LCD programing
rfjhh
LCD programing
PostPosted: Tue Jan 24, 2017 8:07 am     Reply with quote
Why in the LCD.c file, if I want to write (lcd_putc), a read routine is performed before the writing routine?
What is being checked before the execution of data writing? There is some documentation about it???
newguy
PostPosted: Tue Jan 24, 2017 8:42 am     Reply with quote
Before you attempt to access the LCD you first need to "ask" it if it is busy; it will hold its data bit 7 high if it is busy. All the driver is doing is checking this busy flag and waiting until it clears, if it is set, before proceeding.
You can omit the read if you respect the delays that you'll need to give the LCD between accesses in order to allow it to complete one task before giving it another.
PostPosted: Tue Jan 24, 2017 10:59 am     Reply with quote
The flex lcd driver in the code library forum has the option of not using
the R/W line and therefore it doesn't poll the busy bit. It uses delays
as newguy said.
rfjhh
PostPosted: Wed Feb 01, 2017 9:35 am     Reply with quote
Thanks.
Another question: What's lcdlat, where is it???
PostPosted: Wed Feb 01, 2017 10:04 am     Reply with quote
Use the forum's search page to find the threads that have lcdlat in them.
Here is the link to the search page:
http://www.ccsinfo.com/forum/search.php
PostPosted: Wed Feb 01, 2017 10:06 am     Reply with quote
lcdlat could refer to the 'latch' or output port of a PIC. Newer PICs have them.
My version of LCD.C and FlexLCD.c do not have 'lcdlat' though.
Jay
PostPosted: Wed Feb 01, 2017 10:07 am     Reply with quote
Come on Jay, the search engine shows it to be in the Code Library.
It's a #byte statement for the LCD's data port.
PostPosted: Wed Feb 01, 2017 11:29 am     Reply with quote
hmm.. I just checked again and neither my copies of lcd.c and flex_lcd.c have 'lcdlat' in them, according to edit>find......
now I'm thinking I may have old versions and they've been 'updated' over the past few years ?
Jay
rfjhh
PostPosted: Wed Feb 01, 2017 2:02 pm     Reply with quote
Guys
I've find where, in LCD.c, the lcdlat definition is made:
#if defined(__PCB__)
LCD_PIN_MAP lcd, lcdlat;
#byte lcd = LCD_DATA_PORT
#byte lcdlat = LCD_DATA_PORT
#elif defined(__PCM__)
LCD_PIN_MAP lcd, lcdlat, lcdtris;
#byte lcdtris = LCD_DATA_PORT+0x80
#elif defined(__PCH__)
#byte lcdlat = LCD_DATA_PORT+9
#byte lcdtris = LCD_DATA_PORT+0x12
#elif defined(__PCD__)
#word lcd = LCD_DATA_PORT
#word lcdlat = LCD_DATA_PORT+2
#word lcdtris = LCD_DATA_PORT-0x02
#endif
#endif //LCD_DATA4 not defined
