Vern Hardingham
Watchdog timer on PIC24F |
Posted: Fri Jan 27, 2017 2:32 pm |
I have:
Code: | #fuses WPOSTS4, NOWINDIS, NOWDT, ICSP1, NODEBUG, NOWRT, NOPROTECT, NOJTAG
#fuses HS, DISUVREG, NOIOL1WAY, OSCI0, NOCKSFSM, PR, PLL3, NOIESO
#use delay(crystal =12M, clock=32M, USB_FULL)
setup_wdt(WDT_512MS);
restart_wdt();
delay_us(1);
When I compile and run, the processor just keeps resetting.
Can someone help me with this? |
Posted: Fri Jan 27, 2017 3:08 pm |
Some more basic info needed:
What actual processor?.
What compiler version?.
Show the basic 'main' containing the code. |
Vern Hardingham
Posted: Fri Jan 27, 2017 5:01 pm |
The processor is PIC24FJ256GB106
Compiler is CCS PCD IDE v 5.067
Code: | void main()
extern GeneratorStates curState;
initialize();
GATE = OFF;
TXKEY = OFF;
PWRCTL = ON;
init_SPI();
ad9833Reset();
init_UART();
displayInit();
displayClear();
delay_ms(1);//without delay here first line does not indent properly
displayCurOff();
displayStartup();
delay_ms(144);
usbstate = USB_INST;
TRISC = 0b10010000;
CS_DAC = 1;
CS_MEM = 1;
SPI_SCK = 1;
delay_ms(1000); // hold startup screen for 1 second
displayClrLn(3);
displaySetcurpos(3, 4);
printf(displayWrite, "Calibrating");
DACcal();
DACunbufsetlvl2(0x00);
reset_FLASH();
unlock_FLASH();
beep(100);
pwrTmr = PWRTIMEOUT;
SECONDS_TMR = ON;
curState = GEN_STARTUP_DISPLAY;
// Enable Watchdog timer here
while (TRUE)
// Reset the watchdog timer here
restart_wdt();
delay_us(1);
// StateMachine_Update();
Posted: Fri Jan 27, 2017 5:32 pm |
Also, are you running this with an ICD in Debug mode ? |
jeremiah
Posted: Fri Jan 27, 2017 9:03 pm |
Replace #FUSES NOWINDIS with #FUSES WINDIS
Otherwise, just about every time you call the WDT reset, you will reset the PIC. NOWINDIS enables windowed mode for the WDT. You normally don't want that.
Posted: Sat Jan 28, 2017 1:42 am |
As a comment:
TRISC = 0b10010000;
You are aware that the registers on a PIC24, are 16bit wide, not 8bit?. |
Vern Hardingham
Posted: Mon Jan 30, 2017 11:50 am |
Thanks Jeremiah, changing to WINDIS got it working. I guess I was thinking that NOWINDIS meant no windowing but actually means no windowing disable whereas WINDIS means disable windowing.
Also thanks Ttelmah, I'll look into the TRISC. I guess I must only be using the low 8 bits otherwise this would cause problems. Where I want to access just 8 bits of TRISB I have defined TRISBH and TRISBL as the 8 bit portions of the register. |
