Can't debug 12F683 : SOLVED
alan
PostPosted: Sat Jan 28, 2017 6:28 am     Reply with quote
Hi All,
Have a funny problem which I can't sort out.
Compiler 5.024
12f683
If I download the program for debugging using the ICD_U40, I get an error message that the oscillator settings are wrong.
Here are the header VCS_I1.h
#include <12F683.h>
#case
#DEVICE adc=8
#FUSES INTRC_IO, NOWDT, NOMCLR, NOPROTECT, PUT, BROWNOUT, NOIESO, NOFCMEN
#USE delay(clock=4M)
#DEFINE VMeas sAN3
#DEFINE VCh1 3
#DEFINE SW_OnLimit   60
#DEFINE SW_OffLimit  80
#DEFINE ON_TIMER 10 //(0.1 * 60.0/0.262)  //0.262 = timer1 overflow of 262ms
#DEFINE OFF_TIMER 20 //(0.1 * 60.0/0.262)
#DEFINE CHRG_ON PIN_A2
Main file VCS_I1.c
unsigned int16 OnTimer=ON_TIMER, OffTimer=OFF_TIMER;
unsigned int16 ADCvalue;
void main(void) {
  setup_adc_ports(VMeas);
  setup_adc(ADC_CLOCK_DIV_16);
  set_adc_channel(VCh1);   //Set to 1st Fan channel
  setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //262 ms overflow
  //Switch output off
  output_high(CHRG_ON);
  while(TRUE) {
However if I download another project to the same board as they use the same PIC I do not get the debug error and the PIC runs. I am using the same hardware, obviously the program does not perform right as everything is not correct on the pins.
ACFan.h
#include <12F683.h>
#case
#DEVICE adc=8
#DEFINE IMeas1A sAN3
#DEFINE ICh1 3
#define NO_OF_SAMPLES 70
#if (SMALL_FAN)
  #DEFINE LowILimit   60
  #DEFINE HighILimit  80
#else
  #DEFINE LowILimit   45
  #DEFINE HighILimit  70
#endif
#DEFINE LED1R PIN_A2     //High on pin and low on LED1R will give Green
#DEFINE LED1G PIN_A5     //High on pin and low on LED1G will give Red
AcFan.c
#define SMALL_FAN 0
#include "ACFan.h"
unsigned int16 Timer;
unsigned int8 ADCvalue,Sample[NO_OF_SAMPLES],max,min;
int1 Fan1OK;
void main(void) {
  unsigned int8 i;
  setup_adc_ports(IMeas1A);
  set_adc_channel(ICh1);   //Set to 1st Fan channel
  while(TRUE) {
    //Take 30 samples to determine max and min
    //A period are 20ms if taking a sample every 100us then need 200 samples
    //Lack of RAM limit samples to 70 so take in 3 batches thus 210 samples
    min=0xff;
    max=0;
    for (i=0; i<NO_OF_SAMPLES; i++) {
      //Meas Imeas1A
     Sample[i] = read_adc();    //Read 1st Fan Current
     delay_us(100);
    if (Fan1OK) output_high(AllOKPLC);
    else output_low(AllOKPLC);
Probably something small that I keep overlooking. Hopefully somebody can spot it or point me in the right direction.
Regards
PostPosted: Sat Jan 28, 2017 6:48 am     Reply with quote
well I don't see anything....but I don't use the ICD either. Perhaps there's a 'setting' IN the ICD that is in conflict with the code 'fuses'?
I know in MPLAB you can build either a 'debug' or a 'release' version and no way will the 'debug' version WORK in the real world !
Since 2nd program works and has same fuses, I suspect it's an ICD config issue....
Jay
PostPosted: Sat Jan 28, 2017 7:07 am     Reply with quote
You've omitted the stuff in the VCS_I1.c that you have posted showing how it includes the .h file.
Post files that we can compile.
alan
PostPosted: Sat Jan 28, 2017 7:10 am     Reply with quote
Thanks for the answer Jay.
I am using the same compiler and same ICD for both programs on the same hardware.
And I believe the debug warning of the oscillator as I can not get the chip to work with a basic LED Flash, that is why I tried to use the debug feature too see if I can find the fault.
Regards
alan
PostPosted: Sat Jan 28, 2017 7:12 am     Reply with quote
Sorry Ttelmah, I missed the include file when copying.
#include "VCS_I1.h"
void main(void) {
  //Switch output off
  while(TRUE) {
PostPosted: Sat Jan 28, 2017 8:09 am     Reply with quote
#include <12F683.h>
#case
#DEVICE adc=8
#DEFINE VMeas sAN3
#DEFINE VCh1 3
void main(void) {
  //Switch output off
  while(TRUE) {
Above your .h + .c combined, compiled fine for me.....
so something is 'funny', still think ICD settings ??
Jay
PostPosted: Sat Jan 28, 2017 8:43 am     Reply with quote
One 'lateral' thought. Have you tried pasting your own code back in, and seeing how this behaves?.
I'm thinking something like the old problem where there is a hidden 'non printable' character accidentally in the text somewhere. Code looks fine but then won't work.
Assuming you have the 14pin ICD header chip?.
How is the system powered?.
alan
PostPosted: Sat Jan 28, 2017 8:45 am     Reply with quote
Thanks to all who tried to help.
U40 can program part but not debug. I were lucky that it worked with one program, if I add or delete a line it stopped working.
Regards
Alan
PostPosted: Sat Jan 28, 2017 11:18 am     Reply with quote
But you didn't answer, do you have the special ICD header board
that is required to do debugging on the 12F683 ? You can't debug
without it. You can buy it from Microchipdirect.com or other sources.
Look up the part number in the MPLAB help.
alan
PostPosted: Sat Jan 28, 2017 11:30 am     Reply with quote
I just saw that you need the special header.
PostPosted: Sat Jan 28, 2017 11:38 am     Reply with quote
One option is to debug your program on a larger PIC that does have
built-in debugging features. Then load it into a 12F683 when you're done.
This thread explains (at the end) how to use #org statements to reduce
the memory available on a larger PIC so it will "look like" a smaller PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=43086
