8d/MPLAB-lst-1.png?dl=0[/img]
CCS .lst file
[img]https://www.dropbox.com/s/fhkg31i004oc8aj/CCS-lst.png?dl=0[/img]
MPLAB IDE
[img]https://www.dropbox.com/s/vol67roors46b1b/MPLAB-memory-usage.png?dl=0[/img]
CCS IDE
[/img]https://www.dropbox.com/s/2tmbz9izwb1bzpi/CCS-memory-usage.png?dl=0[img]
PostPosted: Wed Mar 08, 2017 11:36 am     Reply with quote
Both are using 33% ROM.
You have to set the option in MPLAB, to 'import symbols after compilation', otherwise it doesn't know what RAM is being used. This is why it is displaying a silly value (think about it, your float array is 20% of the available RAM straight away, yet MPLAB is showing 0%....
Same will apply to ROM for any project with significant constants stored. Depending on the chip, some of these aren't included in the code size unless the symbol table is loaded.
Arakel
PostPosted: Wed Mar 08, 2017 10:25 pm     Reply with quote
Ok, thanks, I did not know I have to check the .lst file to know the memory usage. I will see how set up the table.
Arakel
PostPosted: Thu Mar 09, 2017 9:03 am     Reply with quote
I clicked "enable" near the "Memory usage" but it did not work. Perhaps something else is wrong?
